Trigger and action cards with eventname for Advanced Flows.
Very lightweight app for adding multiple triggers with tags on a single flow, by adding a event name.
The flow can be triggered using optional arguments.
Just create a trigger (When), type the name and select it, then select it in the actioncard (Then).
You can also create an actioncard (Then) first, type and select a name, and then select it in the trigger (When).
(sometimes you will need to save the flow before the name becomes available in the cards.)
Triggers can be overloadable, meaning, you can select and trigger a When card with 10 arguments from a Then card with just 1 argument.
Click here for an in-depth explaination of the Debounce function.
Debounce can be set on triggers (When cards): meaning you can manage how many times and in what way flows get executed within a certain periode.
- Execute last one waiting after each [number of] ms.
- Execute at start, then allow execution after each [number of] ms.
- Execute at start, then allow execution after each [number of] ms, finish with last one waiting.
(Please note the extra delays during testing in Advanced Flows.)
These cards execute almost instantly, as suppose to the default Start-A-Flow cards half a second delay.
Please report issues or feature requests at QlusterIT / nl.qluster-it.AdvancedTriggers / issues — Bitbucket.
If you have any suggestions for the App, just let me know!
If you like the app, please leave a rating in the Store: Advanced Triggers App voor Homey | Homey
