[APP][Pro] Homewizard 🧙‍♂️
I think the problem will be, that the output of the get-status request is empty for the smoke detectors (type:smoke868).
get-sensors
{“id”:9,“name”:“RM HausWR”,“status”:“no”,“type”:“smoke868”,“favorite”:“no”,“timestamp”:“00:00”,“cameraid”:null,“lowBattery”:“no”,“lastSeen”:“2020-08-18 09:15:34”}
get-status
{“id”:9,“status”:“no”,“timestamp”:“00:00”}
Ok does it fall under kakusensors section?
Yes,
“kakusensors”: [{“id”:9"status":“no”,“timestamp”:“16:20”}, …
The only command I know is:
http://x.x.x.x./password/kks/testsmoke/id
http://x.x.x.x./password/kks/testsmoke/9
{“status”: “ok”, “version”: “3.403”, “request”: {“route”: “” }}
kks = kakusensors
THX
I got an idea but again, dont own a smoke detector so not sure if the status : yes would mean there is smoke.
Fixed in test, please confirm
Hi Jeroen,
is it possible to display 3 decimal places at the water meter with SDKv2
Understand what you mean, I will check it tomorrow.
@Jeroen_Tebbens your absolutely right with “status : yes” if the alarm is activated:
/get-sensors
{“id”:5,“name”:“RM Schrank”,“status”:“yes”,“type”:“smoke868”,“favorite”:“no”,“timestamp”:“09:35”,“cameraid”:null,“lowBattery”:“no”,“lastSeen”:“2020-08-19 09:35:14”}
/get-status
{“id”:5,"status":“yes”,“timestamp”:“09:35”}
Please, could you implement it :wink:
THX
I own 4 of these, I would love to have these implemented as well :slight_smile:
Yes it is. Code has been changed it will be in version 1.0.3 available as 3 decimals.
Thanks, thats great
Raised a requested here for tracking and development.
yeah, the water consumption is now in 3 decimal places. we can now see consumption per liter. keep up the good work thanks
Yes it’s better now :slight_smile:
Hi Jeroen,
From version 1.01 and higher, switching the heatlink off doesn’t work anymore.
When the flow runs there is a problem with the command to turn the heatlink off.
How can this be solved.
Greetings Anton
Hello, I have an Energylink from HomeWizard. A kWh meter connected to it.
I use the app v1.0.3 beta from Jeroen. How and where can I see my current consumption of power?
Did you pair the Heatlink again?
Huidig vermogen is je gebruik in watt nu.
Sorry. I can not see it
No, do i only have to pair the heatlink again?
