[HowTo] PtP on Homey Pro
PTP
A lot of questions are asked about PTP. In this post a short explanation about PTP.
What does PTP mean?
PTP means Pull The plug. Make sure the power is off so not connected anymore. Pull the plug out of her!
Now don’t put it back in too soon. Some say a few seconds is enough but experiance is learning that we need to power her down for at least 10 minutes.
On the forums and on Slack u can see a lot of “11.2 minutes” power down. This ofcourse is a joke. The minimum of 10 minutes is not a joke!
Homey needs some time to cool down and make sure she can get a fresh start.
Powering up
After at least 10 minutes it is time to put the plug back in. She will be starting and loading apps. Depending of the amount of apps it can take a while.
Here i have 64 apps running so u can imagine it will take a while for all to be started.
After that it can also take a while before she can build the mesh again for Zwave and Zigbee. Have seen messages where it can take up to 20 minutes!
So patience is the keyword here. A good PTP takes at least 10 minutes and after that can take another 20 minutes.
Disclaimer
A PTP is NOT the same as a reboot from the menu!
Zigbee stopped working/broken
Zigbee Issues
3 failed Aqara motion sensors failing after Homey 2.5.2 update?
[HOW TO] Adding a Z-wave device to Homey
Homey 3.0 update is done, and now?
Temperature & Humidity sensor can't add to Home
New update 8.0.4 disables ikea app
Something not working after a Homey firmware update? HERE'S THE SOLUTION
CPU en MEM gebruik niet kunnen checken
Homey Pro LED ring don't react
[APP] Shelly - Smart solutions for every home and office
Bewegingsensor reageert niet op beweging
[HowTo] Homey Pro (Early 2023) - Migrating from Homey (Pro) (Early 2016-2019)
Zigbee problem
Flows voor Homewizard P1 meter
[APP] Fibaro - Your home is your castle (by Athom)
Kaku schakelaars en afstandsbed. werken niet meer
Adding Fibaro switch out of range
[Solved] [red ring] I got red ring after update homey today
Homey - network request failed
Z-Wave network reliability
Hallo Pro en Daaaag Bridge
Fibaro Geräte reagieren sehr langsam
TRANSMIT_COMPLETE_NO_ACK meldung bei ZXT120 Remotec gerät
Neu bei Homey: Zwave Reichweite
Innr sp120
Zigbee issues - zigbee network broken? Please help :-)
2 Zigbee devices offline
HUE Lampen in Homey
Flows en apparaten weigeren
Homey (Cloud) - 2023-12-14 - 08:56 CET - Most of my apps crashed. What do we do? [Solved & Closed]
[App][Pro] HomeyKit
Homey blijft offline
[APP][Pro] Vision Security
Unable to add zigbee device
Homey Bridge Geräte anlernen
Problem with First setup
Not able to connect to Fibaro devices
Z-Wave Probleme beim einrichten sowie Reichweite
Ikea beweging sensor niet te koppelen
Tradfri v1.8.4 not working on Homey firmware 5.0.0.-rc.46
Zigbee issue
Fibaro universal binary sensor stops updating after a while
Homey Pro werkt niet meer
Ikea lights stopped working?
Cant include namron wall plug
Aren't there airconditioning (airco or AC) devices/apps in Homey?
Frient, Aqara and smartthings - connecting issues suddenly
Homey v5.0.0 (Stable Release)
Status Sensoren
Disaster! Devices and Groups gone after 8.1.1
Has anyone seen this: "On entry number is anumber" and "Action already busy anumber+1"
Mobile app timeline issue
Umzug Pro2019 auf Pro2023
Lidl lights connected to Hue no longer work sinds hue app update homey
Klikaanklikuit werkt niet meer
Homey has stopped talking to all my devices
Aqara componenten werken niet meer na homey update 12.2.0
Zigbee soil moisture sensor integration
Almost all devices, scripts and flows are unavailable after Homey update
How to delete a Zigbee device that is not in the list… (Aqara Motion sensor)
Homey werk niet meer na fout melding
Kan geen nieuwe apparaten toevoegen
Blind flow help needed
Prescence?
Can't use device as trigger in flows
Anleitung zu Developer Tools? (Z-Wave Optimierung)
Red ring, not responding to pulling the plug op
Na de recovery modus alle apps weg en flows
Popp Z-Wave Smoke Detector & Siren do not show up in devices list
Een Z-wave apparaat toevoegen aan Homey [Howto]
Welcome to the Tutorials category
Fibaro Roller Shutter V3 - ZWAVE maakt geen verbinding
Homey stopped working after update
Sinds gisternacht helder rood brandende LED ring
Help, AB werkt niet meer
Problemen met Homey algemeen
Problemen na update 4.0.0
Homey went offline/ crash
Homey app traag, veel devices met uitroeptekens(logitech harmony devices/app)
Xiaomi Sensoren „Gerät nicht verfügbar“ seit 4.x
Prescence?
Update to 3.2.1 and fatal issues with AN179 units
Cannot connect Aeotec Multisensor 6
Notification question: keeps asking me this
Exreme difficulties re-adding z-wave devices from fibaro
Ikea Tradfri koppelen lukt niet meer
Flow wordt uitgevoerd maar schakelt schakelaar niet (goed)
Homey v5.0.0-rc.56
Zigbee Optimierung
Problem with update Homey
MQTT Hub/Gateway
Na firmware 6.0 reageert Homey slecht
Z wave Assoziatioen einrichten
Z-wave blijft hangen
Fibaro rollershutter 3 problems
Familienmitglied hinzufügen funktioniert nicht
Homey Heizungsplaner
Problem adding aqara motion sensor
Latest update 7.1.4 position homey
Zigbee and maximum devices
Coming home from holiday to find lots off things not working?
Broken HUE accessoires
Weersensors
TRANSMIT_COMPLETE_NO_ACK on all Fibaro switches
Phillips Hue App stürzt mehrmal am Tag ab
Homey pro loses connection with all my zigbee after update
Sensative Strips Drip/Comfort einlernen funktioniert nicht
Namron devices fails after last upgrade to 2.2.92
Reconnecting devices
Namron – unble to add Zigbee GU10 bulbs
IKEA trådfri lights stopped working
[APP][Pro] Homewizard 🧙‍♂️
Keine Thermostatsteuerung über FritzBridge 0.10.3 bei Homey pro Version 12.4.6
Umzug von Fibaro HC 2 auf Homey
App fails after PTP, zigbee not ready
Can't setup Fibaro Button on Homey 2023
Leviton Dimmer an "Unknown Device"
Homey pro update to 10.0.0-rc118
Early 2019 update to 12.4.8
Homey Pro 2023 - IKEA Trådfri Dimmable bulb E27 does not work
Homey Pro (Early 2023) - Sunset Flows
KlikAanKlikUit werkt niet meer/lukt niet om te koppelen
Homey app ios error
Siri shortcuts (Automatisering)
TechniSat SmartHome App erschienen!
Push notification not working after Homey Pro 2023 app update
Fibaro RGBW controller 2 inclusion not working
Device Unavailable invalid_node
Z-Wave - 100% TX Error (HP2019/HP2023)
Backups werden nicht erstellt
Homey Pro (2023) stucked in boot loop
Homey ist offline trotz Regenbogen Ring
Unable to add additional Aqara devices
Zigbee not pairing, athom not responding
Best heating valves in connection with Homey Pro?
Issue pairing a new Zigbee device (Lixee power meter)
Homey Pro 2023 firmware 10.3.0 - zigbee is broken
Z-wave not feeling well?
Namron 4512737/4512738 Thermostat not fully removed
All aqara devices not working since 1.7.6 update on HomeyPro (2019)
[APP][Pro] Tuya Zigbee App
Homey Pro crashing to red LED ring when making a backup
Shelly EHOSTUNREACH
Homey geen verbinding met netwerk
[HOW-TO][Pro][Cloud] - Z-Wave Route map
Homey don't find zigbee units after last updated to version 10.0.6(09.02.2024)
Homey verbindet sich nicht mehr mit dem WLan
Homey Firmware 10.2.0 issues
ZSE50 Siren/Chime inclusion
Missing capability listener?
Homey Pro 2023 is constantly restarting!
After homey update, all Tradfri devices are temporarily unavailable
Fazit nach fast 3 Monaten und nicht ganz zufrieden
Na update 10.0.9 op mijn Homey Pro 2019 kan ik geen Google Home meer connecteren
Icasa remote zigbee
Homey Pro 2023 Zigbee performance issue
Heiman smoke detectors (both zwave and zigbee) don't trigger alarm
Aqara Smart Lock U200
Niko zigbee switches loses connection after homey pro hub update everytime…?
Flow cards not shown (randomly) after latest Homey update
Probleem dat zigbee (Gledopto & Philips Hue zonder bridge) niet meer werkt sinds update 12.10.0
Zigbee mesh routing not visible
KlikAan-Uit issues
Innr SP120 smart plugs problem
Z-wave stoped to work 🙄
Dio App
Z-Wave Rolläden reagieren nicht mehr
Report unreachable Z-wave devices
Thnx for the post, known info for me. I was wondering why its not possible to make a button/flow in homey tot ptp. So cache and every thing is cleared with a press of a button.
It’s not cache that’s being cleared when you wait longer, it’s hardware elements that get a proper (electrical) reset when you physically remove the power supply connector from Homey.
Properly designed electronic hardware does not need any long power off to get reset. Especially not digital hardware. Bad software however, which does not reset all circuitry (components, I/O devices etc.), can cause a lot of random problems which could be different depending on the power off time. A 10 min power off requirement sounds like religion more than science.
There is also a difference between pull the USB-plug (power-adater included!) OR only pull the USB-plug, as the adapter contains capacitors (i assume :grinning:).
Correct it is different,
but not for Homey as the Homey self Reset’s
  • and the Power Adapter doesn’t need the Reset
I think that Jackass means that the “capacitors” in the USB Power Adapter can still deliver a small amount of energy to Homey. So it is even better to remove the USB cable temporarily from the adapter than remove the whole adapter. The small electric flow to Homey components will stop a little earlier…
A couple of seconds… vs PtP for 10 minutes…
Even with a PtP for one minute I expect no benefit.
I have a Homey Pro 2023. When I’ve done pull-the-plug resets in the past (waiting at least 12 minutes before reconnecting), it was usually a good refresh on my Zwave network. In the couple of hours after, things are a bit unpredictable, but after that they are all working great.
Would it be a good idea to do a PTP every week?
And does it cound it I do it by connecting Homey to power via a Smart Plug and scheduling the time off? I would imagine it to have the same effect as actually pulling the plug, but wanted to double check.
There is a excellent topic [HOW TO] PtP on Homey Pro
So moved
I rarely execute PTP. I got a HP19 and a HP23. I restart the HP23 every week. Last time i did a PTP, is about a year ago. So i do not recommend a PTP every week, just a restart.
A PtP is not the way to ‘solve’ things on a regular basis.
I also almost never use PtP, unless there’s a good reason.
If you think your zwave mesh needs a regular “refresh”, something is wrong with (a) zwave (unit)(s).
And yes, cutting the power from the power unit with a smart plug, is the same as pulling the power unit from the mains outlet.
A PTP is however a way to solve various problems.
I’m and IT engineer and had to resort to ‘power reset’ all kind of devices; Like al HP Proliant refusing to accept a new IP adres on a ILO untit PtP, and frequently disconnect batteries from all kinds of laptops to get them to boot again.
And though 10 Mins. seem far fetched, I allways keep them powerless for at least 15 secs.
True, I just meant to point out when you have to reset/restart things every x hours just to keep it from erroring, you’d try to fix the real problem instead.
You’d know a linux machine for instance only has to be restarted on special occasions.
Yes I know about the IT issues and workarounds :wink:
Understood, and I agree. But Linux or any other software is not the issue in the cases I mentioned. It is hardware.
In case of the laptops, if it happens to often I’d replace the systemboard.
With the Ilo, the server just doesn’t really reboot the system, an Ilo doesn’t have a power button…
