[APP][Pro] Homewizard 🧙‍♂️
Battery policy is off (long time)
Ok send diag
1225608d-c1c3-4e6f-ab88-3478d17309ff
I changed before the diag the mode in HW app to NOM (not in Homey), mode was then also NOM in homey, restart app in Homey, after some seconds it changed to NOM alleen laden again
Adition: I use as status indicator in the P1 icon: batterij groep oplaadmodus
Please double check policy mode is off, I might have accidentally enabled it with the bypass SlimLaden code.
policy mode is off. I am now restarting Homey, perhaps it helps.
Restarted Homey. Modus changed to “Nom charge only”.again
I now used first the Homey webapp to change the modus and then the “schuifregelaar” to NOM and it changed to NOM charge only (it took more timenow ). Weird.
additional remark: perhaps I can load the production version of the app?
v3.15.92 made policy off as a kill switch. Planning became active due to other slimladen check which started executing the planned modes.
Edit: if test version still doesnt work, yes production doesnt have this issue. Its due to latest slimladen code inside battery policy that bypasses some guards it should’t have. My bad. Which is fine, risk of beta/test anyway till somebody sees a problem as you did unfortunately.
Up till now version v3.15.92 does the job. Thanks. Glad to help things forward!
Good thanks for confirming.
Hi @Jeroen_Tebbens ,
I have a question is in possible to disable the watermeter like the gasmeter .The reason I have not a water meter .:smiling_face:
Implemented in v3.15.95
Hi, a question about Slim laden modus. When enabled this works fine. When the EV starts charging I put the batteries in Standby modus, to resume when the EV stops charging.
Problem: the EV starts charging and when the batteries go in Standby modus, it automatically changes back to Slim Laden modus within a minute. Probably because of the high power demand? But I want the batteries to stay in Standby modus until the high demand is gone..
I know Slim Laden modus is developed by HomeWizard, but I first want to check if this is something we can control/fix from within the app itself..
(Note: confirmed this same behavior with the battery of a friend, so seems persistent)
Dont know (yet), as you say its new and not been through this
Please replicate the problem and sent me the app logs, maybe I can see a little more there.
Log file is small so hope to catch it.
@Jeroen_Tebbens maybe a stupid question but I cannot find the toggle to switch off the water meter .:thinking:
Its in advanced settings of the P1
Diagnostic “EV starts charging and when the batteries go in Standby modus, it automatically changes back to Slim Laden modus within a couple of minutes”:
512ce4f7-e1f2-44c2-b233-e9a432d20c33
Timestamps:
14:36 Started flow manually to force Standby modus
14:45 Slim Laden modus automatically enabled again
Tried this?
Ah that’s seems exactly what I need, will configure this right now. Thx
