I get it it’s pretty complicated stuff , but I don’t understand why you don’t seem to read post 1 of this thread, as suggested several times with a reason;
because that gives you the answers about what to do, when you have:
I hope this gets you a bit further connecting with your ‘not directly supported device’.
Or maybe you’d just wait for the Tuya app by Tuya themselves:
No, about 2 alternative ways to control almost any Tuya device with Homey (like lights, switches) and 1 alternative way to control Homey with almost any Tuya device (like sensors and such)
It is weird. Are you sure the device is supported in Homey? You can control it in Tuya, right?
Somehow, I have the impression that the device is still connected to your old Homey or something like that. Would it be an issue to remove the old Homey from your account?
Yes the filament lights from Action I use are supported.
not all devices in the tuya app are supported but as a test I only did add the filament lights to the cloud project that are known to be supported
Everything works fine in the tuya app. Old homey is empty atm because I did move everything over to the new one.
I made a new cloud project with a different email/accont that only was used on the new homey (old iot account is deleted )
Also I dont really understand the error “Tuyadevice.status is not iterable error”
So I’ve got the Tuya Cloud app all connected to my Smart Life app through the API, no issues there.
Although I did find the set up process a bit tedious and not all the steps were clearly defined at the top of this thread, but anyway…
Most of my Smart Life devices have been added to Homey, apart from some wireless scene switches which I connect to Smart Life using Zigbee Gateways (Wireless).
All three of them are made by Moes.
I have one of these
And two of these
I just use them to trigger Knightsbridge WIFI Sockets in my home office and bedroom to save energy and I was hoping to be able to scale this up with Homey once we’ve finished renovating the downstairs of our first home.
Luckily the most important scene switch in my very basic smart home setup, a Retrotouch Crystal+ switch which is mains powered, pairs with Homey fine.
Any ideas or workarounds on how to get these into Homey?
I’m based in South London, UK
Can you please post what you missed, what was wrong and what the improvements should be?
Maybe it’s possible for me to edit the manual with your findings.
How to add non-supported devices:
Please read post #1 again, it’s clearly pointed out, there are two alternative ways with links to extended howto’s
I now understand why you wrote ‘not all steps were clearly defined’, you skipped them apparently
When I was referring to ‘not all steps were clearly defined’ I’m talking specifically about the app setup with the API, not adding unsupported devices.
No need for the gaslighting emojis. The explanation isn’t a clearly defined step by step process, it’s just a vague explanation with some external links, assuming that people understand the ins and outs of the Tuya developer site already.
If I was questioning the unsupported devices guide, then I would just have referred to that.
Thank you for clarifying on unsupported device types, I’ll spend some time this evening having a bash with the text event method and let you know if I run into any issues. Hopefully this will all be resolved when the new integration with Tuya gets released.
EDIT: The first line of the Raw Commands guide doesn’t even make sense. “You can receive all messages send for devices with trigger cards.”
That literally does not make sense. Do you mean send or sent?
The second line doesn’t make sense either, "Also there are now action cards to send commands to you device. " You or Your?
Third line, “on this way…” doesn’t make sense either, Why not, “Using this method…”
