It would be great if you could test the pairing to see if I can find out why it’s giving duplicate devices. I have created a debug branch on GitHub which you will need to download from GitHub here: https://github.com/jghaanstra/magic.home.wifi/tree/debug
Then you will have to use the command line to run the app using the command athom app run. You will find out instructions here on how to setup the command line: [HOW TO] CLI install method
