PTP
A lot of questions are asked about PTP. In this post a short explanation about PTP.
What does PTP mean?
PTP means Pull The plug. Make sure the power is off so not connected anymore. Pull the plug out of her!
Now don’t put it back in too soon. Some say a few seconds is enough but experiance is learning that we need to power her down for at least 10 minutes.
On the forums and on Slack u can see a lot of “11.2 minutes” power down. This ofcourse is a joke. The minimum of 10 minutes is not a joke!
Homey needs some time to cool down and make sure she can get a fresh start.
Powering up
After at least 10 minutes it is time to put the plug back in. She will be starting and loading apps. Depending of the amount of apps it can take a while.
Here i have 64 apps running so u can imagine it will take a while for all to be started.
After that it can also take a while before she can build the mesh again for Zwave and Zigbee. Have seen messages where it can take up to 20 minutes!
So patience is the keyword here. A good PTP takes at least 10 minutes and after that can take another 20 minutes.
Disclaimer
A PTP is NOT the same as a reboot from the menu!
