Homey Energy Dongle ⚡️ - Megathread
Thanks, tried that a couple of times. But sadly still no succes.
Oké now it works. :melting_face:
Today i migrated to Pro 2023 (from 2016) and did it on a guest network (still at WiFi, will use wired soon). I think that was the bottleneck. When i made the new network to connect, it worked.
Yes, got it to work after connecting it to external power for the first time connecting and updating.
After that it has been running smoothly without additional power.
More people having problems connecting the Homey Energy Dongle to the Landis+Gyr E360? According to Homey it should now be compatible. I still have the same problem as a few weeks ago: still unable to recieve data from the Landis+Gyr E360. Even after resetting and connecting it with external power.
I am trying to setup Homey Pro (2023) <=> Homey Energy Dongle data transfer.
The Meter Model I have (Slovenia, EU) is Iskra MT381 (Iskra MT382 is on the list, but this one is not).
I was able to get a hold of an engineer from the electric distribution company and he is asking me which OBIS codes to send in the telegram. The protocol is IEC 62056-21 (IEC 1107) and the data are being sent every 10 seconds via 9600 baud / no encryption. Only one telegram is possible instead of two (supported by latest meters).
Two questions:
  1. Are those 4 all necessary OBIS codes in one telegram? If not, which ones to add?
  • 1.8.0: Total active energy consumed (kWh)
  • 2.8.0: Total active energy exported (kWh)
  • 1.7.0: Instantaneous active power (kW)
  • 0.9.1: Date and time of the meter
  1. Should I manually re-configure the dongle or does it auto-detect settings (like order of OBIS codes, baud rate etc.)?
Thank you for your answers in advance!
Potential answer to Q1:
I managed to ChatGPT the answer for the OBIS codes - I pasted all the data I found in the screenshots of other users in this forum and got this list:
1.8.1 - Active energy (import), tariff 1 [kWh]
2.8.1 - Active energy (export), tariff 1 [kWh]
1.8.2 - Active energy (import), tariff 2 [kWh]
2.8.2 - Active energy (export), tariff 2 [kWh]
1.8.0 - Active energy (import), total [kWh]
2.8.0 - Active energy (export), total [kWh]
1.7.0 - Instantaneous active power (import) [W]
21.7.0 - Instantaneous active power L1 (import) [W]
41.7.0 - Instantaneous active power L2 (import) [W]
61.7.0 - Instantaneous active power L3 (import) [W]
32.7.0 - Voltage L1 [V]
52.7.0 - Voltage L2 [V]
72.7.0 - Voltage L3 [V]
31.7.0 - Current L1 [A]
51.7.0 - Current L2 [A]
71.7.0 - Current L3 [A]
0.2.0 - Current tariff (could also be 0.1.0)
Did I miss anything important?
Q2 remains unanswered - thanks for your help in advance!
Last week I got my Homey Energy Dongle, and started working on some flows to directly use my solar powered energy in my Tesla. So I started with a flow:
At the moment, unfortunately, there is no ‘if’ card with the current exported energy in kW. That would be needed to transform my dumb wallbox into a smart one, by telling my car to start and stop charging. With the Tesla App it is even possible to change the charging speed. That would be great so I can tune it with the current solar power export.
My question: Do you guys know a way to get the current exported energy into a ‘if’ card. It is a shame, because the Energy Dongle cán actually read the data.
Same problem here. Received it today but not working with my e360 meter…. Cannot load data
About the missing daily kWh totaliser : Homey firmware 12.4.4 fixes this.
Vond dit terug. Verschil in meters zit in de connector zelf.
De L&G 360 is een andere poort dan de L&G 360-1P
HAN of P1 zijn verschillende uitgangspoorten die zich op de slimme meter in uw huis bevinden. Uw slimme meter heeft normaal gesproken ofwel een P1-poort of een HAN-poort, afhankelijk van waar u zich bevindt. HAN-poort is het meest voorkomend in Noorwegen. P1 is het meest voorkomend in Zweden en de Benelux-regio. Sommige landen hebben een mix van beide. Als u onzeker bent, neem dan contact op met uw energieleverancier.
Uitzonderlijke InformatiewaarschuwingHoud er rekening mee dat de HAN Equalizer en de P1 Equalizer twee verschillende producten zijn en niet uitwisselbaar zijn. Voordat u uw elektrische installatie opwaardeert, is het belangrijk om te bevestigen of uw slimme meter een Han-poort of een P1-poort heeft. Deze poorten gebruiken verschillende communicatieprotocollen en verschillende verbindingskabels. Het kiezen van het verkeerde Equalizer-model leidt tot compatibiliteitsproblemen.
De uitgang geeft realtime informatie over uw elektriciteitsverbruik aan het luisterende apparaat - zoals de Equalizer. De poort is meestal standaard gesloten, dus u zult contact moeten opnemen met uw netbeheerder om deze te openen. Als de poort gesloten is, zal de Equalizer niet werken.
Hoewel zowel HAN als P1 dezelfde gegevens leveren, doen ze dit via verschillende communicatiemethoden. Het meest opvallende verschil tussen HAN en P1 is dat ze verschillende aansluitkabels gebruiken om de gegevens naar het luisterende apparaat te verzenden. De HAN-poort gebruikt een RJ45-aansluiting, en we hebben hiervoor een speciale RJ45 naar RJ12-kabel gemaakt. De P1 gebruikt een normale RJ12 naar RJ12-kabel. De aansluiting in de Equalizer is RJ12.
Here it works! Since the new homey update, I even didnt have to reinstall it
Hi all,
I can’t find my issue back with my dongle but are there more people problems with the connection off the dongle.
It connects normally but after a while the dongle stops and stops sending information.
I don’t understand the problem, but maybe it’s the problem the splitter, I got three p1 readers 1 honey the cable goes in the back off honey dongle and than the cable goes to the splitter where Toon and Zonneplan p1.
The homey dongle is connected to the 5 volt
I don’t hope the dongle is broken.
Update 21-5-2025:
i just replaced the Homey dongle now after the splitter instead of straight in my meter, this setting doesn’t work, it keeps losing connectiion, it’s rubbisch at this moment.
the setting i use now works, but i think for a little moment, that was the issue last time.
I expected much more from this dongle, i’m starting to get regreds of buying this thing for way to much money.
please @Homey get updates or i want my money back.
Update 26-5-2025:
Ik heb sinds een aantal dagen weer verbinding, dit komt doordat ik mijn zonnenplan p1 eruit heb gegooid in de zin van uit homey.
Het zonnenplan dongle werkt nog steeds gewoon zoals het hoort, maar dan niet in homey, nu lijkt het erop dat dit het probleem was.
exactly same problem here in Niederösterreich with Sagemcom T210-D
no way to get it to work
My energy company just installed a Landis+Gyr E360-1P which, according to the energy dongle info, is NOT compatible with the Homey Dongle. So is there a solution? I do have a Homeward P1 but it seems that the Homey Homewizard app can only be used with the Home Pro? (which would cost me €399). Is there another solution? I started using Homey to be able to switch devices based on spare solar power but if I cannot measure electricity usage then there is no point for Homey.
The Landis+Gyr E360-1P has a HAN interface (HomeAreaNetwork, with a different connector), instead of a P1 RJ12).
But when Homewizard can pull it off to make the HW P1compatible, Athom should be able to do the same with their Energy dongle imho?
Most (all?) P1 related apps are community apps, meaning: not available for Homey Cloud.
Additionally the Homewizard P1 app works using a local wifi connection, which is technically impossible with Homey Cloud + bridge.
BUT: Shelly has Homey (Cloud) compatible powerclamps, which also can measure incoming & outgoing energy:
3-phase systems need 2 additional clamps:
My dongle worked fine for severall weeks. This morning the message “not connected” . Tried to reconnect but it won’t pass the “reading meter data “step . Tried to reconnect severall times. No luck. On my router the dongle got a dhcp lease for it so wifi is ok.
Anyone an idea where to start for troubleshooting?
Does it have extra usb powered? If so, replace it.
Well, yes and no. I plugged it in a powered P1 splitter. Worked as a charme for serveral weeks but suddenly not anymore…
Is the power inlet separated from te P1 power? So I can power this dongle apart from the P1 splitter?
The homey energy has a usb c socket at the side, add power adapter there and see if that improves the dongle usability.
Installing with USB powerered did the trick.
Need to re-arange my fuse box to get constant power on the dongle…
I’ve read in certain cases it’s possible to remove the USB power as soon as the dongle is up & running (when it has finished setup or initializing)
Always worth a shot.
