[APP][Pro] Homewizard πŸ§™β€β™‚οΈ
Should be fixed in v3.15.105. I only had my own policy mode, not predictive (SlimLaden) as this is disables the policy fully and bypasses the EV card actions.
EV card start β†’ stops current mode β†’ standby
EV card stop β†’ restores predictive (last mode before start)
Thx, I will test it
since yesterday my homewizard app crashed every 5 minutes
report: 7fec459f-9b56-488c-a18f-55e4ad0ef39b.
Jeroen do you have any idea?
Works like a charm the new update!
(EV card start β†’ stops current mode β†’ standby & EV card stop β†’ restores predictive (last mode before start))
Yes your issue, should be fixed in latest test version pushed as v3.15.106
Hi Jeroen, it is better after the update but i have still 6 crashes in an hour
Report: 2d118101-b26b-4dc4-8841-bb361652fdd1
Check new test version v3.15.107 (Export trigger card error)
Jeroen, thanks for the quick answer, again tested and it will still crashing.
report: 66c03585-6e04-4b42-80e8-e3bd68d1a8e0.
see the Ram as well:
Do you have a plugin battery as energy_v2 seems struggling with the information as what I see in the log.
Jeroen, i don’t have a plugin battery.
what i have:
  • 1 x p1 meter
  • 1 x watermeter
  • 3 x energy socket
  • 2x 1 fase kwh meter (solar panels / heatpump)
  • 1x 3 fase kwh meter (solar panels)
Thanks that makes it easier to resolve. As recent firmware has plugin battery information in the payload by default it goes wrong in adding / removing capabilities that are inside the P1.
In your case it keeps addding/removing plugin battery capabilities which ends up in memory issues.
New test version v3.15.108 for you
Hi Jeroen, i have test it and at this moment it will still crash 3 times last hour. (see de picture).
report: db02245b-617d-4a05-bf07-5ff65f3bc421
Yes, found it, and added guards on your SDM230 and SDM630 devices as the 1s interval you have is in your situation to rough making the app crash. Added some guards to improve this to avoid crashes.
v3.15.109 is now in test
Thanks again, its looks better but not perfect. Last hour i had 2 crashes.
report: 6c74be95-c6ef-4605-9e25-82aa26fa5433
Ok new test version with some added debug to understand your issue.
still having the issue,
Version .111? If so sent diag report
testing it at the moment
Hey Jeroen,
The issue looked solved, only i see every 5 minutes a peek in the RAM and de CPU. is this normal?
report: b2a7ceb2-40a5-4902-b8d5-9cc16b08f333
