[HOW TO] CLI install method
Homey Pro only!!!
It does not work this way with Homey (cloud), it only supports CLI run which is there only for development purposes.
Installing Node.js
  • Check Node.js version on Homey: Homey App: Settings - General - About - Node.js version
  • Download Node.js (use Homey’s version or higher) from https://nodejs.org/ and install it on your computer.
Download the app you want to install from GitHub
  • Go to the repository on GitHub (the correct link for the app you want to install is at the bottom of the app store page or given directly through the support topic)
  • On GitHub choose the right branch to install, master is usually the main branch as released in the app store but there could be other branches like a debug branch.
  • From the correct branch click the Clone or Download > Download Zip button to download the app in zip format
  • Unpack the zip file
Setup Node.js
  • Open command prompt and install the Homey CLI tools: npm install -g homey
  • Log in to your Homey from the command prompt homey login (allow access through the webpage that is opened)
  • Navigate to the folder of the app that you have extracted in the previous step
  • For help on the available commands: homey --help
For list (un)selecting Homey:
  • homey homey list
  • homey homey select
  • homey homey unselect
For running app:
homey app run
homey app run --clean
homey app run --path /path/to/my/app/folder
For installing app:
homey app install
Resource
Command Line Interface for Homey App Development
Homey CLI
Homey och energimätning Aeotec
Ikea smart plug - beschikbaar in nld
Cannot include Aeotec Garage Door Opener
Fibaro Motion Sensor does not report/stuck
Home Easy bedienen met Homey
Toon en Homey
Mi Homey
[APP][Pro] TuyAPI / Neo Coolcam wall plug WIFI app
Mi.Light app
Homey Community App Store
[APP][Pro] Tuya Zigbee App
[APP][Pro] Tuya Cloud - This app allows you to connect Homey to the Tuya cloud
Tradfri Remote an Homey?
Homey Pro (early 2023): Einbindung Homematic
Qubino Fil Pilote
[APP][Pro] Insight Trends [Abandoned]
Hot oder Schrott?
[APP][Pro&Cloud] Shelly
Toon en Homey
Robot vacuum and Homey
Heimdall - Let Homey watch over your home
Node.js / Homey HCS
Zigbee logging
Update KlikaanKlikuit
[APP][Pro] TP-Link KASA LAN - Smart Plugs and Bulbs (WIFI)
[APP][Pro] SMA Energy - My home. My energy. Our climate
[APP][Pro] Ubiquiti UniFi Protect
TRÅDFRI Shortcut Button (Dutch: Snelkoppelknop)
Wisselen tussen test en live app
Homey pro 2023 - zwave too much traffic error?
LG WebOS better integration
Meross App crashes
H.O.O.P. (Hope) - Homey Object Oriented Programming
My Nodered flow for setting lights. Is this possible with Homey?
[APP][Pro] Global Caché - Connect IR, Serial, and Relay to Almost Any Network
Homey triggert niet een zeg kaartje als ik een spraak commando uitvoer
Unauthorized Tado thermostat and thermostatic
Vision security app
Add Z-Wave device non-secure?
[APP][Pro] Harmony Hub (v2.0.7)
[APP][Pro] Xiaomi Mi Home App
Can't add Fibaro Relay Switch FGS-212 to the Homey 2.0
Heating Schedule App
Fibaro Shutter 3 not supported yet?
The new Homey Pro — Ask Me Anything
MQTT Hub/Gateway
Aeotec Door/Window Sensor 7
Homey 2.0.0 Community App Compatibility List
[Beginner] Turn electricity off when you shut down PC
Het grote Homey 2.0.0 stable discussie topic [NL]
Guide to Connecting gBridge to Homey for Google Assistant
App von GitHub
Plugwise stretch 2 app?
Welche inoffiziellen Apps nutzt ihr?
Belkin wemo support stopped?
Alternative apps (store) [Not in app store]
[Archived][APP][Pro] OpenWeatherMap
See all actual temperatures in 1 overview
How do I detect a specific computer being turned on and run a flow?
[APP][Pro&Cloud] DoorBird
Greenwave Systems v.2.0 removed power capabilities
Vision security app
Yeelights worden niet meer herkend
Github code to app?
[APP][Pro] Magic Home LED
Oomi devices
[APP][Pro] WeatherFlow's Smart Weather Station
Z-rain delete
Unable to add Fibaro Walli Dimmer
Fibaro motion sensor not recoginised
Hihome slimme stekker
[APP] Yeelights LAN
Yeelight not working
[APP] Prometheus.io exporter
Philips Hue GU10 white ambiance alleen simpel zigbee
Fritzbox Bridge
Icons toevoegen
Adding aeotec siren 6 to homey
Probleem met Ring & Homey
Cannot find/add Ring devices
Ring Doorbell V2
Sending multiple Zwave commands at once
RGBW LED-strip aansturen met Homey
Forsinkelse (lag) i flows?
Besoin d’aide avec Walli
Developer Code/App zu Homey hinzufügen
Mi Homey
Denon - Heos ''apparaat niet beschikbaar''
Aeotec NanoMote Quad
Ring Doorbell Autorisation button not working
[APP] Denon Heos app form @nlrb [Not in app store]
Zwave device’s as a repeater
Import devices from Home Assistant, MQTT
[APP] Yeelights LAN
Fibaro/Z-wave probleem (unsecure include)
Somfy Protect / Home Alarm (formally known as MyFox)
Sonos Say
Aeotec Home Energy Meter Gen5 - 3 clamp
Change device type
[APP][Pro] Bluesound - Multi-room Music. The Hi-Res Way
Fibaro devices doesn't recognised by Athom
Aeotec doorbell 6 in Aeotec app version 3.0.5 missing
Aren't there airconditioning (airco or AC) devices/apps in Homey?
Netscan app
Fehlermeldung Panasonic TV
Innr FL140C integration
Problemen koppeling Neo Coolcam smartplug
Toon en Homey
Ring Security - Extend Heimdall with Ring Security products
Neuer HCS?
Stoom & Gas verbruik uitlezen Rooted Toon
Doorbird koppelen
Aeotec Garage Controller issue
Multiple Ikea Trådfri Gateway dirty hack
Z-Wave unresponsive and unreliable
Node Red: A widget based dashboard working with Homey trough MQTT
20% korting op alles van Nuki
Need help installing app on Homey from GitHub
[App][Cloud&Pro] Twinkly
Ring Doorbell, Camera and Alarm support for Homey
LG WebOs does not work
[APP][PRO] ABUS for Homey Pro (2023)
Brel, bi-directioneel
[APP][Pro] TP-Link Deco
[APP][Pro] Sure Petcare App - (Sureflap Pet Door/Sureflap Cat Flap)
Homey Pro ist mit CCU3 verbunden - Batteriestand der Fensterkontakte wird in Homey nicht angezeigt
[APP][Pro] ID Lock App (v2.0.0)
Homematic App - neue Geräte hinzufügen?
Neue App Timeline Manager
Apps verschwinden in Homey 19
How do you install this community app?
Homey Community App-Store
[APP][Pro] Flow Checker
iSmartGate app with more than one device
Support for Devolo Siren?
Usb powered - pir-motion or tilt sensor
Atag ONE app
[APP][Pro] Universal TUYA Zigbee Device App - test
Multiple Apps not installing/starting
2-Draht-Türsprechanlage im Homey einbinden?
LG app - Enter code on TV & use joystick of LG remote
[APP] Yeelights LAN
[APP] Fibaro - Your home is your castle (by Athom)
[Homey Pro 2016-2019] Firmware Updates
[APP][Pro] Philips Hue Zigbee (Without the bridge)
[APP][Pro] Broadlink App
[APP] Slide - Automate your curtains
Kan niet in loggen alternative app store
Netgear Meural
LG TV koppeling: er wordt steeds om toestemming gevraagd
[APP][Pro] MQTT Hub - Community version
Rolladen KNX - Homey geht - HomeKit nicht
Flow sehr sehr langsam. Warum?
[APP][Pro] Alfen - Optimal Charging, Smarter Homes: Powering Efficiency for You and the Grid
Z-Wave Thermostate fast immer unreachable
[APP][Pro] Xiaomi mi flora sensor/ropot app
Installing CLI error
[APP][Pro] Nuki Direct
HomeKit not working with iOS 16.2
[APP][Pro] OctoPrint
[APP][Pro] Xiaomi Miija (Temperature and Humidity)
[Abandoned] deCONZ
Kan Shelly app niet installeren op Homey
[TUTORIAL][PRO] Install Home Assistant community store app, and Athom app side-by-side
Homey Community Store (HCS) Login Error - Invalid Client ID
Control Eglo Connect / Awox devices with homey
Here can you find a video tutorial about installing apps with Homey CLI:
Here a new video with the current way of installing apps outside the app store
Thanks a lot! With your help, I’m now on 2.1.9
@HansieNL Does this mean that I can download an app from GitHub, make changes and install to my Homey?
I want to try a small “fix” in an existing app and see if that work.
That will be correct!
Cool! Then I can try the change on my Homey and if it works I can let the dev know. If it’s not working I can keep quiet and pretend that I didn’t even try. :smiley:
@HansieNL Athom seem to have change where you an see the Node.js version so you might want to update your excellent guide.
Its now under Settings - General - About - Node.js version.
Updated.
I try to install an adjusted version of the Neo Coolcam app, but i keep getting “Homey Offline” after validation:
Homey is online and responding.
What am i doing wrong?
Other question: If i have the official app already installed, will a CLI install overwrite that version?
Try searching for cli homey offline. It’s a common issue, in my opinion caused by Homey’s not-so-stellar networking setup. Rebooting Homey and/or your router and/or your WiFi access point might solve it.
Yes, it will. It also will not get updates anymore.
Thanks
Please keep it on-topic. Off-topic posts will be deleted without further notice.
@HansieNL could you update this topic with the new homey package for installing apps. I send users from my apps to this topic if they want to debug their issues but it’s now outdated with the new app store and installation process.
Inhaven’t seen the new instructions yet. If you like you can send them via pm and I’ll add them to my post.
Helaas lukt mij ook alleen stap 1.
Ik krijg helaas niet het webadres te zien van homey.
Wat doe ik fout? :thinking:
In English please.
Which step do you mean exactly? You have installed node.js, the release you want to install and installed the Homey CLI tools? (npm install -g homey)
this is the error after step 1 (what i’m doing wrong?)
Which version of node.js did you download?
Rather than using the latest, try using the one Homey uses
At moment of writing this is version 8.16.2
https://nodejs.org/download/release/latest-v8.x/
Not saying this is the solution, just to make sure it isn’t
