Ever since upgraded to v5 all the routs on the developer Zigbee page is gone, se picture.
Anyone have a idea why that can be and how I can get them back?
Regards Stefan
Regards Stefan
I thought it can take up to a week, or maybe even longer till all routes are properly seen.
You either wait some time or reset zigbee and rebuild it from scratch. Start with routers and then with battery devices.
Last word on RC38 was that u need to reset Zigbee?
Hi @rvdeijk
Itās been more then a week so donāt think that will work for me⦠
Hi @Igy
Iāve waited for a week so maybe Iāll reset it tomorrow and see if that works.
I only have 12 Zigbee devices so far, so not that much work, just some flows to rebuild afterā¦
Thanks.
Did you manage to get your Zigbee routes showing again? After the v5 update, my routes are gone. Iāve done numerous restarts and waited for more than 15 minutes before powering on the Homey, all without any result. The routes showed perfectly before the update.
This week Iāve also added 3 new devices (that is a few weeks after the v5 update). Initially the new devices had route information (they all connected to Homey directly, even though there are two router devices much closer). After a few days, their route info also disappeared like all the existing devices, except for one sensor. Very weird. The devices do seem to function normally though.
You need to do a zigbee reset. read the forum posts about new 5.0 and zigbee resetā¦
Thanks for the reply, but itās not really helpful when you just say āread the forum postsā. That is exactly what Iāve been looking for and how I ended up in this topic. The forums are a confusing mess with no real help from the Homey guys themselves. I love my Homey, but the support is terrible.
This is a community forum. If you want to contact Athom about any issues, you have to file a support request through support@athom.com
Robert, Iām well aware of that, thank you. I pointed out that in a ācommunity forumā as you put it, it is not very helpful of someone to point you to āthe forumā. It wouldāve been way more helpful if someone wouldāve pointed me to the actual post or posts where the issue was addressed.
Specifically for routes not showing up or disappearing, this thread is where that issue is being addressed.
Hi!
Got the same issueš©ā¦
Does this issue affects users who have a lot of zigbee devices?
Under V 4.2 i had to wait more than 15 minutes to get the routes, but now with V5 I have waited for 1hour, but nothing appearsā¦
I have tried Ptp, restart homey without successā¦
Iād like to avoid resetting my zigbee network as I have more than 50 zigbee devices and hundreds flowsā¦
I hope this will be solved soonā¦
I guess the main question is: do your Zigbee devices still work? If so, I donāt see why it matters so much that the routes arenāt being shown.
For some people, it took more than a week before the routes were showing up.
Yes, it works quitte well excepted 2 devices,⦠thatās why iād like to see their routesš¤.
Exactly, it is supposed to work. My devices function normally most of the time, but now and then one fails to register an activity. It seems like something is wrong with my Zigbee network after the upgrade to v5, because (some of) the new devices I added do show routes, but they connect directly to Homey and not via their closest router.
What I find very disappointing is the way some people react in the forums. It is as if they find it more important to play police man and to constantly try and correct other people, instead of of actually being helpful.
That is the same as when people talking, there are always people that donāt have anything to say, but they still talking to impress others, my advice is, ignore them, and certainly donāt answer them, they will keep talking/writing.
@Yann_Yann and @andrekrit Check this topic:
fixing-disconnected-zigbee-devices-without-having-to-modify-all-flows
Once you did this, you could also check your zigbee health with a script
I had 8 devices that lost their route and fixed them without resetting the zigbee or change flows.
Thanks for the directions @rvdeijk
I ran both scripts @Dijker created (thanks Geurt!) as my zigbee developers page stays empty (been like that for weeks, since stable v5)
The script returns:
Oddly enough, zigbee worksā¦I just have huge cpu spikes which (I think) causes my Homey to become unresponsive / go offline.
I will re-add a router as āduplicateā and see if that does anything. If not, I will have to reset zigbee and rebuilt my flows.
I have absolutely the same situation since update to v5. There are only Aqara sensors and not a single route is shown. Strange that ALL zigbee sensors seem to work properly.
I added two Osram Smart+ plugs as routers but the situation stays the same. Also the newly added plugs have no route information.
Please let me know if you find a solution which does not mean a complete reset of zigbee.
