Features:
Use your UniFi Protect cameras as motion alert sensors.
Monitor your UniFi Cloud Key’s health in a dedicated, new UniFi Cloud Key device.
Supported device models:
UniFi® Protect (Network Video Recorder):
UniFi® Cloud Key v2 Pro
UniFi® Dream Machine Pro (UnifiOs)
UniFi® Protect Network Video Recorder (UnifiOs)
UniFi® Video Camera G3 series:
UVC-G3
UVC-G3-AF
UVC-G3-DOME
UVC-G3-FLEX
UVC-G3-MICRO
UVC-G3-PRO
UniFi® Video Camera G4 series:
UVC-G4-PRO
UVC-G4-BULLET
UVC-G4-DOORBELL
Note: if you are upgrading from a previous (beta) version, please re-add your devices.
Getting started:
Create a local access user in the UniFi Protect web interface (used only for Homey.
Install this UniFi Protect app on your Homey.
Go to the UniFi Protect app’s settings page.
You will be prompted to enter the credentials of the UniFi Video user you created in step 2 and some network information.
Start the ‘add device wizard’ in Homey, search for your UniFi Cloud Key and/or cameras and add them to your devices.
If the user credentials changed in UniFi Protect, they can be updated on the UniFi Protect app’s settings page.
Usage:
A flow can be triggered when motion detection on a camera starts or ends.
A flow can be triggered when a snapshot is created on a camera. This card supplies the name of the camera that created the snapshot and the snapshot image itself.
A flow action card can be used to create a snapshot, which is is saved to an Image tag.
A flow action card is available to set a camera’s recording mode, being one of ‘Don’t record’, ‘Always record’ or ‘Record only motion’.
How to create an local account?
Login in your local UniFi web interface, and click on Admins & Users. Note: This must be done from your local device and not from unifi.ui.com or within the app.
Click on the ‘+’ icon to add a new user.
Fill in the user details, and make sure to select ‘Restrict to local access only’ as the user type.
Give the user Full Management rights and click on ‘Add’.
Notice:
In a beta version of Unifi Protect, all information about the NVR itself has been removed. We have made the NVR itself deprecated as a device and will be removed in the next version.
Remove the NVR from your devices. The NVR is also no longer obliged to install it first.
Troubleshooting / FAQ:
I am using UniFi® Dream Machine Pro and can’t connect.
You must select ‘UnifiOs’ in the Application Settings.
I get a lot of false motion alerts. Is there anything to do about that?
Turn off ‘Enable Auto Rotate’ and rotate the camera manually.
Remove the default motion zone and create a motion zone with only the zone what you want to detect motions.
Set ‘Minimum seconds of motion to trigger event’ on 1 second or higher
Do you have more tips? let me know!
I am using a UnifiOS device, I don’t see any storage information.
UnifiOS device does not release storage information through the API.
I’ve got the g4 Doorbell. I’ve made a flow trying to catch the doorbell ring and then play a sound on my sonos but it doesn’t work. Someone else having this problem?
I have a Dream Machine Pro and i can’t connect it to my Homey Pro. I think it is the problem with the Two-Factor Authentitation token. Can you tel me how to do.
Thanks for a great app. I’ve recently started to use it. I have several cameras and the app works fine for sending a notice when detections are happening, and also for capturing snapshots on events. However I can’t change the recording mode on any of my devices.
When capturing a snapshot I can see a couple of rows in the log in the app config page, but when the change recoding mode is triggered nothing is shown in the log so I’m assuming that there is no request beeing sent to Unifi then?
Using my local user to login locally into my Dream Machine I have verified that my user has the correct rights to change recording mode on the cameras.
Is there anything else I need to do in order to get homey to change the recording mode?
hey @Daniel_Johnson any luck with getting catching the doorbell Ring? @ObelixNL Is this an option, I just added the doorbell, but do not see a flow option yet to catch the doorbell ringing. Quite new to this so maybe I missed it.
Hey folks,
I’ve got the app running for a while now. Since yesterday I’ve installed the G4 doorbell and ever since I created a flow for it, the app stopped as in, it shows the PAUSE icon on the apps list and devices are unavailable.
