[APP][Pro] Homewizard 🧙‍♂️
I know it does not say a lot, but the Homey is in between the kWh meter and that accespoint
I guas the distance from:
accespoint to homey is 2 m
Accespoint to kWh is 8 m
Homey to kWh is 7 m
No wals one big room(barn)
I wil reboot homey
I did a reboot and unfortaly i did not mention a difference
Stil 1.7A with only 10w of usage. But don’t spend to much time on it i wil run my own calculations thank for youre time! And if you wil put time in it and need data just text me, i is only smal effort to send compaird to youre time you put in the app!
Homey communicates to your kWh via your wifi. If there are other noise sources on the WiFi channel used then distance doesn’t matter. Noise is noise.
Try to talk to talk someone next you while a F16 jet fighter takes off with afterburner :sweat_smile:
The only noise i can think of is zigbee but wifi is set on channal 1 and 2 and zigbee at 19 so that sould work
If i use 5000w on one phase the math does at up and then the Amp give the right value
If i use 1250w on one phase the math does alt up and the the Amp give the right value
From where i’m right now i can’t check with lower Watt levels
It is just an example. My only hunch / lead is that a capability in a screenshot has a 1 minute last update while it should be 10s or less. Something is disturbing that update process.
Is it posible that in that one min no change hase happend?
There where only some lights on at that moment
When i use a big consumer it the update time is always “a few second ago”
Hard to believe for Amps that fluctuates a lot even with 2 decimals.
Btw thanks for your paypal donation :heart:
Please share me the output of your SDM630:
http://10.1.0.224:80/api/v1
i think i wil go tomorrow to the location where the device is, i wil bring my laptop and look in to it.
do i just need to pres that link when i’m on the same local network as the SDM630?
Yes, assuming the kwh meter keeps its ip (static?).
I reconnect them to the WiFi and that did the trick.(restarting my accespoints didn’t do the trick) I got my second 3phase meter also connected.
I have 2 P1 meters (on two digitaal meters day/night and excl. Nicht) ans 2 3phase kWh Meyers. Everything works now as I would wanted. Thanks for the tip and for the app :slightly_smiling_face:
Multicast DNS has its good and bad things.
Good to hear it resolved now.:+1:t2:
v3.7.3 is live.
v3.7.4 live
  • Extra check upon websocket creation to avoid crashes
  • Plugin battery catch all error (unhandled exception)
  • Additional checking and error handling on bad wifi connections (websocket based)
Strange thing happened. I did see a red error on my devices and went to the Settings –> App → HomeWizard and tried to restart the app. Then I got this error message “App not installed”
After reinstalling the same error occurs!
Update goes wrong.
It toke several minutes for the app was visible again in the Homey app. But it is not complete. Tries to restart the app and get an error App not installed.
@Arnold_vd_Linden Oehhhfff. I thought it was something locally only.
Great app but my homey just shows my homewizard devices not available. When trying to restart app it tells me not installed… reinstalled the app but no difference.
I read now more people have this problem.
@Jeroen_Tebbens are you seeing these messages with the same issue?
same here. all of my Homewizard devices offline and Homey is saying the Homewizard app is not installed. Re-install also not working. There was also an Homey update (12.8.1)
Seems the upload got corrupted again…I dont understand why…
