Project started as a way to include the Aqara FP2-sensor via Homekit into Homey.
App is now more generic, many services and capabilities are supported. If you encounter problems, please PM me a short note and a copy of the log where you add the device.
Generic procedure to add a device.
Add your Homekit capable device to the app that came with the device and configure it.
If added with iOS device, remove the device from the iOS Home app, a device only can have one controller.
Most of the time the device can be discovered and added now, using the PIN.
Additional services are made available over time, as its capabilities. But in some cases it can take multiple minutes that the homekit service is advertised on the network.
As a start the Apple defined services and capabilities. When available some other vendor specific might be added as well.
When entering the PIN and you have selected OK, please wait patiently until the device has been added. DO NOT click OK twice impatiently
WHEN adding EVE Thread devices reset the device and do not put it into pairing mode, the device will not be found if you do. For Thread devices, remove devices does not work, so if you want to remove it from homey, delete it and after that reset the device network settings. (usually pressing some button for 10s).
thanks for providing the homekit controller. I tried to connect the FP2 sensor today. After a few attempts I got the sensor integrated into my home but the sensor doesn‘t sync anymore. The alarm is permanent active. Do you have an idea how to solve this issue?
Hi
Thankyou for the replay
I am using 1.0.2
Just found out how to update to 1.0.4
Doing it now and delete from homey and aqara and add it all again and will update
Thanks. The integration works now. I had some trouble with ghosting, but this doesn‘t seem to be based on your app. Some „AI Learnings/Resets“ later, it is more reliable now.
Add the bridge device first, after that bridged devices will show which you can add without PIN.
Might be that sometimes device capabilities are not shown that you expect. (i do not have all devices )
If this is the case PM me the log and a short description of the issue.
PS. Hue bridges that support Homekit can be discovered by pushing the button on the bridge.
I have a homebridge server with a TPlink plugin. I have this set up as a child bridge. I was able to successfully add the bridge and then all of my switches using the HomeKit controller. Very cool!
After trying several times, I could add the FP2 to Homey.
But I get a yellow “!” (exclamation mark) on the device. Luminance and the zones are available, but most of the do have yellow exclamation marks. Is this a know issue?
Hi KEvlarD, thx. Yes, I mean this one. It seams, that I don’t get resent updates. Some status is several hours old, even there have been updates recently. I try to trouble shoot tonight.
Remove device from Homey
Remove accessory from Aqara
Press Aqara button until yellow flashing
Add to Aqara
If IOS remove from home app
Add to Homey
When PIN is entered, ONLY PRESS OK ONCE AND WAIT.
