[APP][Pro] Homewizard 🧙‍♂️
Yes you can
Missing gasmeter and Total usage KWh values in the P1 v2 connected to a DSMR 4.
A bit off topic. But how can I get the firmware 6.x on the P1 meter dongle?
Only in combination with a Plug-in Battery.
Please sent a diagnostic report.
For now it’s beta or you have a Plugin Battery.
Version 6.x is mandatory for the battery. This is also a requirement later for controlling the behavior of the plugin batteries (charge/diacharge/standby)
Diagnostic report e39b2ffd-1010-4f44-8da0-6b424e68f33c
Thanks for investigating!
I wonder why you (seem to) want to drop the local connection in favor of an internet connection?
beta/test
v3.6.9
  • Update code for custom polling for P1 and sockets (Default is back to 10s).
    Setting can be adjusted in advanced settings of the device
  • Bug fixes polling timers that suddenly stopped
  • P1(apiv2) gas meter bugfixes
APIv2 is also local.
Hero!
Gasmeter fixed, Total usage kWh still empty (not for API v1)
I’m still using the stable P1 firmware 6.0112 but I was really SURPRISED to see your quick implementation in v.3.6.9 for the HW P1 6.0200 beta firmware :heart_eyes:
Still cosmetic plugin battery details doesn’t work yet. But as I need to fix the P1 APIv2 as well that slipped in. I will look at the total usage, not sure why that doesn’t work. Will get back with fix.
I didn’t notice it immediately but unfortunately the P1 v2 device is unavailable after upgrading to v3.6.9. Back to v3.6.6 is working but without showing Gasmeter usage, Total usage kWh and Active tariff.
Please no hurry Jeroen.
Found it. Fixed in v3.6.10 (now in test)
test/beta
v3.6.11
  • Custom polling for SDM230, SDM630 and SDM630-p1 mode, Default 10s, adjust as you wish.
Nice, 1 sec. works fine on the early 2023. Thank you.
Happy for you but this can vary per user. One HomeyPro 2023 can die if there are multiple devices (sockets). So really can be different per use or setup.
Great app @Jeroen_Tebbens!
Are you planning to add the poll setting for the water meter, too? Would be really cool.
Also, Homewizard has an integration for AP Systems (solar panel) in their app. Is it possible to get this data to Homey as well, or does this only live in the Homewizard cloud?
Sure can add custom polling for water meter as well.
And no I can’t add AP or any solar panels via cloud.
This information is not known locally by the P1 dongle.
