[Tip] Problems with Homey?
When u have problems with Homey and you are reaching out to the community members here on the forums it’s important to give as much info as u can.
First of All: Homey Family members!
  • Since September 2021:
    Homey Cloud (Premium),
    and the first “old” Homey is rebranded as Homey Pro (early 201x)
  • Since Januari 2023:
    Homey Pro Early 2023 the standard.
  • Since Januari 2025:
    The Homey (service) is rebranded and now officially presented by Athom as Homey Cloud .
  • Sinds Q2 2025:
    Homey Pro mini (for US, Canada and UK only, No tile image below yet)
And while using Homey with or without a Homey Bridge on many aspects CAN be the same as the Homey Pro, they differ in capabilities and available Apps (even some Flow Options).
Some things are just different or maybe even impossible!
An overview:
So pls be clear when you ask something, but ABSOLUTELY when you report Problems, or ask about anything!
Try to mention/answer all applicable bullets below!
  • It is useless to ask here, or at Athom, IF and/or WHEN a Homey Pro app will be compatible for Homey cloud or cloud/bridge;
    Members here don’t know , and Athom almost never communicates future releases.
  • Athom (the company behind Homey) doesn’t read your posts here adressed to them. Please contact Athom support in that case.
    This is a users only forum.
Else, just continue reading please.
  • 1. What Homey model do you have, or is your Question about?
    As in the Tiles above:
    A. Homey (Cloud) - (So without the Bridge or about Cloud connected Devices)
    B. Homey Bridge - (The physical device) and/or:
    C. Homey & Homey Bridge (the combination of)
    D. Homey Pro Early 201x (all white balls 2016 - 2019)
    E. Homey Pro Early 2023 - (2023 Model)
  • 2. For Homey Pro only - firmware (fw) version.
    Please don’t say “latest” or “newest version”, because there are stable, and RC (release candidate a.k.a. experimental) versions.
    Also, the time passed between posting and reading, can result in different “current” or “newest” firmware versions.
    So please mention the complete fw version.
    You can find this in the mobile app:
    … > More > Settings > General.
  • 3. Problems with an app.
    When you have problems with an app, plz tell us which app you are using, and the version of that app.
    U can find the version in the mobile app at … > More > Apps > and select the app. The version number is on top, just under the logo.
    Also mention if it’s about test/experimental versions!
  • 4. Problems with a flow.
    When you have problems with a flow then plz share the flow(s). There would be a lot of guessing when u don’t share the flows involved.
    Saying “I just do this and that” would not help in getting ur problems solved. U can share the flow(s) in the mobile app by opening ur flow, and click the share sign at the top right.
    Copy the link and paste it in your forum post.
For Advanced flows, only screenshots are the way to share these.
  • 5. Problems with a device.
    When u have problems with a device, plz give as much info on the device as u can.
    Something like make and model, but also a weblink to the device is very helpful.
    In case of problems with Zigbee and Z-Wave devices, have the recommendations on how to create a stable network been followed?
    Creating a stable Zigbee network with Homey Pro (2016 - 2019)
    Creating a stable Zigbee network with Homey Pro (2023)
    Creating a stable Z-Wave network
    Sometimes it can be helpful to know an overview or the number of Zigbee/Z-Wave routers/repeaters and end devices (battery-operated devices). This script can be helpful for a quick overview (Homey Pro only).
  • 6. What have you already tried yourself?
    Also describe as clearly as possible (step-by-step plan) what you have already tried to solve the problem.
  • 7. And last but not least, search.
    Knipselzoek
    Try to use the search function. There is a search function on the forums, there u can find a lot of info. Am not saying the function is perfect, but when using the correct search words u can find a lot.
    Further helpful support articles can also be found on the Homey Support page.
  • Athom support
    When you think Athom only can / should solve your issue(s), or you want to request support, you can create a support request via https://homey.app/support.
P.S.
When asking for help and telling you don’t wanna use the search function because you are too lazy, it won’t help you in the amount of reactions!
A lot of peeps is willing to help u, help them by providing as much info as u can! :wink:
Known issue’s
  • General Stability due to USB Power Supply
    Probably the second weakest link of Homey Pro 201x (the white ball), is the USB Power supply delivered with the Homey.
    Although the relative number of issues could be low, many users have reported Homey restarting many times an hour and giving crinkling noises after months or years working fine, or weird zigbee issues. It could start with only restarting once a day.
    In all Cases that Homey does not keep running: Please lookup another decent (from a well known brand) USB Adapter, with 5 Volt and at least 2 A (2000 mA);
    Homey doesn’t use 2000mA but the higher rated USB adapters are usually more stable.
    In case of doubt regarding inexplicable stability problems, often with unpredicted restarts, please replace the USB Adapter. If the original Adapter is defect create a support ticked at Athom.
    No reason for using the Fast Charge, Quick Charge or Qi as Homey doesn’t use these provide power options
  • General Stability not due to Power Supply
    In some other cases the Firmware on Homey may be corrupted over time. For Example multiple Apps Fail at the same time or other generic menu’s give errors. Same Errors keep coming back also after a PtP. In that case a Full Firmware download / Recovery can sometimes be a solution. Beside creating a Support ticket you could try this: (Please also Report it to Athom Support!)
    Homey (Pro) 2016 - 2019 : For the first generation Homey’s (All White Ball) use the following article to choose in Recovery for a Full Software download. [HowTo][Pro] Restarting Homey Pro to Recovery Mode - Adv. Options From Mobile
    Homey Pro (Early 2023): use https://support.homey.app/hc/en-us/articles/7263435817116-Connecting-Homey-Pro-Early-2023-to-a-PC-Mac-with-USB to connect to USB on a Computer to select an Firmware update.
Note: Older posts (before September 2021) referring to Homey or Homey vs Homey Pro are ALL about the Homey Pro 2016 - 2019! (some say: The White Ball, die Kugel :wink: )
Thanks, and enjoy your Homey.
(btw, this is a WIKI post. Everyone (with the correct authorizations) can edit this post and add points if you like!)
Apple homekit
Connection error all the time after v 5.0.2
Homey suddenly keeps crashing
IKEA Trådfri connections to Homey
[HOW TO] Get started with Tuya cloud
Frient Electricity Meter
Flow for lights on when motion is detected has stopped working
Timed flows do not execute, most of the times
Home problem connection
Device Unavailabl
Philips Hue temporarily unavailble
Home Wizard connection lost with software update
Infinite booting and strange sounds - Homey pro
Fibaro flood sensor alarm
H6159_e6ef
Ikea Tradfri filament light issue
Geofencing update when moving house
Fibaro Walli Roller Shutter can not add in Homey
Flow Randomly stops working
Can´t get Fyrtur to pair with Homey and remote at the time
Homey Pro Performance issues
Brel top up bottem down
Aqara temp sensor problem
Problem linking Homey with Philips Hue
Latest firmware creates loads of issues
Plans for Homey Bridge to support Devolo devices
The zigbee of my homey says it is busy
Homey built-in presence detection huidige situatie
Flows stop not working
Ring snapshot
Aqara sensoren - vibration, temperatur, tür-fenster-melder,
Fakro App suddenly refused to work/disappear
Revolt Funksteckdosen einbinden
Homey Bridge chronograf áno countdown
Can't pair Broadlink RM3 Mini
Inactive zone
How to use the VThermo app with Mill
Problem with update Homey
Homey - boot loop?
Fibaro rollershutter 3 problems
Homey pro und keinen Sinn mehr
Tradfri light triggered by Tradfri app, without flow
[Request] Separate community categories for Homey Pro and Homey Bridge
Why are some apps greyed out?
Help, Homey seems to have died
Broken HUE accessoires
Google Nest cam
AliExpress temperatuur sensor Connect
Getting this error "manager.zigbee.controller startup failed"
Homey stops working
Heatit 16 A contact lost
Speech input removed in firmware 7.4.1
Velux und Somfy können nicht hinzugefügt werden
Homey frequently restarting
[APP] IKEA Trådfri - Create the right atmosphere for every mood (by Athom)
Homey Bridge seems not sending IR signal anymore after last update
Memory full
Linkind Door Sensors
Problems connecting homey app to Netatmo
Morse Push notification isn’t working (note: on iOS, by design)
Variablen werden gelöscht - HP23 - 10.2.0
Big problem homey "Heizungsplaner" heating
Homey Pro (Early 2023) goes offline
Homey pro crashes several times
Turn Samsung SmartThings air conditioning off at a certain time
Guests can edit flows?
Where is my ev (charger)
[Bug] Homey Mobile App - Add IR or 433Mhz Device needs Bridge on Pro
Shipping Status
Corrupted Backups
Homey app ios error
My Homey app lost (almost) everything!
Ikea trådfri problem
Show shutter position in symbol instead of W
Homey Pro 2023 Zigbee Issues
A message to all new Homey users
Homey Pro says ”App unavailable” for Aqara
Zigbee unstable since update to second last update
Access Homey via 4G
Homey pro going crazy
Color and brightness after using a Flow
Swap file is increasing
Rithum and Homey
Somfy TaHoma geht bei meinem Homey plötzlich nicht mehr
Samsung Smarthings
Bond bridge intigration
Homey crashing
Improved Matter Support - Homey Pro v12.7.0 is now available
Update 12.7.0 doesn’t download
Device Logs
Current Voltage Fase 1 missing?
4 and 5 Gang Zigbee Switches - Paring to Homey
FLOWS is suddenly missing in my android app
Homey pro 2023 - zwave too much traffic error?
Somfy « kit de connectivité » (new device)
NEDIS screen switch
Thermometer Windmeter
I can not program Flows in version 12.7.0
[SOLVED] Ikea app not available
Popp outdoor switch z-wave error message
Eurotronic comet z-wave
[APP] Netatmo - Same home, just smarter. (by Athom)
All my Zigbee devices do not work HP23
Saswell and Scinan Controller app disappears after installation
An error occurs when my device triggers a feature
Temperature Sensor Tuya compatible
Issues adding Gledopto 5 in 1 zigbee controller in Homey Pro
All my aqara matter contact sensors are not working!
Create an HP 2019 forum and an HP2023
You cannot connect two devices of the same type
Hohe Latenz -- Homey Pro (Early 2023) - Version 10.1.4
Slow and unreliable reactions in flows
Philips hue lamps unavailable
Zigbee RobbSmarrt
How to identify why some of my Zigbee devices are disconnecting? (Was: Odpojování)
Aqara app won’t install properly
What does it mean if I dont see all my installed apps?
Danalock Zigbee stops functioning in Homey after short while
Homey Pro crashing to red LED ring when making a backup
Spawn Enomem!
Daikin heat pumps
Homey Keeps restarting
Basic Z-Wave questions
Aeotec range extenter 7 and Zigbee "Device unavailable"
Homey pro mini "back soon"?
Google Chromecast does not work anymore?
Not working after latest update
Reverting thermostat setting after flow has run, advise needed
Mi Light/ Mi Boxer
Abus SHRM10000 Alarm Erledigt
Homey Pro 2023 continuously crashes
Weird sound from my Homy 2018
[App][Pro] MCOHome App (v1.5.4)
Homey pro 2016 can't find my devices
All apps keep crashing after update
[APP] Philips Hue - Transform the way you experience light
433mhz switch and relay
INNR - RGBW Bulb - Timeout - Asleep (?)
Push Notifications not working on Android
Homey moods with govee
Firmware 12.0.1
Plejd problem in Homey pro
Devices stuck in interview
Futurehome app states; Zigbee not found
HomeyLink showing "missing_scopes"
Homey knettert
Homey knettert
Backup plan did not auto renew?
Trying to find a good smart switch that works wirelessly
HUE and Matter, bug?
Homey goes offline after electric shut down
Homey Insights shows the wrong values, too low
What is the Add Scene on the app?
Homey location incorrect
Homey not detecting if I turn on a switch or light outside of the Homey app
Zigbee light devices problem
I’ve problem with connecting Fibaro z-wave plus to the homey bridge
Aqara app
Appairage new Sonoff Zigbee
To many 433 mhz commands
Nexa is temporarily unavailable, it will be back shortly
Defekte Flows Kennzeichnung
Humidity stopped reporting
My Homey does this now
Trigger "Every xxx Minutes" does not work with variables (in HP2023 <= FW 10.0.9)
Bosch-Siemens Home Connect - connection issues
Great post! I hope people will do this minimal effort and help the helpers help :slight_smile:
