HomeKit not working with iOS 16.2
I pushed a branch containing the latest version of hap-nodejs.
To install this, first make sure that you have the correct setup to install Homey app using the command line: [HOW TO] CLI install method
Then:
Keep the terminal window open as long as the app should run. It will probably output a lot of text and hopefully not crash (if it does, please post the text of the terminal console either here or on Github).
It may be required to reset the app, which you can do from the App Settings (either in the Homey app or through the developer page). After you’ve reset the app, stop it (by pressing Ctrl-C) and start it again.
