[APP][Pro] Homewizard 🧙‍♂️
@Jeroen_Tebbens Maybe you can compare the diagnostics with my diagnostics.
60819d66-10f0-45e7-b3ad-06f8c98618e8
I am on V3.2.0 Homey 2023 is on 10.0.0-rc.110.
With Temp sensor, Homewizard, P1 meter, Watermeter and the Energylink.
I have no problems at this moment.
The devices are also still in Homey Pro 2019.
Yup different but still major network issues, but again I dont own a Homey2023 so unable to test.
Your old Homewizard cant be reached:
Error Homewizard Request - CONNECTION PROBLEM
Your watermeter (ENETUNREACH means no route was found to your device).
2023-05-26T22:44:45.031Z [err] [ManagerDrivers] [Driver:watermeter] [Device:baf6ad02-cb08-4fb5-8964-a761fc3bb41b] FetchError: request to http://192.168.0.44/api/v1/data failed, reason: connect ENETUNREACH 192.168.0.44:80 - Local (0.0.0.0:0)
at ClientRequest. (/app/node_modules/node-fetch/lib/index.js:1491:11)
at ClientRequest.emit (node:events:513:28)
at Socket.socketErrorListener (node:_http_client:502:9)
at Socket.emit (node:events:513:28)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
type: ‘system’,
errno: ‘ENETUNREACH’,
code: ‘ENETUNREACH’
Thank you for this info.
Till now I have still no problems with the devices.
When I request the Watermeter api i get for the wifi:“wifi_strength”:100
So I don’t know if there is a problem.
Maybe it is because of the use with the HP23.
Don’t know if the old Homewizard has a problem because the Energylink has no problems as far as I know. Every time I take a look the value of the power it is the same as the P1 meter.
And the Energylink is only working with the Homewizard.
I will let you know if something is changing with connection problems or other things.
Maybe its not your Homewizard devices but Homey itself that has connectivity issues (wifi?).
The problems are solved.
The P1 dongle has been added again. In Homey2016 and Homey2023 and workes fine now.
The cause was in the router. Ip adress was somehow blocked.
Has reopened. After that the problems were solved.
Thanks for your feedback on your issue. Yes sometimes its hard to track the real cause if issues where an assumed change/update in software doesn’t automatically means that is the real problem.
My router is about 3 meters from my HP23. So wifi problems shouldn’t come from that.
But he is not yet at his final location. Play around with it a bit before I start migrating everything.
The Homewizard is on the ground floor near another router and Homey is on the first floor.
When Homey is in its definitive place, we’ll see
Hi Jeroen,
First of all a big thank for the expertise and the hard work.
Would it be possible to implement the peak value of the month?
This value is in W(att) and is the average measured over a quarter of an hour.
Thank you in advance!
Yes that is possible.
v3.2.1 (beta/test)
  • Fallback to node-fetch as Axios 1.4.0 giving problems (Added retry & abortcontroller code)
  • P1 - monthly peak watt (Belgium specific P1 meter value)
Hi @Jeroen_Tebbens ,
Thanks for the lightning fast implementation!
I can confirm that "P1 - monthly peak watt (Belgium specific P1 meter value) " works, but the naming is slightly confusing: It is now just called “Vermogen” and caused some confusion with “Huidig vermogen” for me (sorry my Homey is in dutch).
So perhaps I would suggest to rename it to “maandelijks piekvermogen” or something? That might make the distinction between them a bit more clear?
Thanks again for implementing this so fast!
Yeah I figured I added as a default meter/value and not flagged it with a proper name.
Fixed in v3.2.2
@Ruurd_van_der_Noord Thanks for your donation, very much appreciated. :smiling_face_with_three_hearts:
Will this be availble for Homey Bridge too soon?
No never. Homey Bridge is cloud only and Athom doesnt allow local wifi access, sorry. :cry:
Hi Jeroen,
In the Homey app of Homewizard (P1) I do not see the current voltage.
When i go directly in (via IP) i can see the current voltage.
I hear from other users that they can see the current voltage in Homey, how come that I do not see the current voltage?
Strange it should work if the P1 API shares it.
Please share me the http://x.x.x.x/api/v1/data of your P1 please.
Wrong image
That is the telegram output I need the json version.
Sorry!
