Ring Doorbell, Camera and Alarm support for Homey
This app lets you add Ring Doorbell, Camera and Alarm devices to Homey.
This topic is for Ring Doorbell, Camera and Alarm devices support, if you are looking for information or support for connecting the Ring Alarm devices to your Homey as stand alone Z-Wave devices please visit the Ring Security - Extend Heimdall with Ring Security products topic.
Support is not limited to the below shown devices, all versions within the mentioned categories can be used with the Ring App, there is however, no guarantee that all functionalities on all devices is supported.
Any Ring Doorbell
Any Ring Chime
Any Ring Camera
Any Ring Intercom
These devices require a Ring Alarm System
Any Ring Contact Sensor
Any Ring Motion Detector
Any Ring Keypad
Support for other Ring Alarm System devices will follow, no ETA will be given
How to use the app
After installing the Ring app on Homey add a Ring device. While adding the device you will need to logon with your Ring Account. When successfully authenticated your available devices will be shown. Pick the device you want to use in Homey.
Multi-Factor Authentication (MFA) must be enabled on your Ring account!
Supported languages
Translations were done using ChatGPT, please inform me of any errors on Github
:uk: English
:netherlands: Dutch
:denmark: Danish
:fr: French
:de: German
:it: Italian
:norway: Norwegian
:es: Spanish
:sweden: Swedish
Links
If you want to support this app, please consider a donation
ko-fi
Donations are very welcome, though they come with no guarantees, warranties, or preferential treatment (just think of it that you’re donating for the work already done, not the work to be done).
This app was initially developed by Dennie de Groot and maintained by him until version 2.3.5
Q. I no longer receive notifications when motion is detected or when the Doorbell is rung
A. Sometimes Ring no longer sends out notifications, this can be fixed by following the instruction on How to: Fix notifications.
Q. How can I check if the Ring App is authenticated at Ring?
A. Please read the How to: Check if the Ring App is authenticated at Ring
Q. How can I authenticate the Ring App at Ring?
A. Authenticating at Ring is done by adding or repairing a previously added device. Please read the How to: Repairing a Ring device
Q. There is no image shown in my Ring device and on the developer pages, why is that?
A. The snapshot feature requires Motion Detection to be enabled on the devices, please check the devices settings if this is enabled.
Q. There is no Live video shown in my Camera or Doorbell, why is that?
A. Live video is only available on Homey Pro 2023 or newer. Also, it will only work for devices connect to mains power.
Changelog
Current version: 2.14.26
  • Better handling of unavailable devices
Previous test version: 2.14.25
  • Added timeline notification when authentication at Ring is lost
Previous version: 2.14.24
  • Added motion-activated floodlight setting with flow cards to enable/disable it
Previous test version: 2.14.23
Previous version: 2.14.22
  • Improved power mode detection
Previous version: 2.14.21
  • Code improvements
Previous test version: 2.14.20
  • Improved logging for Motion Alerts
Previous test versions 2.14.15, 2.14.16, 2.14.17, 2.14.18 and 2.14.19
  • Various code improvements
Previous version: 2.14.14
  • Updated ring-client-api
Previous test version: 2.14.13
  • Added settings and flowcards to Camera and Doorbell to enable or disable Motion Alerts
  • Added possible fix for a race condition where a new mode wasn’t retrieved correctly upon setting a new mode
Previous version: 2.14.12
  • Fixed inversion text for “Mode is …” Basestation flow card
Previous version: 2.14.11
  • Added Ring Alarm Basestation
  • Added Ring Intercom Video
Previous test version: 2.14.10
  • Prepared app for Homey Pro firmware 12.9
Previous test version: 2.14.7
Previous version: 2.14.6
  • Improved mains power detection for doorbells
Previous version: 2.14.5
  • Added Live view to cameras and doorbells*
  • Added multiple location support
Previous test version: 2.14.4
  • Improvements for Live video for Cameras and Doorbells
  • Fix for problems on Homey Pro 2016-2019 version, courtesy of @VyseExhale
  • Added Live video to Cameras and Doorbells
  • Fixed failures after Ring API change
Previous version: 2.13.0
  • Added Ring Alarm System support, now supporting Ring Contact Sensor, Ring Alarm Motion Detector and Ring Alarm Keypad
  • Added Motion Type Vehicle to cameras
Previous test version: 2.12.6
Previous test version: 2.12.4
  • Added Ring Alarm System support, now supporting Ring Contact Sensor, Ring Alarm Motion Detector and Ring Keypad
Previous test version 2.12.2
  • Added Ring Alarm System support, now supporting Ring Contact Sensor and Ring Alarm Motion Detector
Previous test version 2.12.1
  • First version to connect to the Ring Alarm system, Ring contact sensor available
Previous version: 2.11.17
  • Adapted to changes in Ring API
  • Renamed Generic Alarm to Doorbell
  • Made ‘Snapshot is grabbed’ flowcard available on Camera and Doorbell
Previous test version 2.11.16
Precious test version: 2.11.12
  • Fix for Homey Pro 2016
Previous test versions 2.11.8, 2.11.10
Unannounced versions
Previous test version: 2.11.6
  • Differentiated API per platform version
Previous test version: 2.11.4
  • Fixes for API changes at Ring
  • Improved error handling.
Previous version: 2.11.0
  • Added support for Ring Intercom
Previous version: 2.10.28
  • Added newly introduced motion type to flow card
Previous version: 2.10.27
  • Improved flowcard to set the mode of a location
  • Fixed problem with Siren Off flow card
Previous version 2.10.26
  • Repaired receiving of notifications after Ring API change.
Previous test version 2.10.25
  • Improved new ring-client-api
Previous version 2.10.20
  • Added Smart Alerts to Doorbell and Cameras
  • Minor translation fixes
Previous test version 2.10.19
  • Test version for Advanced Motion
Previous version: 2.10.14
  • Added additional translations
Previous version: 2.10.12
  • Fixed Location Mode flow cards for locations with a Ring Alarm System
Previous version: 2.10.10
  • Added flow cards to snooze and unsnooze a Chime
  • Adapted to changes in the Ring API
Previous version: 2.10.8
  • Added setting to Cameras to enable/disable motion detection
  • Added setting to Cameras and Doorbells to configure the motion timeout
  • Added new App Store images
  • Added new device icons
Previous version: 2.10.6
  • New communication method with Ring API
  • Minor fix in handling snapshot errors
Unannounced test version: 2.10.5
Skipped version: 2.10.4
Current version: 2.10.3
(All changes since previous stable version 2.3.5)
  • App upgraded to SDK3
  • Improved device pair function
  • Improved device repair function
  • Improved status view
  • Improved handling authentication failures1
  • Set devices unavailable when Homey is not authenticated at Ring
Current test version: 2.10.3
Previous test version: 2.10.2
  • Devices will be set unavailable when authentication at Ring is lost
  • Small improvement to authentication process
Previous test version: 2.10.1
  • App updated to SDK3
  • Added several new translations
  • Minor code fixes
  • Improved device add function
  • Improved apps settings page
Previous test version: 2.3.8 (only available on Github)
  • Minor code fixes
Current test version: 2.3.7
  • Changed App Store links
Previous test version: 2.3.6
  • App transfered. No functional changes
Current version: 2.3.5
  • This is the last version published by the original developer Dennie de Groot
Roadmap
In no particular order, no eta will be given
Improve device repair function
Improve apps settings page
Improve device add function
Update the app to SDK3
Publish SDK3 test version to Homey App Store
Look into handling authentication failures
Look into occasional invalid_content_type error when getting preview image
Set devices to unavailable when authentication at Ring is lost
Check compatibility with Homey Pro Early 2023
Complete translations in app.json
Rewrite communication with Ring API
Add setting to enable/disable motion detection for Cameras
Add setting to configure motion timeout for Cameras
Add setting to configure motion timeout for Doorbells
Add flowcards to(un)snooze Chime
Investigate the possibility to use Smart Alerts (Requires Ring Subscription)
Add Smart Alerts for Doorbell and Cameras
Add support for Ring Intercom
Add support for Ring Alarm System
   Add Ring Alarm System Contact Sensor
   Add Ring Alarm System Motion Detector
   Add Ring Alarm System Outdoor Motion Detector
   Add Ring Alarm System Keypad
   Add Ring Alarm System Basestation
   Add Ring Alarm System Glass Break Sensor
Add support for Live Video for Doorbells and Cameras
Add support for Ring events from Ring Intercom Video
Add setting to enable/disable motion alerts for Cameras and Doorbells
Add flow cards to enable/disable motion alerts for Cameras and Doorbells
Add setting for motion-activated floodlight
Add flow cards to enable/disable motion-activated floodlight
Add support for Live video for Ring Intercom Video
Research possibility to support Ring Sensors that use Amazon Sidewalk
Sometimes Ring stops sending notifications to devices other than the official Ring Smartphone app. If this happens to you, or they are only working sporadically, the steps below should help.
Steps to fix notifications
  • Stop the Ring Doorbell and Cameras app on your Homey (Wait some time before proceeding with the next steps, so surely all sessions are stopped, 15 minutes will be fine.)
  • Optional: Remove the Ring devices from your Homey (Some users needed this step to get notifications working again.)
  • In the official Ring Smartphone App, go to the Control Center. This can be reached from the main menu, under the Account section. See this article if you are having trouble finding it.
  • Click on Authorized Client Devices.
  • You will now see a list of authorized devices on your account. You should remove all devices (2) associated with the Ring Doorbell and Cameras App. The devices created by this App will be listed as android devices, with names like:
    • Homey
    • Device name not found
      (It wouldn’t hurt to remove all devices, but that would mean every client needs to re-authenticate.)
  • Once you have removed all of the extra devices, you will need to re-authenticate at Ring.
  • Start the Ring Doorbell and Cameras App on your Homey
  • Go into any of your Ring devices and re-authenticate by clicking Try to Repair and logon.
  • Notifications should now be working :crossed_fingers: :rocket:
Click here for the original article by the author of the ring-client-api library
How To: Check if the Ring App is authenticated at Ring
Sometime the authentication of the Ring App at Ring is lost. When this happens your Ring devices will be set unavailable. This can easily be seen because the device tile will show a red triangle with an exclamation icon in it.
Another method to check the authentication status is via the apps settings pages.
Follow these steps to check the Authentication State in the Homey app
Select …More
Now scroll all the way down and click Settings
Scroll all the way down again until you get to the Apps section and click on Ring
The next page will show the authentication status of the Ring App at Ring.
When the Ring App is successfully authenticated the screen below is shown
When the Ring App is not successfully authenticated the reason why will be shown. This will look like this, the actual reason however may vary.
In this case you need to authenticate at Ring. This can be done by repairing a Ring device
When the authentication at Ring is lost you can authenticate again by using the Device Repair Wizard.
Follow these steps to repair a Ring Device in the Homey app
Select Devices
Now long click on a Ring Device to open the device.
Next click on Try to Repair
This will take you to the logon screen
After entering the correct account information and clicking Authenticate the MFA code screen is shown.
When the entered MFA Code is valid the Ring App will be authenticated at Ring again which will be shown like this.
Click Continue to close the Device Repair Wizard.
Howdy!
Thanks for the app, I’ve installed it on. HP23, just some feedback -
  1. the chime flow card didn’t work until after the app was restarted (unknown device I’d error).
  2. In addition to that I had something funky happen when adding devices, where I was able to add chimes twice. At the time I was renaming some of the devices (and added a new one) in the app - but it wasn’t just the renamed devices it was all of them which were re-added.
  3. my approach for repairing was to just setUnavailable to the device - this then shows a “would you like to repair” screen from the device directly with out going to maintenance. Perhaps you are already doing this - or perhaps there is a reason you can’t, just in case though.
All these problems are resolved, by deleting the chimes - readd and then restarting the app.
Thanks for all the hard work! I hope Athom fix their end soon :slight_smile:
Hi Jamie,
Thanks for your feedback.
I’ve not experienced the Chime flow card not working at first, I will try to reproduce. Was this all ‘in the same session’, adding the chime, adding the flow and testing it?
Did you end up with 2 instances of 1 and the same device? That sounds like a Homey Pro Early 2023 bug to me, I’ve not seen such behaviour like that in testing and the adding process is actually a Homey function.
I’m not really getting the third point you mention, what did you mean with ‘set unavailable’ to the device?
I’m interested to know which exact devices you are using with the app, I’m trying to setup a compatibility list, could you please send me a PM with that info?
Hey,
  1. Yes this was all in the same session, once the app was restarted it worked as expected.
  2. Yes I did, I wonder if ‘uniqueID’ alters when renaming using the ring app, that might explain it, either way ill let you know if it happens again.
  3. If you Device - Homey Apps SDK v3 set a device as unavailable then rather then having to pair via the maintenance you can do it using this screen :
I dont have many devices, I use arlo as my main system but I have the following devices for my doorbell :
Ah, now I get what you mean with the third point, Thanks that’s a good tip, will look into implementing it!
I’ll send you a PM about the devices.
New test version published
Current test version: 2.10.1
  • Minor code fixes
You can find it here: Ring App (test version)
This version is the first SDK3 version. Next to the upgrade there are also some improvements and minor fixes.
There are also some languages added, I’ve used ChatGPT for this so I’m not sure everything is correct. If you spot errors, please post them on Github
Unfortunately updating the app to SDK3 does not mean it’s ready for Homey Pro Early 2023, some functionality is not working.
Most noticeable is that it is nog longer possible to retrieve a snapshot by using a flow. I’ve done my best getting this fixed by Athom but until now without result. If this is not fixed by Athom I will have no other choice than to remove this functionality completely.
With snapshot what are you meaning ?
When someone rings the doorbell it’s not possible anymore to get a snapshot ?
That’s sad if that’s so
This card is currently not working on Homey Pro Early 2023
Subsequently this card is never triggered:
And that’s indeed sad.
Hopefully athom will fix it otherwise the app has less added value for me
@DaneedeKruyff het lijkt er op dat dit in de software ge-update is want ik kan het kaartje gebruiken / krijg de snapshot binnen !
Here it is not working :cry:
Please keep the conversation in English.
Can you please show the flow you’re using? Because as far as I can see nothing has changed. (But can’t really test it thourougly right now)
I sorry , i will keep it in English……
but you’re right.
I use the snapshot card in telegram.
That’s working !
I have reinstalled the app and repaired the doorbell, however it keeps saying I have to reauthenticate the app every 4 hours.
When checking the app it says it is authenticated. So I also tried revoking auth and re-auth there.
Any other ideas?
