Nedis wifi led strip, can't get it to pair with homey pro
Hi. As the topic says, I am trying to pair a nedis wifi led strip to homey pro, under tuya zigbee in the app i select the rgb led strip controller, and there it says under the pairing process the led strip should be blinking green, but mine is blinking red, so am i using the wrong setup or is it not supported, for homey pro?
Is it wifi or zigbee device?
If wifi:
If zigbee:
Here you can check if it’s supported, and if not, how to request support for it.
