Try to test out aqara presence sensor FP2 with homey before deciding if I want to invest in homey pro, but it looks like you have to have homey pro for them to integrate which makes me worry all the things I’m seeing in reviews about homey pro not integrating well may be true (US based). Is there a way to test integration with homey and aqara FP2 presence sensor that I’m missing?
No, you need a Homey Pro for FP2 support. Homey Cloud/Bridge is not a good way to test device support since it only has a limited amount of available apps (by choice).
I cannot find it here Aqara App voor Homey | Homey so it is not supported.
The Aqara app is for Zigbee devices, the FP2 isn’t a Zigbee device. There is now an app that supports the FP2: HomeKit Controller App for Homey | Homey
How do you know all those things and exceptions !![]()
No? The HomeKit Controller app is a Homey app.
So don’t use it and wait for it to become stable.
There is a stable version, HomeKit Controller App voor Homey | Homey
In the change log it says it does support:
0.0.2
28 okt 2023
FP2 30 zones, changed icons
0.0.1
27 okt 2023
Initial release Aqara FP2 support
More info at [APP][Pro] HomeKit Controller voor Homey (NL)
Thank you
Thank you!
Hi @robertklep,
When using the homekit controller app, I cannot see the FP2 device(s). Does the homekit controller app need a separate bridge before it can see the FP2?
Steps to reproduce:
- install homekit controller app on HP23
- add device → homekit controller
Result: a list of Homekit devices, EXCEPT for the FP2.
I must had missed something, so I need a little help here.
Thanks,
Roger
I only suggested the app, I don’t use it myself nor am I involved in its development.
One thing I do know is that your FP2 cannot already be connected via HomeKit with another HomeKit controller (like an iPhone/iPad or Home Assistant). When it is, it can’t be found.
I think there is another discussion going on here Aqara FP2, mmWave presence detection on WiFi
And a solution here:
Hi
(My first post here, as I just ordered Homey pro and still wating for the delivery)
I suppose you need Apple Home kit for this to work. Or you just need the HomeKit app installed in Homey? Wondering if if this still works for non-Apple users…
Cheers!
Yes, it does, you don’t need any Apple devices for it to work.
Perfect. Thanks, @robertklep
Ok so I tried this and it recognized it fine, but when I typed in the PIN and gave you a connection error and asked me to cycle power and try again, I’ve tried a few times. Did the same thing every time
I have the same problem. Do you know what to do?
Well actually, I kinda gave up for a bit, then tried again after a few weeks the same way, and it just worked! IDK??
Thank you for your reply. I think I’ll try again later, too.
