[APP][Pro] Homewizard 🧙‍♂️
Sorry I see nothing or what goes wrong on your end.
No timeouts, no errors, yet you do not see updates in your P1 measurements.
Stack trace
Note: this log has been manually submitted by a user.
Log ID: 5f7c9249-0bab-43ec-af2e-207f58a5d03f
User Message:
P1 measurements do not update
---- stdout ----
2026-01-14T09:15:46.339Z [log] [HomeWizardApp] HomeWizard app ready!
2026-01-14T09:15:48.922Z [log] [ManagerDrivers] [Driver:energy] [Device:c747c9cb-27df-4406-9fa5-e0cd21a32c17] Restored URL from settings: http://192.168.0.87:80/api/v1
2026-01-14T09:15:49.277Z [log] [ManagerDrivers] [Driver:energy] [Device:c747c9cb-27df-4406-9fa5-e0cd21a32c17] Discovered device URL: http://192.168.0.87:80/api/v1
---- stderr ----
@Jeroen_Tebbens exactly, no P1 updates after the update of the app
Yep, same here. No updates on P1 apiv1. Seems like apiv2 does update.
No more updates on P1.
Rapport 5a428212-bbdc-462e-ba6c-a2693f6a1aa5
Same here, also no updates on the P1 meter. Stopped working with the update.
424ef814-aa33-48c4-a57f-1263138b7c0e
Strange, my Homey Pro 2023 has no issues as what I use for test.
But when I try it on my Self Hosted Server it doesn’t work anymore.
I am receiving an empty body from the P1 as JSON packet. Weird.
After the last update my P1 meter crashes. After a reboot of the HomeWizard app, I can get my information from the P1 meter again, until it crashed again.
In the Homey Energie Dashboard, you see a flat line, after the reboot of the HomeWizard App, it is working again.
Report code is: 8b4a2fba-62a3-44e8-9d88-7a34681afafe
Not working to my two P1 meters, homey pro 2019.
Can I step back to previous stable version?
the local api works from my computer, and mdns messages are there.
2898731f-abfa-4d62-9f4c-b477ee0d5560
Maybe we should support you with an old Homey Pro 2019? :slight_smile:
Am really lost, my Homey Pro 2023 is fine. Gets data for P1 both APIv1 and apiv2. But same code on SHS doesn’t update. Trying to find the difference of node-fetch failing.
It is on my Homey Pro 2023 that I get no updated data for P1
@Patrick3 @nogren @KSBahorie @_gertjan @FrankP @PaoloF
Please try v3.10.13 (test)
@Jeroen_Tebbens now it works again
Good, let me push it with priority.
EDIT: already live
@Jeroen_Tebbens, I installed the test version and it is working. I will keep this version for 24 / 48 hours to check if it will crash again.
Working again with v13
Yes, also from my side this works again! Tnx!
Here also working again with v13. :+1:
Thanks!
I experienced an issue with the new app where the data was no longer being updated after the update. I’ve now removed everything and set it up again, so I’ll see how long it keeps running properly.
Which version? I went through some pain today. Please be specific and perhaps read up this few posts.
test/beta
v3.11.0
  • P1 energy modified to modular
  • P1 energy_v2 modified to modular
  • Heatlink additional code check on set target_temperature
