[APP][Pro] Homewizard 🧙‍♂️
Found the problem in my code. Voltage only was shown for 3phased connections. You seem to have voltage on 1 phased.
That’s correct, I only have a one fase connection!
Is it possible that the code get changed so I can see the voltage in Homey?
Sorry if I ask something strange, do not know how much work it is.
Yes I can fix that, probably tomorrow. Else early next week.
Great! It will automatically update I think?
It will first flow in to test version, then when Athom approve it it will flow in to stable.
Thanks for the explanation!
v3.2.3 pushed to test
Changelog:
  • Attempt to cleanup callback calls and replace them with Promise/Resolve
  • P1 fixing voltage for those that have that info
Hey Jeroen,
Is it possible to add a manual IP entry in the app? I’m having issues with MDNS, I have lokaal API enabled and the p1 meter is on the same network. Can connect and see the API. The firmware of the P1 meter is 4.14.
Not looking forward to add it as its a lot of work as I have do it for the kwh’s and watermeter too. Why does mdns not work?
v3.2.4 (test / beta)
  • Additional Homewizard windmeter error handling
  • Energylink meters 3 decimals
  • Energylink code fix reading T1 & T2
Hi, I have a question. I have a Homey (Early 2016) model. I also have ordered a Homewizard P1 Dongle. How can I add it to my Homey? I see that the Homewizard APP is only available on a Homey Pro version.
It will work. Homey Pro is basically for all the sphere/ball based units and the latest puck. This app will not work on the Homey Cloud based solution. I am also still on the Homey early 2016 (non pro).
Hi Jeroen, thanks for your fast reply. But how can I add it? When I want to add the Homewizard APP within the Homey APP the follow statement is “Alleen op Homey Pro”. Do I need to add an other APP?
Strange. Did you have only Homey app without the Homey 2016 before as in cloud only?
My app installs fine on the Homey 2016.
I have solved it, I think…
I just continued as I would have a Homey Pro, during installation I could select the Homey (Early 2016) model.
Right, ok then you should be fine.
v3.2.5 (test / beta)
  • SDK3 - Homewizard Kakusensors fix (driver problem)
v3.2.5 just went live.
Hallo
Got my Homey Pro 2023 and installed the Home Wizard app version 3.2.5. When I try to connect to my Home Wizard base station the Home Wizard app shows the screen for putting in IP and PW. However this screen only shows for 1 second and then disappears. So connection is canceled even before connection data can be entered. Reinstalled the app and restarted it but this does not help. I have no problems with other apps I am using so Homey app works ok. Any suggestion how I can get it working?
Which firmware are you on your HP2023?
