[APP][Pro] Homewizard πŸ§™β€β™‚οΈ
My diagnosis report
68c41fb3-7e93-425d-98b2-ef59aaed9210
Alright as expected the cards I added not working yet need to add some more error control. What firmware does your P1 have?
2025-05-11T11:24:11.816Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:8d68dcd4-dd59-47ee-aae6-97a64e6e1d5e] Settings: {
  oldSettings: { mode: 'zero', polling_interval: 2 },
  changedKeys: [ 'polling_interval' ],
  newSettings: { mode: 'zero', polling_interval: 10 }
2025-05-11T11:24:11.820Z [log] [ManagerDrivers] [Driver:energy_v2] [Device:8d68dcd4-dd59-47ee-aae6-97a64e6e1d5e] Polling_interval for P1 changed to: 10
    stderr:
    2025-05-11T11:27:45.342Z [err] [ManagerDrivers] [Driver:energy_v2] [Device:8d68dcd4-dd59-47ee-aae6-97a64e6e1d5e] Error: Not Found
    at module.exports.api.getMode (/app/includes/v2/Api.js:88:26)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async /app/drivers/energy_v2/device.js:364:27
Firmware version: 6.0112
Yeah cards will fail if firmware is lower than 6.0200
Thx need to see a way to avoid that.
So back to the stable version for now?
Yes sorry, still beta with loopholes so for your own comfort use stable till I can avoid it.
Stable version reinstalled. P1 v2 works normally again.
Yeah thanks for confirming that, the cards rely on that beta firmware 6.0200
beta/test
v3.6.13
  • Extra firmware check for P1apiv2 to avoid errors / unavailable
Sorry, the same problem as before today.
5d9f36b7-66ac-46d1-a6bf-c56c32481f89
Ok I give up. I will wait till that current version goes live.
@johan_W thank you for your donation :heart:
beta/test
v3.6.16
  • Bug fix for P1(apiv2) to ignore cards for older firmware version 6.0200
  • Additional logging Plugin Battery mode get/set. Wifi metric added for P1(apiv2) and Battery
  • RSSI capability fix for P1apiv2 and PluginBattery
  • meterPowerImportedCapability and meterPowerExportedCapability added for Plugin Battery (Homey firmware 12.4.5)
  • Custom polling plugin battery added, default 10s
Sorry, still a problem on 6.0112
76aceebd-8811-472d-8bd0-590a3a94b606
Since version 3.6. 13 I have the problem that the signal to the battery is broken and restored and it keeps going on like this. Also the PiB gets upset and starts charging, pausing and continuing
Get latest test version, that one lowers the polling interval for the battery.
It seems to be going well now, we’ll have to wait another day but it looks very promising!
There was another user with the same issue (time-out connections to battery). I made polling now custom as well and forced to 10s default.
I had the same problem with my battery.
Installed the beta version but the p1 apiv2 device isn’t available on my Homey Pro 2023
Please sent a diagnostics report.
