[APP][Pro] Eufy Security
:uk: - Eufy Security Smart Home Simplified
Add support for Eufy Cam/Doorbell in Homey.
Useful links
NOTE
This is not the topic for Eufy Home devices.
The topic for Eufy Home you can find here: Eufy Home
Account Information
Because of the way the Eufy Security private API works, an email/password combo cannot
work with both the Eufy Security mobile app and this app. It is recommended to
use the mobile app to create a secondary “admin” account with a separate email address
and use it with this app.
Usage
  • Install this app on your Homey.
  • Go to add devices
  • Provide your Username and Password. Click Next
  • Available devices show up
Current features:
  • turn on/off camera (EufyCam pan&tilt will turn its lens)
  • Set guard mode (Home, Away, Disarmed, Schedule)
  • Add devices and use them in flows. (on/off)
  • Get notifications based on detection modes for specific devices. (Motion, Face, Sound and Doorbell Press)
  • Get images when motion is detected
  • See last motion events
  • Generic alarm for each camera → Heimdall (goes off for all events except doorbell press)
Tips:
enable push notifications for Eufy Security to receive a notification when something important happens for this app
Record_2024-01-09-17-05-13-ezgif.com-video-to-gif-converter
Supported Languages:
  • :uk: English
  • :netherlands: Dutch
  • :fr: French
Contributions
If you appreciate this app, contribute to future development by making a paypal contribution
or buy me a coffee on Ko-Fi or Bunq.me
image ko-fiimage
:laptop: Apps made by @martijnpoppen
See for more apps link below :backhand_index_pointing_down:t2: or just open the pull down.
How-to send a diagnostic report:
:warning: Note: Before sending a report make sure to reproduce the issue so the issue will be visible in the report
  1. :mobile_phone: Via Homey Mobile app:
    More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
  2. :laptop: Via Homey Webapp:
    Settings wheel bottom left - Select Eufy Security - Click on send diagnostic report
Image and Video Features
  • Event Images: :person_walking:
    These images are automatically captured when a specific event occurs, for example, when motion or a person is detected by a camera. (doorbell press doesn’t update this image)
  • Snapshot Images: :camera_flash:
    These are on-demand images that can be taken at any time.
    Since version 3.39.7, snapshots are no longer processed on an external server but are generated directly within Homey.
    To capture a snapshot, you need to create a Flow that uses the “Take Snapshot” flow card. (Most cameras need a homebase to properly take a snapshot)
  • Livestream: :video_camera:
    Introduced by Athom in Homey Mobile App version 9.6.1, livestreaming allows real-time video viewing.
    Eufy cameras that support RTSP can provide a live video stream to Homey. To enable this feature, activate RTSP in the Eufy app.
Frequently Asked Questions
Q1: I don’t receive notifications/device updates in Homey
A1: Make sure the selected security mode inside the official Eufy app has enabled notifications for your device. (Home / Away / etc)
A2: Make sure push notifications are enabled in the device settings:
A3: Sometimes it might help to restart the Eufy app in Homey
A4: For Homebase notifications enable:
A5: Update: 01-08-25: Since july Eufy requires a country instead of a region. If you have issues with push notifications repair the device and select the proper country.
Q2: Can I disable notifications on my Phone and keep them on Homey?
A1: Unfortunately not. Homey registers itself as a Android device at Eufy.
A2: Work-around Android: Disable motion inside the Android settings (Apps → Eufy → Notifications)
A3: Work-around Ios: (link)
Q3: Images are not updating in the app
A1: Images are only updating when an event happened: motion/person detection or doorbell press
A2: Check FAQ Q1 for the correct settings
A3: Doorbell doesn’t always have a image, only when a motion was detected together with doorbell press.
A4: For snapshots see FAQ Q14
A5: To see difference between Snapshots and Events see: [APP][Pro] Eufy Security - #3 by martijnpoppen
Q4: My device shows a error
A1: If the error message contains a captcha error. Then follow the instruction
A2: If the error show that it can’t find the device or station serial number:
A2.1: Homey mobile app: Go to the device settings → maintenance → repair.
A2.2: Homey web app: Right click on the device → repair.
A2.3: This will update your devices and sync them with the Eufy server
Q5: The battery status and temperature is not aligned with the official Eufy app
A1: Unfortunately the battery/temperature status is incorrect. Eufy is not updating that every day to the cloud. so the data is quite outdated. Once Eufy resolves this the battery status will be correct in Homey.
A2: The temperature is the battery temperature and not the real environment temperature
Q6: When I change to Geofencing/Schedule Homey doesn’t update
A1 When you come home - select Home on the keypad. Make a flow like this: Gedeelde Flow | Homey (with these settings: https://us1.discourse-cdn.com/flex025/uploads/athom/optimized/3X/a/1/a1c570c5ac6a6e98283ab951829d0e24a8a97eed_2_250x500.jpeg)
A2: Don’t use Schedule/ Geo in Eufy and let Homey decide what Eufy needs to do. In this way you can combine other brands together with Eufy. Like this Homey is your source of truth and decides what other hubs/devices needs to do.
Q7: When I try to add a new camera it doesn’t show up
A1: Make sure the new camera is shared with your extra account. Otherwise it can’t be picked up by Homey.
Q8: Eufy disables my Homebase notifications
A1: Use the force notification option inside the Homebase setting: [APP][Pro] Eufy Security - #1029 by martijnpoppen
Q9: How to start a stream
A1: Not supported anymore
A2: Additional info: Due to API restrictions its currently not possible to stream a web stream from Homey → [Question]: RTMP CloudLiveStream migrated to WEBRTC · Issue #317 · bropat/eufy-security-client · GitHub
Q10: Changing guard mode shows: Not available for this device
A1: This is because the security modes are setup globally. The Off option is only for the homebase. When you see Not available for this device the security mode isn’t changed and the Homey app shows this message as an indicator that it cannot be used with this device.
Q11: Commands to Eufy are not working (on/off , security modes, etc)
A1: This might be caused by your network. If Eufy and Homey are not in the same network the connection won’t work (unless on Homey Cloud).
A2: Since Homey-Eufy version 3 it’s possible to have dynamic IP addresess for your Eufy cameras/homebase. So if you have set-up a static IP and experience any issues, make the IP dynamic, restart the Homey-Eufy app and try again.
Q12: My camera notifications settings are put on include thumbnail
A1: Since Homey-Eufy version 3 this is forced from Homey. As include thumbnail is the best setting which allows Homey to react to all camera types. Text only doesn’t contain an image and Full Effect gives duplicate data and unpredicted results as this behaves different per camera model.
Q13: How to setup self-hosted snapshot service
A1: This is no longer needed since app version 3.38.0 → FFMPEG runs locally on Homey see Q14
Q14: How to use Snapshots
A1: To make a snapshot create a flow like this:
A2: How does this work?
When Eufy starts a stream the Homey app receives the H264 Readablestream from Eufy. This is parsed via FFMPEG. FFMPEG takes a snapshot and sends that back. NOTE:
Since app version 3.38.0 FFMPEG will run natively on your Homey
Q15: How to trigger a recording (alternative solution)
A1 Unfortunately there’s no native way to trigger a recording, so therefore there’s no recording card available.
A2 I did manage to trigger a recording in another way, but it requires the automations from Eufy itself. To make this solution work it’s key that you’re not using the alarm of the homebase.
A3 Add the following automation in Eufy:
ScreenRecording_01-10-202509-19-10_1-ezgif.com-video-to-gif-converter
A4: In Homey add the following flow:
A5: For now the recording only lasts 10 seconds, i will check if i can change that somewhere
Q16: How to recognise a person
A1: if your camera supports it or is connected to the Homebase 3 the ‘Person Detected’ flowcard will contain a person tag
See example flow:
A2: As of release 3.5.0 there’s also a known person detected card which only triggers on a known person
Q17: Homey video streaming with Eufy
A1: Introduced by Athom in Homey Mobile App version 9.6.1, livestreaming allows real-time video viewing.
How-to: In Eufy App → Select camera → Settings → General → Storage → NAS(RTSP) ->Under Video type store to NAS select “Continuous recording”.)
A2: If the stream shows: RTSP_not_enabled_in_EUFY_app it means that you should enable RTSP on the camera before the stream will show up. (on battery cameras this might drain battery)
A3: if the stream show: Camera_is_off it means that the camera is turned of and can’t stream video
A4: if the stream shows an error that it can’t connect to the url there can be multiple reasons:
  1. the camera and Homey are not in the same network so local streaming is not possible
  2. the Homey app is opened via a mobile network (5g) and therefore you can’t see the stream because it’s a local url
  3. the stream has stopped after 5 minutes. This is a known issue and should be resolved, if this occurs try to open the device again and see if it opens the stream again. There are investigations to see if it’s possiible to continous stream, however Eufy has limitations on this level.
Q18: Can I change the order of Event Images / Snapshots and Video streaming in the mobile Homey app?
1: Currently it’s not possible to change the order of these items as these are prioritised by Athom:
  • Videos first (in case of Eufy only 1 stream)
  • Images next (Snapshots, Events)
:warning: App status — please read before posting an issue :warning:
Last updated: 23 October 2026
In short: The new Eufy app for Homey, built on the Eufy Mega platform, is almost ready for a beta release :tada:. This app (Eufy Security) stays in maintenance mode until then. Notifications, event images and API calls are still unreliable here, and that’s caused by Eufy’s migration, not something I can fully fix in this app.
Progress can be followed here: Eufy Mega Discord
:rocket: New app: almost at beta
Together with other Eufy developers from the Homebridge and Home Assistant communities, I’ve been building a new Eufy Mega SDK, and the new Homey app built on it is nearly ready for its first beta.
What to expect:
  • One Eufy app for Homey, which will eventually replace both Eufy Security and Eufy Clean.
  • It’s built on Eufy’s new Mega platform, so it doesn’t depend on the old APIs that Eufy is switching off.
  • Migration will be needed. Devices will have to be re-added in the new app, so your flows will need updating too. I’ll share a migration guide when the beta goes live.
  • It’s a beta, so expect rough edges. Please only join if you’re OK with testing and reporting issues.
I’ll post here as soon as the beta is available, with a link and instructions. No need to ask for an invite in the meantime :folded_hands:
:wrench: Current app: maintenance mode
Eufy is moving everything to the Mega platform (the 5-in-1 app) and phasing out the older APIs this app was built on. Until the new app takes over:
  • I’ll keep the bare minimum working as long as the old APIs stay alive.
  • No new features will be added here.
  • Fixes for issues caused by Eufy’s migration are mostly out of my hands.
:bell: Notifications: hit or miss
The app runs a hybrid of Eufy’s old and new systems, so notifications can be unreliable whichever side your account is on. Reliable notifications will come with the new app.
Crashes
Some users see app crashes. These happen when the Eufy API goes into a loop that this app can’t handle, and we don’t have control over what Eufy is doing there.
Failing login
Your account may already be on Eufy’s new V6 API, which this app doesn’t support. The migration happens entirely on Eufy’s side: we can’t trigger it, it isn’t tied to updating the app, and we can’t predict when your account moves. If your app stopped working, it’s likely caught between the old system being switched off and the new one not yet being active. The new app is the fix for this.
If you’re hitting crashes, notification, image or stream problems, the sections above are almost certainly the cause, so there’s no need to open a new report :folded_hands:
Progress on new:
Unsupported Devices
Currently unsupported:
:orange_circle: S4 Camera
:orange_circle: POE E40
:orange_circle: POE E41
:orange_circle: SoloCam E42
:orange_circle: EufyCam C37
:orange_circle: Network Video Recorder S4
:orange_circle: Eufycam C31
:orange_circle: Eufycam C35
:orange_circle: Eufycam E40
:orange_circle: Homebase mini
:orange_circle: Homebase S1
:orange_circle: Entry Sensor E20
:orange_circle: Motion Sensor E20
:orange_circle: 4G LTE S330 - T86p2
:orange_circle: 4G camera
:red_circle: Water and Freeze Sensor - T8920
:red_circle: Eufy Siren - T8970
:red_circle: DoorLocks
:rotating_light::rotating_light::rotating_light: Currently it’s not possible to add support for these device due to changes in the original Eufy app. Once it’s possible the devices marked with :orange_circle: will be added. Devices marked with a :red_circle: will never be supported
Hi @martijnpoppen , this is great news, when are you going to support other products ?
I have a eufy doorbell 2k wired and a homebase 2 with 2 1080 p cams.
If I can help you with this by testing let me know.
Hi @Rens_Hoekema ,
Currently i’m trying to get the notifications to homey.
I think this will also work with the doorbell press but i’m not sure.
If I have a new version ready i’ll reach out to you via DM :slight_smile:
I have a doorbell too, i would like to test too :slight_smile:
Hello Martijn, If I can helping you with testing the doorbell please let me know.
If you need a tester for the wired doorbell let me know :+1::+1:
Another Wireless 2K Doorbell user here, let me know if you want me to test something!
Deleted due to outdated information
I’m also interested in a eufy integration
Thanks for the update!
I tried to get the Deurbel Druk working, but it didn’t work.
This is what I have done so far:
  • Shared the devices (EufySecurity app --> Family & Guest --> Add Admin) with a second account.
  • Logged in with second account in the EufySecurity, can see the devices and get notifications.
  • Installed v0.7.0 from Community
  • In Homey Eufy app, Configure App
  • Logged in with the second account. But no keys are generated. It only tells me: “Saved. Logged in to EufyLife.”
  • Tried to create a flow, but no doorbell press was detected.
When I go back to configure the Homey Eufy, all the login details are gone.
And when I try to fill in random things in the login, it also gives the above “Saved” state.
So it looks like the login isn’t working anymore.
With the previous version, it did work and got all de different keys.
If you need any more testing, please let me know!
Hi @Pim_L,
Thanks for your findings.
Did you also log out of the EufySecurity app (on your phone) again?
Because you should logged in in to the EufySecurity app with your main account and logged in with the second account on the homey app.
Can you share a screenshot of the Configure App page in a DM?
That is amazing @martijnpoppen !
I’ve already got an integration working with a Fibaro Implant, but this makes it so much more convenient!
How likely do you think it will be able to include a camera screenshot as well?
Would love to connect that with the Face Recognition app for full integration :slight_smile:
Yes working on that too.
Trying to get devices up and running. I think then it would be possible to have the notfication screenshot as well.
First fixing some Authentication problems :frowning:
Hi @martijnpoppen .
I see that an (other) app has appeared in the Homey store.
https://homey.app/nl-nl/app/se.adamnoren.eufy/Eufy-Security/
Or is the same app?
Hi Twan,
Yes @Pim_L already send me a message about that. It’s a different one.
But as far as i see only doorbell support.
I also requested a publish of my app to the main store. Let’s see where this goes :slight_smile:
I don’t know if you already got it working, because I didn’t.
Installed the app, logged in with my second account (admin rights), got a (swedish?) message that I was logged in, but it didn’t found my doorbell.
