This should be fixed in v3.12.9 (in test now)
Yes, looks good! Thanks for the Quick fix!
My water meter stopped working after the v3.12.9 update. The device shows the error âmissing URLâ. I tried removing and re-adding the device, but I get the message âNo new devices found on the networkâ. The device cannot be discovered in any way. The P1 meter is also no longer detected after the update. Has anything changed in this update?
Sounds like mDNS/wifi problem. Check the device fetch debug tab in the app settings for clues.
Thanks, the Device Fetch Debug tab was empty: no fetch logs available. Iâve resolved the issue by completely removing all HomeWizard devices, uninstalling the HomeWizard app, restarting Homey, and then setting everything up again. Iâm not sure what caused the issue, but I noticed that the problems started immediately after the v3.12.9 update, which is why I linked it to the update.
I have no issues with my watermeter else I wouldnt release this update either. Removing a device is not always the solution. First post in this topic hints on steps to try first.
It must have been a mDNS issue as you refer to URL not found which indicates the fallback mechanism also was unable to recover it.
Here also no issues with the watermeter since update V3.12.9. Using the value L/m in flows and working fine.
My energy meter displays an exclamation mark. It usually worked fine in the past.
When I restart the app, it displays a value for a few moments, after which an exclamation mark appears again. So the app is detecting it.
Iâve read that removing a device isnât always the solution. What could be the problem, and whatâs the solution?
I canât answer that. Wifi/network problem at your end. Either your Homey has issues or your P1 has troubles.
Clearly timeout that a query done from Homey doesnât get a response from your P1 dongle within 5sec. Hence timeout.
Interesting. The energy device is the only thing in my house with troubles. Itâs about 20-30 cm below the router, as it always was. changed the polling interval to 8 seconds, no difference.
After restarting the app the device does have connection, as I see a value. After that the connection is lost.
The watermeter works differently, doesnât use the P1 meter. Do you know of any other way I can test the P1 meter?
20-30cm from your router doesnât mean it connected to that router. I have an access point in my âmeterkastâ but my P1 is connected currently to my âwoonkamerâ access point.
I suggest you check your router a see where you P1 is connected. First post in this topic has more suggestions to check as well.
I understand your frustration or the illogical state your P1 and/or your Homey is. But it is impossible for me to point the exact cause of this problem. I can only drive on what the log tells us and that is timeout.
I am clueless on what your wifi set up is. Configuration of your WiFi your network, how many accesspoints, which brand, which firmware, is your P1 extra usb power or only directly powered by your smart meter?
So many different variables that have influence on this that I am have no idea (yet).
Youâre absolutely right. You canât check my wireless configuration because of so many variables.
The P1 meter is connected to the access point in my âmeterkastâ, the one situated 20-30 cm away from it. I use a Deco B95 with its latest firmware. The P1 meter gas a fixed IP-address. It has an extra USB power, not just from the P1 port.
First I will unplug and plug the power adapter. If that doesnât help, I will connect the device to a different access point, maybe that changes the situation.
Will keep you posted.
EDIT: after unplugging the adapter and plugging it back in, the energy meter functions as it should be! So everything is back to normal!!
test/beta
v3.13.0
- Watermeter - battery based (via cloud hwenergy only 4x updates a day)
NOTE: This is best effort as this is cloud based and depends on your own internet and what Homewizard Energy platform allows.
If Homewizard Energy is down or is under maintenance you get errors or incorrect data.
Thank your for update and feedback.
I have exactly the same issue since one day with both meters. When using a MDNS discovery tool I see both devices (P1 and water) so it looks like this is not a problem. I now rebooted my Homey and I have connection again. Homey is wired. There was no problem with information on HWDisplay, only in combination with Homey. Hopefully reboot fixed the issue for now
test / beta
v3.13.8
- Homewizard Legacy Device updates (CSS, flow and language) - thanks smarthomesvan
- Plugin Battery state of charge icon added as tile for dashboard
EXPERIMENTAL (still prone to changes as it still needs to be validated with Homewizard)
- P1 meters can now be connected via HomeWizard cloud API (Based on cloud API research by Sven Serlier)
- P1 (apiv2) - tariff trigger fix
- Bugfix: capability_already_exists (cloud_p1)
If Homewizard Energy is down or is under maintenance or change their hwenergy web frontend you get errors or incorrect data.
My app keeps crashing multiple times a day. Anyone else having the same problem since the last update?
5768138e-1437-4570-87f0-cf452baeebe5
