[Homey Pro] overview script
Homey Pro overview script
Always wanted an overview of your current Homey?
Because you are in the process of migrating to another Homey Pro, or just for the fun of it.
Well that is what this very HomeyScript script is for.
Feel free to share your results in this thread, as I do like to see every ones Homey too! (no sensitive data is shown)
I’ve tried to make this overview script somewhat user friendly to use.
The only thing you need is an Homey Pro (any version, besides Homey (Cloud)) and the app HomeyScript.
When you have that app installed you can go to the Web GUI => Scripts and click on “New HomeyScript” on the bottom-left of the page.
A new script will get created and you can give it a name (not mandatory, just easier to find it back later on), “Homey Overview” is a good example :wink:
Then all you need to do is copy and paste the entire script linked below (it is pretty large, 782 lines) into the top field, and press the “Save” button.
Then to see the result all you have to do is press “Test”, and behold the results will show up below it (it can take a few seconds to retrieve all information from Homey Pro).
(Tip: you can increase the result’s view by dragging the “Output” line, up).
Changelog HomeyScript Overviewer:
  • v1.23 (October 6, 2026):
    • Add: Support device updates (OTA).
    • Add: Support devices updated (History).
  • v1.22 (July 20, 2026):
    • Fix: Apps disabled counter was wrong.
    • Add: Apps crashed counter (if supported).
Show older updates
  • v1.21 (July 19, 2026):
    • Fix: Some ZigBee devices don’t have a defined device type.
  • v1.20 (Februari 22, 2025):
    • Added: Last Backup date (Homey Pro 2023 and higher)
    • Added: Homey Memory
  • v1.19 (July 10, 2025):
    • Added: Group support (Homey Pro 2023/Mini)
  • v1.18 (July 15, 2024):
    • Added: Moods support for Homey Pro 2016-2019
  • v1.17 (May 21, 2024):
    • Fixed: API change
    • Added: sysInternals devices as virtual devices
    • Separated out Homey Bridge devices
  • v1.16 (May 6, 2024):
    • Fixed: New API uses zigbee vs zigBee
    • Added: Zone names
    • Added: Moods (Homey Pro (early 2023) only)
    • Added: Images (Homey Pro (early 2023) only)
  • v1.15 (October 16, 2023):
    • Added: Insight entries (boolean (yes/no) & numbers)
  • v1.14 (September 19, 2023):
    • Added: Unavailable devices (and the reason when displayed)
  • v1.13 (September 18, 2023):
    • Added: Last seen date and time for ZigBee devices, Homey Pro (early 2023) only
  • v1.12 (June 28, 2023):
    • Added: Logic (variable) names and their ID, for each type
    • Added: Node ID to Z-Wave devices’ names list
  • v1.11 (May 10, 2023):
    • Fix (virtual) infrared device(s) not being counted for Homey Pro (early 2023) (API change)
  • v1.10 (May 8, 2023):
    • Added: count and overview of apps are in the Stable or Test channel, or installed from CLI (development)/Community Appstore
  • v1.9 (April 26, 2023):
    • Fix error for the now available getAppSettings() function (since 10.0.0-rc.80)
  • v1.8 (April 9, 2023):
    • Added: App <group>'s devices to the virtual devices count
  • v1.7 (April 6, 2023):
    • Added: Storage information (disabled by default for Homey Pro (2016-2019) as it is a very slow function)
    • Added: Number of alarm clocks
    • Homey Pro (early 2023) only:
      • Added: Throttled (Homey Pro (early 2023) will throttle when a bad power supply is used or the temperature is being too high)
      • Added: Under voltage (Homey Pro (early 2023) was delivered at first with a power supply that in many cases delivered too low of a voltage.)
    • Cleaned up the code a bit
  • v1.6 (April 3 2023):
    • Fix error with counting Router and End Devices for ZigBee devices (API change) on Homey Pro (early 2023)
  • v1.5 (March 14 2023):
    • Added error information for Homey Pro (early 2023) users as HomeyScript needs an update to support the getAppSettings() function
    • Fix when no HomeyScript tokens (again)
  • v1.4 (March 11 2023):
    • Added amount of HomeyScripts
  • v1.3 (March 11 2023):
  • v1.2 (March 11 2023):
    • Added amount of: HomeyScript tokens, Better Logic Variables
    • Added some error catching if anything fails, it will continue on
  • v1.1 (March 11 2023):
    • Fixed the Z-Wave count
      I used a bad way before, now it is more accurate and includes the different security levels
    • Added Chronograph and Better Logic Library for Virtual Devices count
  • v1 (March 10 2023):
    • Initial release
Homey Pro Tagged Overview:
As the latest addition to this script (now technically 2 scripts) as the addition of a “tagged” version.
If you want to use any of the values in a flow, or just get an overview once in a while, you can use the bottom script to do so.
It has multiple options of returning the script:
  • All the possible values as an JSON Object, which will return a valid JSON (stringified), which you can then read any value from with for example the Logic flow card: “Read [TEXT] as JSON and select path [PATH] as …”
  • The overview as a regular string, where you can separate the values with a choose able separator, to for example, send it as push message to your phone
  • Set the return value (Object or string) to a HomeyScript tag
  • Set the return value (Object or String) to a Logic Variable (Text variable only)
Any given value can be enabled or disabled by setting the appropriate “show” option at the top of the script.
It is a pretty big script (805 lines), so make sure you copy over all lines!
This script can also work in the Advanced flow card: “Execute [CODE] and return a Text-tag”.
Changelog HomeyScript Tagged:
  • v1.7.1 (September 18, 2026):
    • Fix: Advanced flows not being called advanced flows in the tagged string version.
  • v1.7 (October 6, 2026):
    • Fix: Groups (object) missed the total and overview options (overwrite).
  • v1.6 (July 20, 2026):
Show older updates
  • v1.5 (July 19, 2026):
  • v1.4 (Februari 22, 2025):
  • v1.3 (July 10, 2025):
  • v1.2 (July 15, 2024):
  • v1.1 (May 21, 2024):
    • Fixed: API change
  • v1.0 (May 19, 2024):
    • Initial release
Note:
The Z-Wave count for battery and router devices can be slightly wrong to your actual real life devices, as Homey doesn’t expose what a actual router or battery device is, there is a “battery” flag but that is false for FLiRS devices like “newer” thermostats (Eurotronic Spirit or Fibaro Thermostatic).
I’ve tried to fix it as accurate as possible by also looking if there are batteries specified for the device.
But also this isn’t the case for every device like the Aeotec Siren 6, which has a battery, but that is only for backup reasons and thus pretty much always connected to the mains.
This is just the best I could do without having to manual configure every device that should be excluded, which is too much work for just an Overview Script.
Count down and/or other apps
I won’t be adding the countdown apps, there are 4 different ones, and is getting a bit too much that way.
Other apps will most likely also not be added, or in the end the script will contain all apps.
Disclaimer:
If you encounter an issue, feel free to say so and I will try to fix it as soon as possible.
Please do keep the thread clean, any non related replies will get deleted!
If you have (general) questions about HomeyScript or the used Web API, then this is not the thread for that.
Homey Pro Overview v1.23:
Homey Pro Tagged Overview v1.7.1:
My result with v1.16 running for some time now with Homey Pro (early 2023):
--------------- Homey Pro Overview v1.16 --------------
Homey name: Aurora
Homey version: v11.0.1-rc.2
Homey model: Homey Pro (Early 2023) (4 core(s))
Uptime: 8599.35 (2 hours, 23 minutes, 19 seconds)
WiFi: Connected
Ethernet: Not connected
Throttled: No (Currently: No)
Under voltage: No (Currently: No)
Update available: No
Storage: 2.66 GB (1.11 GB free)
------------------ Main ---------------------
1 Users (1 Owner, 0 Manager, 0 User, 0 Guest)
44 Apps (35 Stable, 5 Test, 4 Development/Community Appstore, 0 SDKv2, 44 SDKv3, 0 Updateable, 0 Disabled/Crashed)
40 Zones
2 Notifications (Timeline)
1406 Insight entries (716 Boolean (Yes/No), 690 Number)
58 Logic Variables (1 Boolean (Yes/No), 50 Number, 7 String (Text))
3 Flows (0 Broken, 0 Disabled)
172 Advanced flows (0 Broken, 0 Disabled)
13 Images
0 Moods
7 Alarms (2 Enabled)
22 HomeyScript scripts (2 Token/Tag)
----------------- Devices -------------------
4 Unavailable devices
0 Virtual devices
0 Infrared (database) devices
61 Z-Wave devices (61 Unsecure, 0 Secure (S0), 0 Secure (S2 Authenticated), 0 Secure (S2 Unauthenticated), 32 Router, 29 Battery, 0 Unreachable, 1 Unknown)
64 Zigbee devices (48 Router, 16 End device)
107 Other devices
232 Total devices
:white_check_mark: Script Success
:leftwards_arrow_with_hook: Returned: “Overview finished”
Nice and useful overview, thanks!
--------------- Homey Pro Overview --------------
Homey name: Homey
Homey version: 8.1.3
Homey model: Homey Pro (Early 2019) (2 core(s))
Uptime: 904206 (10 days, 11 hours, 10 minutes, 6 seconds)
Update available: None
3 Users (1 owner, 1 user(s), 1 guest(s))
30 Apps (6 SDKv2, 24 SDKv3, 6 updateable, 0 disabled/crashed)
17 Zones
1145 Notifications
26 Variables (17 boolean (yes/no), 0 number, 9 string)
5 Flows (0 broken, 0 disabled)
67 Advanced flows (0 broken, 5 disabled)
28 Z-Wave nodes (17 router, 2 battery, 1 unreachable)
16 Zigbee nodes (16 router, 0 end device)
17 Virtual devices
32 Other devices
93 Total devices
Homey name: Homey Pro van Gerner 26
Uptime: 289579 (3 days, 8 hours, 26 minutes, 19 seconds)
2 Users (1 owner, 1 manager(s), 0 user(s), 0 guest(s))
37 Apps (2 SDKv2, 35 SDKv3, 0 updateable, 0 disabled/crashed)
18 Zones
162 Notifications
27 Variables (2 boolean (yes/no), 21 number, 4 string)
69 Flows (0 broken, 8 disabled)
42 Advanced flows (0 broken, 5 disabled)
Failed: Getting HomeyScript Tokens
1 Virtual devices
51 Other devices
11 Z-Wave nodes (5 Unsecure, 0 Secure (S0), 2 Secure (S2 Authenticated), 4 Secure (S2 Unauthenticated), 6 router, 5 battery, 0 unreachable, 1 Unknown node(s))
42 Zigbee nodes (23 router, 19 end device)
105 Total devices
Ok how do you have that many notifications they should be capped at 100 :joy:
They are capped at 1 month I think, latest one is Feb 10 19:13…
No they are capped at 100 when did you last reboot Homey? Around Feb 10?
Nice!!! Thanks!
Q: About variables, I assume Better Logic and HomeyScript variables aren’t included?
A: Now they are :wink:
UPDATED v1.10
--------------- Homey Pro Overview v1.10 --------------
Homey name: 1.HomeyPro Peter
Uptime: 2787865 (32 days, 6 hours, 24 minutes, 25 seconds)
Storage: 1.64 GB (652.07 MB free)
3 Users (1 Owner, 1 Manager, 0 User, 1 Guest)
48 Apps (18 Stable, 24 Test, 6 Development/Community Appstore, 4 SDKv2, 44 SDKv3, 1 Updateable, 12 Disabled/Crashed)
App(s) that are installed via CLI or Community Appstore:
Cast a text to Google and Sonos
Broadlinkred
WebOS Plus
< Timeline Manager² >
Homey Community Store
tadoZones
SDKv2 app(s):
Marantz
PaperTrails Log
Broadlinkred
ESP Easy
51 Zones
160 Notifications (Timeline)
283 Logic Variables (40 Boolean (Yes/No), 157 Number, 86 String)
456 Flows (16 Broken, 61 Disabled)
58 Advanced flows (13 Broken, 11 Disabled)
3 Alarms (0 Enabled)
169 HomeyScript scripts (302 Token/Tag)
5 Better Logic Variables (1 Boolean (Yes/No), 1 Number, 3 String)
107 Virtual devices
0 Z-Wave devices (0 Unsecure, 0 Secure (S0), 0 Secure (S2 Authenticated), 0 Secure (S2 Unauthenticated), 0 Router, 0 Battery, 0 Unreachable, 0 Unknown)
0 Zigbee devices (0 Router, 0 End device)
163 Other devices
270 Total devices
✅ Script Success
↩️ Returned: "Overview finished"
I had 700+ flow notifications once :stuck_out_tongue:
Ah, I didn’t even think of these, but those aren’t currently included indeed, not sure how easy it would be to include this.
A didn’t even see this one :joy: that should be an easy fix (edit: fixed)
No, 10 days ago
Homey name: Home
Uptime: 529 (8 minutes, 49 seconds)
5 Users (1 owner, 0 manager(s), 1 user(s), 3 guest(s))
38 Apps (3 SDKv2, 35 SDKv3, 1 updateable, 0 disabled/crashed)
26 Zones
31 Notifications
7 Variables (3 boolean (yes/no), 3 number, 1 string)
101 Flows (1 broken, 19 disabled)
11 Advanced flows (0 broken, 1 disabled)
16 Z-Wave nodes (8 router, 0 battery, 3 unreachable)
0 Zigbee nodes (0 router, 0 end device)
6 Virtual devices
131 Other devices
153 Total devices
——————————————————— ✅ Script Success
--------------- Homey Pro Overview v1.4 --------------
Uptime: 597031 (6 days, 21 hours, 50 minutes, 31 seconds)
2 Users (1 owner, 0 manager(s), 1 user(s), 0 guest(s))
SDKv2 apps:
ABUS
NEO Coolcam
HTTP request flow cards
Updateable apps:
Disabled apps:
UnZ-Cure
MQTT Hub
MQTT Client
45 Apps (4 SDKv2, 41 SDKv3, 0 updateable, 4 disabled/crashed)
25 Zones
11 Notifications
149 Variables (54 boolean (yes/no), 90 number, 5 string)
266 Flows (6 broken, 114 disabled)
97 Advanced flows (0 broken, 20 disabled)
29 HomeyScript scripts (2 tokens)
20 Virtual devices
49 Other devices
78 Z-Wave nodes (72 Unsecure, 1 Secure (S0), 3 Secure (S2 Authenticated), 2 Secure (S2 Unauthenticated), 39 router, 39 battery, 1 unreachable, 0 Unknown node(s))
37 Zigbee nodes (19 router, 18 end device)
184 Total devices
Updated 12.03.23 with script v1.4
Lots of people have more Z-wave Node IDs then the router + battery devices (they should sum up to the same value) would indicate, and I’m curious why.
Anyone that has this willing to do some more “research”?
Please PM me or contact me on slack (caseda).
You’re right. I haven’t noticed it at all so far. I have counted and I come to 78 (without Homey). I will contact you on Slack.
Homey name: Homey
Homey model: Homey (Early 2018) (1 core(s))
Uptime: 40939 (11 hours, 22 minutes, 19 seconds)
27 Apps (6 SDKv2, 21 SDKv3, 5 updateable, 0 disabled/crashed)
17 Zones
11 Notifications
1 Variables (1 boolean (yes/no), 0 number, 0 string)
129 Flows (1 broken, 12 disabled)
7 Advanced flows (0 broken, 4 disabled)
1 Z-Wave nodes (0 router, 0 battery, 0 unreachable)
5 Zigbee nodes (1 router, 4 end device)
15 Virtual devices
1 Infrared (database) devices
44 Other devices
66 Total devices
——————————————————— :white_check_mark: Script Success
Nice to see. But I wonder; how to find the apps that are updatable?
in the top of the script there are several options you can turn on to show the names added to the overview, for updateable apps change this line:
const showUpdateableApps = false; // Names of Apps that can be updated
to
const showUpdateableApps = true; // Names of Apps that can be updated
And it will add the names to the overview of the apps that can be updated when you run (test) the script.
Interesting enough my sum of router+battery+unreachable is way less than the total amount…
yeah, i’ve probably overlooked something with the code when i wrote that part long time ago… backtracing it all right now :sweat_smile:
(Deleted devices?)
