[Tip] Problems with Homey?
When u have problems with Homey and you are reaching out to the community members here on the forums it’s important to give as much info as u can.
First of All: Homey Family members!
  • Since September 2021:
    Homey Cloud (Premium),
    and the first “old” Homey is rebranded as Homey Pro (early 201x)
  • Since Januari 2023:
    Homey Pro Early 2023 the standard.
  • Since Januari 2025:
    The Homey (service) is rebranded and now officially presented by Athom as Homey Cloud .
  • Sinds Q2 2025:
    Homey Pro mini (for US, Canada and UK only, No tile image below yet)
And while using Homey with or without a Homey Bridge on many aspects CAN be the same as the Homey Pro, they differ in capabilities and available Apps (even some Flow Options).
Some things are just different or maybe even impossible!
An overview:
So pls be clear when you ask something, but ABSOLUTELY when you report Problems, or ask about anything!
Try to mention/answer all applicable bullets below!
  • It is useless to ask here, or at Athom, IF and/or WHEN a Homey Pro app will be compatible for Homey cloud or cloud/bridge;
    Members here don’t know , and Athom almost never communicates future releases.
  • Athom (the company behind Homey) doesn’t read your posts here adressed to them. Please contact Athom support in that case.
    This is a users only forum.
Else, just continue reading please.
  • 1. What Homey model do you have, or is your Question about?
    As in the Tiles above:
    A. Homey (Cloud) - (So without the Bridge or about Cloud connected Devices)
    B. Homey Bridge - (The physical device) and/or:
    C. Homey & Homey Bridge (the combination of)
    D. Homey Pro Early 201x (all white balls 2016 - 2019)
    E. Homey Pro Early 2023 - (2023 Model)
  • 2. For Homey Pro only - firmware (fw) version.
    Please don’t say “latest” or “newest version”, because there are stable, and RC (release candidate a.k.a. experimental) versions.
    Also, the time passed between posting and reading, can result in different “current” or “newest” firmware versions.
    So please mention the complete fw version.
    You can find this in the mobile app:
    … > More > Settings > General.
  • 3. Problems with an app.
    When you have problems with an app, plz tell us which app you are using, and the version of that app.
    U can find the version in the mobile app at … > More > Apps > and select the app. The version number is on top, just under the logo.
    Also mention if it’s about test/experimental versions!
  • 4. Problems with a flow.
    When you have problems with a flow then plz share the flow(s). There would be a lot of guessing when u don’t share the flows involved.
    Saying “I just do this and that” would not help in getting ur problems solved. U can share the flow(s) in the mobile app by opening ur flow, and click the share sign at the top right.
    Copy the link and paste it in your forum post.
For Advanced flows, only screenshots are the way to share these.
  • 5. Problems with a device.
    When u have problems with a device, plz give as much info on the device as u can.
    Something like make and model, but also a weblink to the device is very helpful.
    In case of problems with Zigbee and Z-Wave devices, have the recommendations on how to create a stable network been followed?
    Creating a stable Zigbee network with Homey Pro (2016 - 2019)
    Creating a stable Zigbee network with Homey Pro (2023)
    Creating a stable Z-Wave network
    Sometimes it can be helpful to know an overview or the number of Zigbee/Z-Wave routers/repeaters and end devices (battery-operated devices). This script can be helpful for a quick overview (Homey Pro only).
  • 6. What have you already tried yourself?
    Also describe as clearly as possible (step-by-step plan) what you have already tried to solve the problem.
  • 7. And last but not least, search.
    Knipselzoek
    Try to use the search function. There is a search function on the forums, there u can find a lot of info. Am not saying the function is perfect, but when using the correct search words u can find a lot.
    Further helpful support articles can also be found on the Homey Support page.
  • Athom support
    When you think Athom only can / should solve your issue(s), or you want to request support, you can create a support request via https://homey.app/support.
P.S.
When asking for help and telling you don’t wanna use the search function because you are too lazy, it won’t help you in the amount of reactions!
A lot of peeps is willing to help u, help them by providing as much info as u can! :wink:
Known issue’s
  • General Stability due to USB Power Supply
    Probably the second weakest link of Homey Pro 201x (the white ball), is the USB Power supply delivered with the Homey.
    Although the relative number of issues could be low, many users have reported Homey restarting many times an hour and giving crinkling noises after months or years working fine, or weird zigbee issues. It could start with only restarting once a day.
    In all Cases that Homey does not keep running: Please lookup another decent (from a well known brand) USB Adapter, with 5 Volt and at least 2 A (2000 mA);
    Homey doesn’t use 2000mA but the higher rated USB adapters are usually more stable.
    In case of doubt regarding inexplicable stability problems, often with unpredicted restarts, please replace the USB Adapter. If the original Adapter is defect create a support ticked at Athom.
    No reason for using the Fast Charge, Quick Charge or Qi as Homey doesn’t use these provide power options
  • General Stability not due to Power Supply
    In some other cases the Firmware on Homey may be corrupted over time. For Example multiple Apps Fail at the same time or other generic menu’s give errors. Same Errors keep coming back also after a PtP. In that case a Full Firmware download / Recovery can sometimes be a solution. Beside creating a Support ticket you could try this: (Please also Report it to Athom Support!)
    Homey (Pro) 2016 - 2019 : For the first generation Homey’s (All White Ball) use the following article to choose in Recovery for a Full Software download. [HowTo][Pro] Restarting Homey Pro to Recovery Mode - Adv. Options From Mobile
    Homey Pro (Early 2023): use https://support.homey.app/hc/en-us/articles/7263435817116-Connecting-Homey-Pro-Early-2023-to-a-PC-Mac-with-USB to connect to USB on a Computer to select an Firmware update.
Note: Older posts (before September 2021) referring to Homey or Homey vs Homey Pro are ALL about the Homey Pro 2016 - 2019! (some say: The White Ball, die Kugel :wink: )
Thanks, and enjoy your Homey.
(btw, this is a WIKI post. Everyone (with the correct authorizations) can edit this post and add points if you like!)
Great post! I hope people will do this minimal effort and help the helpers help :slight_smile:
