[APP][Pro] Homewizard 🧙‍♂️
Oh wow, great find. :+1:t2:
Wifi can be nice but also full of surprises.
Thank you for your donation :heart: just received it.
v3.10.8 (test/beta)
  • SDM630 added per phase kwh meter tracking (estimate) + daily kwh meter (also estimate)
NOTE: This is an estimate based on polling interval. The SDM630 does not track per phase kwh so this is a calculated attempt based on Watts per phase. If bad wifi or Homey can’t reach the SDM630 the measured value will be lower than the actual data.
Hi all,
Since 3 days now (since january 10th), the values for Dagverbruik (kWh) and Dagverbruik gas (m³) are not reset to 0 anymore as they used to at midnight. Instead the values keep adding up, showing the sum of usage of the past days instead of only the usage of today.
I’m not sure if this could be an issue with the recent version(s) of the Homey app for Homewizard, or more an issue with the P1 dongle (firmware) itself… Is anyone else experiencing the same issue?
Thx!
Wout
Which version are you?
Now on 3.10.7 (homey app), and P1 dongle firmware 6.0206 (since this morning, so not sure if the FW update could fix the issue?)
Version v3.10.7 has a fix for daily reset gas usage. When did you get that update?
Mine didnt reset on 10th Jan due to me coding at 0:00 o’ clock so it missed the timer reset.
But it does work, so please check and see if it resets tonight.
I received the update v3.10.7 yesterday afternoon. I do see Homey wasn’t receiving any updates from the P1 dongle since 18h00 yesterday. I had to restart the homewizard app on Homey this morning to get it connected again, maybe this is the reason the values didn’t reset. I will check tomorrow if it’s fixed.
Thx for the quick assistance!
Hm that might be the smoking gun, polling stopped and didnt execute the nigth time reset somehow. I added more checks. Try the test version v3.10.10 which is available now:
Sinds the update for version 3.10.5 the watermeter does not get the value from energie link.
That is unfortunate, let me check. Energylink did get an update so might have missed something.
OK found and fix in version v3.10.12. Currently in test but when ok I will deploy it to stable later this week.
It looks like it is working again. Tanks.
Good, then I’ll push this version.
v3.10.12 now live
I also confirm the Dagverbruik counters are reset at midnight now (still on version 3.10.7, will update to the latest version later today). Thx for your dedication to develop this app!
@Jeroen_Tebbens P1 meaurements are not updated correctly after latest update
Check app settings device fetch debug to see if P1 connection is timing out.
Both my P1 apiv1 and apiv2 are fine with v3.10.12 here.
@Jeroen_Tebbens, no, it’s not timing out
Drop me a diagnostics please
@Jeroen_Tebbens 5f7c9249-0bab-43ec-af2e-207f58a5d03f
