Welcome to the forum!
Hi!
Welcome to our Forum, we’re glad you found us!
On this Forum you can discuss everything regarding Homey and Athom. This forum is for everyone, independent of your knowledge and experience with our products. I thought it would be a good idea to set some guidelines so we’re all getting the most out of this medium.
Here we go:
  1. Please stay on-topic.
  2. Please use a meaningful title for your thread.
  3. Search for your topic ideas on the forum to see if somebody else already mentioned it somewhere.
  4. If you have a question, please first browse the Knowledge Base to see if you can find your answer there.
  5. Always be polite and give constructive feedback. There are real people behind a username.
  6. Keep the conversation in English, except for the localized subforums.
  7. Please use only one language per topic.
  8. Don’t reply to your own posts in the same topic but edit your previous post.
  9. If you want the moderations to read along, mention @Caseda, @Dijker, @johan_bendz, @Jamie, @OH2TH
  10. If you need support from Athom or find an issue related to Homey, the smartphone or the web app, please visit Support | Homey.
  11. If you are a developer and found a bug, please create an issue on GitHub. There are issue trackers available for the Apps SDK and the Web API.
  12. If you are looking for an app, the quickest way to check whether a device is supported, is to search the app store Homey Apps.
For some Infrared, Zigbee, Z-Wave, Matter or Thread devices no extra app is needed.
  1. If you have questions about a community app or want to report a bug, please use the appropriate topic, the developer platform (e.g. GitHub, Bitbucket) or contact the app developer. Links can be found in the App Store, otherwise please search for an appropriate topic in the forum.
  2. If you are looking for someone to create a new community app, there is a Homey Community App Requests topic where you can make your request.
If you are missing a supported brand on Homey and/or Homey Pro, then visit the request page Request A Brand.
And most of all, have fun and be kind. Only together can we make smart home better!
KlikAanKlikUit AWMT-003 not able to pair to Homey
Homey 2.0.0 Experimental discussie [NL]
Alfred Smart Lock
To many 433 mhz commands
Melinera led christmas lights
Homey Pro Backups (voorheen Homey+) abonnement
Honeywell hr92 battery status
Ik probeer mijn Honeywell t serie aansluiten
Multi bridge senic
Créer une application pour ambivision pro
Homey Pro 2019 led ring not working properly
Homey App connecting to Homey animation
Login issue Somfy TaHoma Connexoon
Carbon CFK Kohlefaser schneiden bohren 2,5 mm 6 mmm
Inloggen op Homey Community Store
Sécurisation tablette
Manque de l'Echo Dot Gen 5 dans l'application Amazon Alexapp
Anzeige Shelly 3EM in einer Kachel
Backup van Homey en Flows
Extending zwave with Homey Bridge with HP23
Homey löschen
APP Request: TTLock OEM Smart lock provider
Homey bridge apps future
Homey bridge verliest verbinding met Ikea Zigbee Devices
[Czech][Device] Žárovky EMOS SMART LED E27 RGB i E14 RGB zigbee
Button+: a new display/switch device
Namron thermostat 4512759
NTC Sensors not working on Heatit z-relay
Mobilephone as device
Foscam t5 ep
I’ve problem with connecting Fibaro z-wave plus to the homey bridge
Verschil berekenen tussen twee numerieke variabelen
Tuya zigbee curtain motor no action
Can 2 users activate a flow using Google Assistent
Ikea e1743 dimmer schakelaar
Homey shutdown after boot/stuck on boot up
Homey Pro - model 'Early 2023' (NL)
Benachrichtigung bei Bewegung
TP-Link Kasa HS220 Will not discover
Fibaro Roller Shuttler 2 FGR 222 EU 2.5 lässt sich nicht integrieren
Tuya app (official) accepteer mijn login niet (meer)
Getting my smart home started. How is Homey Pro’s device compatibility, and with Homekit? Should I buy Homey Pro?
X-Sense App
Homey Pro 2023 i.c.m. Tuya app lijkt op een No-Go
Cannot edit or add flows in iOS-Homey-app
Wie helpt?
Unifi G4 Doorbell Pro en Nest hub Max
Aquara FP2
Nuki devices (locks) suddenly offline since 2/4/2024
[App][Pro] Bibliotheek.be (Testers Wanted)
Dali dim
Uitspraken Google hub 2e generatie
Totaal de weg kwijt
Homey app crashes after adding big speakers widget to dashboard
Device Unavailabl
Update homey blijft op 0 %
Smarte Pumpen-Steuerung für Gartenbrunnen?
Ein paar Einsteigerfragen
Niko ZigBee batterij 2 knoppen led lamp
Flow för tända/släcka lampa
Philips hue dymera
Compatibilité Eltako serie 14 (Enocean)
Error homey a britge whit this dereal dosen't exist
Ikea Tradfri filament light issue
Zigbee rookmelder werkt niet naar behoren
Oude bridge wil niet resetten
Missing Insights since power outage
yale ymzb-100
Kan iemand mij helpen hoe ik met Homey Pro 2019 een Bluetooth apparaat Duux Threesixty moet koppelen ik krijg namelijk geen koppelkode terug op mijn mail
Delivery issues
Homey Pro 2023 Zigbee Problemen
Peblar App
Flows werken op de app maar niet live
Support for Palazetti Cbox
Flows: Mehrfachbelegung der Tasten Ikea Symphonisk FB
Hue contact sensor window/door
Flow Und-Verknüpfung: Helligkeit "Wird weniger"warum nicht "Ist weniger"
[APP] Fibaro - Your home is your castle (by Athom)
Shelly 2PM und Statusmeldungen Oben/Unten im Homey Pro
Nuova dashboard Homey Pro (Early 2023)
Aqara compatibility
Nybörjare tända och släcka
Be helpfully and friendly
Support and flows for air monitors from IQAIR (outdoor and indoor stations)
Status.could not find zigbee shepherd device
Timethinker smart WiFi sockets
Wrong Username shown after homey-login
Trouble pairing the Aeotec Smart Switches in Australia
2FA - Two Factor Authentication?
Different user priority?
Misplaced buttons in iOS app
Insight graphs
Homey?
When wil there a be a Toon app that works?
Problemen met scherm Google Home Nest Hub 2
Homey pro hangs
Where do we put up feature requests now?
Considering Vera Migration
Smartphone v2app extra usermode button
Homey Pro with Z-Wave plus 916mhz support
Dashboard iPad homey
Language for the community
Firmware 2.0
Support for ORCON MVS15 fan
"Find my location automatically"
Downgrade Homey
Shipping to Russia is not an option in the Online Shop from Athom
Zigbee Range with Innr smartplug SP-120
Backup, Restore and Migrate functions for Homey
Can't add a new family member Homey v2
Taal foutjes in de Android Homey app doorgeven
Display and compare MULTIPLE gradients in ONE Insight graph
Have a desktop account on another destination
Tesy smart boiler
Gestion production solaire
Homey Hub, Staff, app developers and Community Moderators. Thank you
WATER LEVEL SENSOR 2020 - List and yours !?
Vision shock sensor VIS_ZS5101
Presence is not working
Hue na koppeling aan Homey weer koppelen aan hue bridge lukt niet
The light is on as long as there is movement in the room with a motion sensor
Adding aeotec siren 6 to homey
Se connecter
Please help a new user of Homey
Flow history addition
Wie kontaktiere ich Athom und oder App Entwickler
Fibaro rollerShutter3 - better support for venetian blinds - position/angle of the slats
Hue sensor instellen
Ethernet (LAN) Adapter
POPP smoke POPE004001
Homey insights and backup errors!
Mise en marche homey
Acces code to download the invoice cloud backup
Installieren von Apps nicht mehr möglich
Ikea push button
Homey v3.2.1-rc.10 experimental ist online
What is going on Athom?
TV Lautstärke einstellen
Appareil Enocean
Radiateur sauter
Homewizard App
Transferring Nanoleaf connections from app to Homey's Matter network
Homey Pro: fighting with Aqara Water sensor & Innr plugs
Solaredge foutmelding
Chauffage au sol
Can't find energy meter gen5 in Aeotec-app for my homey
Can we have a real Homey Pro please
No more device available
Wallmote Quad battery showing zero %
Revolt Funksteckdosen einbinden
Enocean Unterstützung von Homey Proi
Water cooker and Innr 120 smart plug
Backup: Make it possible to store/lock a "Master Backup" for later use
Two owners (eigenaar) in Family
WOOX wifi smart plugs & smart bulbs
Do Athom even care?
[APP][Pro] Alexa - Control your Amazon devices from Homey
Smart Module de Fibaro (FGS-214)
Ideen / Funktionsanfrage (Neue Info 2021)
Autoback-up broke with last RC 58
Aqua temp divice error
Android homey app opstart tablad
Homey niet bereikbaar in de ochtend, enorme moeite om wifi te verbinden via setup
Missing_scopes when updated to rc50
Wat zeggen deze foutmeldingen na update Google Chromecast 5.1.0
Apaga app?
Smartwares SH8-99103 not listed
Eufy clean vs eufy security
Connection error all the time after v 5.0.2
Read a value from the knx light sensor
Help! Trouble adding a new user
Muziek afspelen verschillende sonsos boxen
Homey beta
Security concerns continued
Backup restore met zichtbare backups
Homey Bridge...trouble..trouble with Aqara
Switch Homey automatically
Aqara deurbel toevoegen
Heimdall flow
Bold smart lock doesnt work
Enphase Battery
Connecting to eufy app
Enphase Enlighten Uitschakelen bij negatieve stroom prijs
Coqon DThermz5 ( Danfoss RS-Z or Devolo) z-wave
Homey energie dongel leest de gasstand niet
Suggestion button on/off in app
Get query to my ecoflow River Pro
Tuya ball valve
Send raw pronto hex IR commando's (new feature)
Velux und Somfy können nicht hinzugefügt werden
Extra decimals for sensor in virtual device
Keine Bluetooth Verbindung zur Home Bridge
Govee Stehlampe Pro Über Spotify Musik hören
Klik aan, klik uit spots in de slaapkamer
Tuiss awning motor, Swedish brand
Three Cerbo GX mk2 and Homey Pro (and Victron Energy app)
Pricing
Homewizard p1 app stopt regelmatig
Gledopto driver reageert niet
Aqara light switch, cant connect
Alle klik aan klik uit apparaten zijn verdwenen
Meross Mss210 Smart plugs
Download Apps
Homey Pro 2019 Device - Displays the Yellow ring and turns off
Widget icon size in dashboards
Tips for large Z-Wave/Zigbee networks on Homey Pro
[APP][Pro] Homewizard 🧙‍♂️
Homey Bridge doesn't recognize Aqara door sensors
[APP] Trust Smart Home (Dutch: KlikAan KlikUit) by Athom
Tahoma Somfy app: Timeout of 10000ms exceeded. Error: Aborted. Inloggen niet gelukt
Why is Homey Forum so hostile?
[HomeKit Controller] Aqara FP2 - Multi-presence detection
Self hosted server to Apple Homekit
Opladen batterij auto icm batterijen van homewizzard
Google nest stuurt geen apparaten aan
Unifi network
Mes Flows ne démarent pas HELP svp, Any/All pas de différence?
Mercedes Me integration?
About to give up on Homey Pro
Newbie question - how to contact developers?
Nieuwbouwhuis
[Bug] Fahrenheit conversion - was: Why is it 828° F outside?
Cannot read property 'scale' of undefined
[APP][Pro] Ubiquiti UniFi Protect
[Bug] Wrong translation for "temperature" in thermostat flow card
Herschel California 2000 IR-heater
Is there already a app for screentronic?
No consigo hacer flow con alexa
Advanced-flow?
Detectieschakelaar Aqara FP1
Musik.
Sound system
NEXA WTH-103, Thermometer/Hygrometer
LG acquires Athom
Homey Pro et Raccourcis Apple
Notificaties (Ring-beveiliging) overnemen in webhook
Homey Pro Apps / Technologies / Matter ( ! missing ! )
[APP][Pro] Sensibo - Air Conditioning and Quality
Verbindung zu Amazon Echo unterbrochen
To lokasjoner med Homey bridge
Btcino netatmo
Problemen starten flow via Google assistent
Adding Tuya/SmartLife
Einfache Zeitschaltung mit Denkfehler?
Problem adding a Fibaro double relay switch FGS-221
New house making smarter
Aqara motion sensor wil niet connecten
Linkind Door Sensors
Connect aqara single rocker (no neutral) H1 switch to homey pro
How about a category for AI related stuff
Homey Bridge not connected
Wat gaat er hier niet goed
Homey pro 2019 lumière orange fixe or connexion
ROBB SMARRT Draadloze Z-wave Schakelaar 8 knoppen, zowel enkel als langduring indrukken?
Bester Door/Window Sensor
Installing Philips Hue Wall Switch Module with a Double Switch and a Single Switch in a Three-Way Setup.
Optimalisatie verbruik en teruglevering SolarEdge systeem
I have a Bridge and have just bought / ordered a Pro
Defective Homey Pro after Two months - Amazon restocking fee to return
14 Days of Silence – Homey Pro Breathing Red, No Support at All
Aqua Temp pool heater
[APP][Pro] Midea - Midea HVAC Solutions - Smart climate controls
Trage Homewizard apparaten
Bei der Alarm App gibt es offensichtlich das Problem, dass diese nicht zuverlässig auslöst
Homebase 380 gaat op rood om de 3 dagen
Waarom werkt de Tesla app in Homey niet meer
AI kamera do HOMEY
Na reset Homey Pro blijven oude flows werken
Nanoleaf Essentials GU10 (NL54U000) + Homey Pro (Matter/Thread) – Tips, Issues & What Finally Worked
OTV/ZAVírač zámku do HOMEY
Bathroom motion flow help
[APP][PRO&CLOUD][OFFICIAL] Growatt
Blurams webcan
Como puedo volcar todos mis dispositivos shelly al homey pro, que tengo unos 20 dispositivos
24 kanaal zigbee relais box
Z-wave reset counters (Rx, Tx)
Bold en eufy deurbel
Hjälp med enkla knappar till Homey Pro
Heatit Z-smoke detector flows
Premium contract laat niet toe om Power by the Hour app te installeren. Klopt dat? En zo ja is er een alternatief om toch te schakelen op day ahead prijzen
IOS app loosing connection to Homey and repeatedly reconnecting
I have this advanced flow to random turn on or off my lights at home while i am away from home
[APP][Pro] AMBEO Soundbar - Bring immersive AMBEO sound into your Homey smart home
Connecting Save Connect to Homey
API toegang Homewizard plugin batterij
Flow voor starten apparaten bij teruglevering aan net
[APP][Pro] Tuya Zigbee App
Security and BackDoor
Auto enable a flow
How to add solar panels (enphase) in homey app
Philio app: Devolo‑badged Philio devices pair as “Unknown Z‑Wave Device”
Homey pro crashes several times
Homey energy dongle triggers
Homey Energy Dongel Reset
How to set separated autocomplete listener for each 2 devices?
Where is my ev (charger)
Régulation radiateurs électriques
Z-wave issues
Homewizard energy as solar panel
Fibaro Dimmer 2 not working properly with Homey BUT working with HomeCenter2
Homey en apart Zigbee netwerk?
[APP][Pro] Mitsubishi WF-RAC - Cooling, heating and ventilation
Hulp homey linken aan electriciteitskast
Homey Pro connecten met homepod Mini
WTW Zehnder whr 950 afzuiging slim maken
HomeWizzard app not responding/installing
Unifi protect ondersteuning
Bewegingssensor flow vraag
Intégration de TIS smarthome filaire
Whatsapp
Help needed for retrofitting a floor lamp with LED lights
Homewizard Energy Display
My Homey 2019, Have lost all zigbee
Google connect issues
Change of software from 3.6.6 to 12.4.2: all kind of changes in flows?
Broadlink rm pro +
Shipping Status
Keine Tuya Geräte mehr
Codes for door locks
Changan Deepal
Can’t connect matter bridge app to Apple home app
Die Entwicklung der Homematic App soll fortgeführt werden!
MyStrom WRS1 LED Strip Controller
Alexa ne fonctionne plus
[APP][Pro] Balboa
Updating Zigbee/Thread devices
Aqara Cube T1 Pro Not Responding in Homey Pro
Zigbee failure
Homey app loopt vast
[APP][Pro] EasyLighting - Make smart home easy
[APP][Pro] SolarEdge + Growatt TCP modbus
Sonos TunIn Radiosender abspielen
Vallhorn/Hue
Shelly wave 2pm koppelen lukt niet
Help with Flow Request
Netatmo Presence aktivieren
Device Groups Homey
Fasebelasting melding uitzetten
Transfer from Futurehome to Homey Pro
Self-Hosted Server local web login
Homey Pro (Early 2023) - communiceert via Wifi in plaats van LAN
Homey Pro (Early 2023) - LED Ring ademt ROOD — Homey Pro has crashed
[APP][Pro] Weather from Yr.no
[APP][Pro] SESSY Thuisbatterij (NL)
SolarEdge & Zonnepanelen - Flood of Errors
Update 12.4.9 --> Thread issues?
Can a device appear in multiple zones?
Homey pro Tagebuch
Zigbee network unavailable
TimeZone in the Miboxer app
Shelly display
Kaart Datum en Tijd: Vandaag is XDag > Morgen is XDag? + Van datum X tot datum Y
You can only add 5 devices before you need a subscription
Properties of devices
Blij of niet?
E-mail verification Ikea dirigera - home smart app
Homey Bridge - Serial Doesnt Existing
Actuele waarde uit apparaat halen
Ik krijg een ERR_SSL_VERSION_OR_CIPHER_MISMATCH als ik via de laptop wil verbinden
Samsung Smarthings
[APP][Pro][NL] Homewizard 🧙‍♂️
Peblar App
Acm-250-ld
What controller to use
Aanwezigheids detectie geeft timeout
Geen verbinding te maken met Matter/Thread Homey Pro 2023
Nodon SIN-2-FP-00 Enocean
Einbindung Fronius Wattpilot Homey Pro 2026 / Shelly Ecowitt WS90
Unifi protect Cameras
Can the Homey gateway connect with the Tuya brand’s app or products?"
Small logic card issue in Homey Pro 2023
Flows werden des öfteren gar nicht oder nur zum Teil ausgeführt
EWE , Shelly and Smarthings
Anzeige für offene Fenster
Haushaltsumzug und Neueinrichtung Homey pro
4 and 5 Gang Zigbee Switches - Paring to Homey
Supla ZAMEL LIW-01
Common flow
Google Home dubbele apparaten
Pir styring av lys
Hulp gevraagd thuisaccu, laadpaal en zonnepanelen efficiënt aansturen
Schema hervatten tado x
Some of my Zigbee lights self-activate during the night
Ist es mittlerweile möglich Homematic IP in Homey zu installieren
[App][Pro] Nefit Easy
No consigo enlazar camare seguridad eufy soloCam e42 en Homey Pro
Futurehome HAN
Water, time and gas Usage measuring
Homey pro of losse apps vanwege familie?
Waarden uit een TAG naar een zelf aangemaakte variabele kopiëren of overzetten
Er is een fout opgetreden
Can't connect hue tab dial switch to homey bridge
Z-Wave ZWP Model WD-100 Light Dimmer profile
Nieuwe HUE bridge 2025
Philips HUE Tap Dial flow (advance)
TCP Smart
Generic Info before purchasing HomeyPro
Shelly Pro 3EM false energy readings
Vale TV05-ZG ZigBee Thermostat
LG TVs
Automatische raam opener
Motionmounter
Shelly button only working when USB attached
ALARM - UTP - Motion Sensors en Magnetische Raamcontacten verbinden met Homey
Can't find the Tibber App in flows
De zon gaat onder over…."X" min
Kostal Inverter stop discharge battery
Hoe kan ik mijn backup abonnement stoppen?
Enphase zonnepanelen toevoegen
Python Virtual Home Assistent
Extend the Philips Hue setup with IKEA kitchen Tradfri
Eglo remote controller 2.0
Version 12.7.0 broke my system
Homey pro und App Gruppe
Sunricher CCT remote dimmer switch not recognised by Homey
Homey ist offline trotz Regenbogen Ring
Heeft Homey Pro 2023 een afwezigheidsstand?
Shelly 2PM geeft maar één schakelknop weer bij het openen in de Homey app
New member from the USA, Anyone else here?
KNX Sensor (Door/Window & Motion)
Sonos devices not found on install
Hoe kan je een variabele tijd ingeven om een actie te starten (tijd x om vaatwasser te starten)
Hulp bij toevoegen lampen
New Philips Hue lamps not appearing in HP23
Network error - write your experience
I want to be a Homy Pro user
Grid with large tiles on iPad?
Smarte Beleuchtung bzw. Schalter
Making the phone go into alarm when the firealarms go off
Accepting invitation not working, Homey-Offline message
Deltaco Power stripe tuya not working
Flow - Leistung befindet sich zwischen 2 Werten
Connecting new Aqara water leak sensor T1 model WL-S02D to Homey
Wifi
Ring Doorbell flow does not work
LED Glühbirnen hinter smart Plug
Apparaat toevoegen aan Ledvance Smart +
TypeError: Cannot convert null value to object
Homey Pro Komt niet meer online
Schaal in grafiek (app)
Homey app maakt geen contact meer
"Homey Bridge, borderline unusable product."
Farys (Sagemcom) watermeter uitlezen via de Homey Energy Dongle
Issues adding Gledopto 5 in 1 zigbee controller in Homey Pro
Flow voor boiler aan/uit op basis van PV
Does NEXA WMR-1000 work on Athom Homey?
Improved way to see Battery status
Homey kein Pro mit Shelly TRV verbinden oder alternative
Same device in two different "Rooms"
Dynamische prijzen van morgen niet zichtbaar in energie tab
Netatmo doorbell doesn’t trigger flows anymore
Issue pairing a new Zigbee device (Lixee power meter)
How long should it take for Homey Bridge to complete setup
Heatit Z-TRM3 connection problems
Cannot detect Alexa Echo dot (Gen4)
How to reset P1 meter
Aqara video doorbell G4 not supported
Sonos and light in bathroom
Foutje homewizard
User information not passed to flow, depending on how the flow is started
Homey Pro in Thailand
Und noch ein neuer User mit Problemen
Marstek venus v3
Where and how to execute enableRX() klikaanklikuit
Best light switches for homey pro
Homey kan Bold startlock niet vinden
Welke Aqaura hub het beste om ook zigabee algemeen te versterken
Anzeige Kategorien in iOS App
New Homey Pro 2023 - Google Home Problems
Strømkontroll uten tibber
Ratio laadpaal
Tuya 8 inch Control display
Z-temp2 thermostat flows
problem with heating flow
What solution for a long house?
Homey pro 2023, response_timeout when adding Z-wave devices
Setup Homey Bridge fails after the install updates part
Fenster als Objekt in Homey erstellen mit mehreren Sensoren
How to identify why some of my Zigbee devices are disconnecting? (Was: Odpojování)
[App][Pro] X-Sense - Ultimate home safety with X-Sense smart devices
Namron bulbs keep loosing connection
ZOOZ ZSE29 Outdoor Motion Sensor
Switch to Homey with Eve Degree/Weather devices?
Flow keeps sending messages
MQTT Client - payload wordt niet opgeslagen in variabele
Innr Smart Spot GU10
Google home speaker to say something Homey?
Homey en Hoftronic
Wenn Gerät an, dann Regel aktivieren
iPad an der Wand mit Push aktivieren - aber nicht immer
Breakdown
Ik wil mijn prinium abbonnement opozeggen , hoe doe ik dat!
Leak Smart system compatibility
Strømpris med homey bridge
Zigbee apparaat heeft netwerk verlaten (Aqara T1)
Dubbele Schakelaar Zigbee inbouw Tuya
Figaro Roller Shutter 2 - Problème
Cant connect the Cleverio CSP-100 mini smart plug to homey
Lumisky Bobby (decoratieve led lampen op accu voor in de tuin of vijver)
Keeping time without internet connection
Overzicht Energie
Homey energy dongle en Ratio solar
Moes wired Gateway for HomeKit and Moes dimmer switch
Different behaviour for a flow
Homey Pro 23: Nicht erreichbar per App - aber erreichbar per Cloud?
Bold
Controlling Sonoff 4Ch Pro in Homey
Pro NEO NAS-PS09B Zigbee
Which Dominique box
Tellur remote IR
Add hold (favourite position) on Brel bi-directional
Activate Homey Pro
INNR app is sinds de laaste update verdwenen; opgelost via leverancier
Heatit z-temp3 regeling elektrische verwarming
Aldes connect
Unable to install apps on Homey Pro 2023
Fehlfunktion Doppelschalter der Firma Teslasmart in Homey
Do I need 2 flows to switch something off at 11pm and on at 7am?
Home Assistant Devices Show Offline
Led strip lidl met homey
Aqara humidity sensor T1
Skoda Citigo
Welcome Home from Sonos (Flow)
Homey Bridge Not Connected and blue ring is blinking
Popp Zwischenstecker Kindersicherung
Aplicacion POWER BY THE HOUR
Ecolink Garage Door Tilt Sensor
Can't login Smart Life
Ezviz app smart
Adding Nexa power plug PER-1500 (433 MHz) to Homey
Ikea hub
Advanced flow for lights
Push notificatie gaat fout
Ring Camera / Doorbell not working in flows (motion detection)
Support for Aqara Presence Sensor FP2 in the Aqara app for Homey Pro
Serial number invalid
Aqara single switch T1 that can't connect to Homey
Passecode and/or hide flows and devices
Slimme wasmachine
(Favorite) Devices as a widget
Questions before getting a Homey - Regarding Sonos, Hue, Modes and RF433
Considering moving from Hubitat to Homey Pro
Engo smart Engo thermostat zigbee
Geen beweging licht uit na 10 minuten
Brel hub usb
Zigbee Unavailable regularly
Adding Leviton Wifi Outlets to Homey Pro
Lamp dimmen met aan uitschakeling
Tuya smart life
[FeatureRequest] Possibility to hide devices
Nouvelle application smart life
Homey Pro Unterputz-Schalter für elektronische Rolläden
Symbol neben Text für Flows
Wrong battery type
Lidl E27 light
Alfen Charger – ondersteuning voor Duo laadpalen toegevoegd
Rolluiken openen/sluiten en ook stoppen tijdens beweging
Zonneplan Charge gewenste einddatum
Jaloezieen Slim maken
ATAG ONE plus BCU module
Dreame l20 ultra vacuum cleaner
Steuerung der SonnenBatterie über Time of Use (ToU)
Opwaarderen van Homey (Early 2019) naar Homey pro
User Name has changed
Fibaro Dimmer für Schaltkasten?
Entering Setup Mode to change Wi-Fi to ethernet
Battery level aqara roller shade driver E1
2e SolarEdge omvormer koppelen lukt niet
Homey compatibility
Occupancy Sensor OS11
W'eau Mini inverter plus warmtepomp zwembad
Tuya Cloud please configure app first
Tesla app - Dog mode
Trying to retur my unopen homey bridge
Homey randomly reboots
Homeyduino: unable to add device to homey
Temperature in C instead of F
Unifi UDM Pro/account koppelen
Flows not in widgets (iphone) anymore
Anyone else that use the "Quad Vena integrated amplifier" app?
Geofence range setting
Tado verlangt Benutzer-Code?
Yale Doorman Classic med Yale plugg och eller Verisure Plugg
Homey 2 way light switches are too slow
Is it possible to connect a RAIS Fire gas fireplace to Homey Pro?
Centralised Log of all Device Activites
Tapo P110M, doesn't show power
Niko enkelvoudige geconnecteerde schakelaar verbinden met homey
[Eufy] Deurbel gezicht herkenning
Z-wave on Fibaro non-responsive/extremely slow after Homey Pro 11.0.0 update
Integration of Jung Home | Bluetooth Mesh System
[APP][Pro] Eufy Security
LED ring permanent rood
Shelly wave 2pm wird von der App automatisch abgestellt
[APP] Zooz - Let's build smarter tech together
KNX multiple status addresses
After homey update, all Tradfri devices are temporarily unavailable
Group app, add devices
Eufy cam as sensor to turn on hue light
Ewelink Doesn’t Work
Lost Connectivity
Considering switch from Hubitat - Yoolax supported?
Somfy RTS error flag
Tesla laden met Tesla Wall Connector
APIR-2150 blijft in bewegingsalarm stand staan
Blinking white light
Groups Plugin not working anymore, how create light groups now
Dyson HP1 Hot & Cool Purifier
Reviewing Diagnostic Report BEFORE SENDING
Aeotec Button
PEHA dimmer (schakelaar & 1-10V) vervanger naar draadloos
Replace Device old to new
Add a “Family Member” function is not working! Any help please?
Centrale Ventilatie (CVE) op basis van luchtvochtigheid
Vragen over eerste stappen met de homey pro
Kidde Smoke Detectors with Air Quality monitoring
Anker Solix Solarbank Support
Roborock zeo one Washer in ROBOROCK app?
Can't get Aqara or Better Lights to install
App for Sunseeker Robotic Lawn Mowers (Meec, Brucke, Tokmanni, Scheppach, Orbex, Practixx, Adano)?
Training AI for Eufy S380 and the e220 pan & tilt Cams
Screen niet naar beneden bij open deur
Unsupported device list (in app report broken)
Problem with the variables from the homey device itself. It saves automatically
Moeten wij ons zorgen maken - Athom sluit aan bij LG Electronics
Sonoff ZBMINIR2 support in Homey Pro 2023 or Homey Bridge 2023
Node Red: A widget based dashboard working with Homey trough MQTT
[APP] Ring - Home Security & Video Doorbells (by Athom)
Slow to respond to device changes and cant discover new devices with Alexa
[APP] Ecobee - Smart thermostats that harmonise energy savings and home comfort
Laatste update
Futurehome app states; Zigbee not found
Change WiFi and now is all deleted!
Heimdall - Let Homey watch over your home
Daikin aico pairen met Homey pro
Att styra enheter via homey bridge
Best Practices for Automations
HomeyLink showing "missing_scopes"
Homey pro auf destop
Oude homey verwijderen
Cancel a Flow from finishing?
Bold smartlock
Flow maken
Ring Doorbell, Camera and Alarm support for Homey
The key argument must be of type string or an instance of ArrayBuffer, Buffer, TypedArray
Retour sturen
Meross Garage Door Opener times out
Help with the Telegram app
Any ideas about the Smoke Detector Flow?
Homematic ip installeren
Ugreen Nas
Philips hue 404 error
Doubled entries in Google Home or Alexa
Homewizard Energie Display
Wiser home / Wiser Gateway 2.gen
Cannot add Shelly H&T Gen 3 to Homey Pro
Home Center 3
Recuperar mi homey pro eliminado de la aplicacion
[APP][Pro] WhatsApp - Simple. Reliable. Private
Out of the box Sunrise and Sunset flowcards
Programatically change the device icon on the homey dashboard
Hue sensor
Wat nodig om de p1 meter uit te lezen
Bug found in camera widget
Sonos flow
Sonoff POWR320D
[BUG] TP-Link Kasa devices get "rate limited" error every day
Comment relier un ruban led Lepro s1 sur homey
Flow does not work
Firmware Update bei Matter Geräten
Homey Pro cloud desync – devices missing in web app, local app works
Homey Pro 2019 et matter
The latest Docker image tag points to v12.11.0 instead of v12.11.1
Newbie problems with Pro 2026
Aqara curtain driver E1
Shelly 2PM – Homey erkennt nur „Single Push“, Long / Double Push funktionieren nicht
Ghost Tado thermostat is auto enabling it self, how to debug?
Flow voor Homewizard P1 meter
Ik heb zonnepanelen en een batterij van Huawei
Daikin naventileren bij uit
Philips 65OLED850/12
Ring Gen 2 internal Camera no live view and not truning on lights
Server Registration fails ... Hunter - Hydrawise
[APP][Pro] Solis Cloud Inverter - Receive realtime data from your Solis Inverter
[APP][Pro] Homematic App - Connect Homematic with Homey
Multiple SHS's - How to delete
Ring status "doorbell" and "all alarms" cannot be selected anymore
Developer needed: Homey Pro driver for Airzone Aidoo Z-Wave Plus (AZAI6ZWXDA1)
[APP] Miele - Immer Besser - by Miele & Cie. KG
Miele Geräte - Waschmaschine, Spülmaschine - aus, aber keine Push und ein bisschen Tesla Tageskilometer / Fahrtenbuch
Adding two text-format time values
Problems with firmware 13.3.0 / 13.4.0-RC.1
Crash
Curtain
Deutsch /Englisch
Thirdreality R3 not updating Presence Alarm
Homey GPS
MELCloud app upgrade 45.4.0 - authenticatie probleem
Integrating multitap, long press and combined taps for Senic/Gira Friends of Hue Switch in Homey
aërQ voor mechanische ventilatie badkamer
Becoming part of the Homey movement!
Can Homey learn IR codes?
Ios ios
Paid apps
Danfoss Ally - devices stop responding
Flexit home ventilation system
Daikin Onecta App und BiZonen Kit
Appairage new Sonoff Zigbee
App for McCulloch automower
Homey V5 (Discussion about v5 before it was released to stable)
Troubleshooting Homey Flow Trigger Card with New Wallbox Capability Values
