Can you connect aqara presence sensor FP2 to homey?
I am trying to pair one of my FP2’s with Homey Pro. I follow the instructions, when I get to the screen I enter the PIN and it gives me an error “Onpair No Service Found For Device”
Any thoughts? The first time I tried I had a similar error (asked to Cycle POwer and Try again) but after that I haven’t been successful in getting it into Homey
I have the same problem with “Onpair No Service Found For Device”, do any have a solution?
Yes I eventually got both of my sensors to pair. Here is what I did and it seems to work.
Restart the homekit “app” under the settings for the app. Remove the accessory from the aqara app. This will then put it into pairing mode.
I found on my phone I also had to turn off cellular Data or it wouldn’t onboard in the aqara app. Input the WiFi info into the aqara app and it will connect. Then switch over to the homey app and add device, homekit device. It should now show up in the devices and then you can pair it with the homekit key.
Be very carful when you hit “connect” when inputting the pin. It’s almost like when you hit ok it seems like nothing happens, it takes a second then all of a sudden it works.
I think the key was rebooting that homekit app in homey. I now have both my sensors in homey as well as in the aqara app.
Hope that helps
Do I need to enter the PIN provided by Homey from the HomeKit, or the PIN on the FP2?
The pin on the FP2
I’ve tried it 30 times now, but I keep getting stuck at ‘Onpair No Service Found For Device’
Phew, persistence pays off! I finally got it to work. After many attempts, I removed the Apple Home app from my phone, and now it works.
Hi! Removing the FP2 from HomeKit and redoing the pairing process would have been sufficient to resolve the issue. The FP2 can only have one controller at a time, so reconfiguring it should have worked without needing to remove the Apple Home app from your phone. Bye :slight_smile:
But how would it work? Don’t you need apple home or something? Or does it just work?
Well, the trick is to have Homey say “Hi, I’m an apple device" :pear: So you don’t need to actually own apples .
That’s a bit what the Homekit Controller app does:
