Lidl Smart LED Strip (RGB)
Got Lidl Smart LED Light strip (RGB) but cannot seem to get going.
It pairs to my HP23 but mainly only turns on or off (and dims).
Even tried the Tuya RGB LED strip and RGB LED controller but same poor result.
Is this a new version not recognized?
Any hope to add it to the Lidl or Tuya app?
On this page is a link to the Lidl app topic.
Maybe you can ask it overthere.
https://homey.app/nl-nl/app/com.lidl/Lidl-Smart-Home/
With the link “Vist forum” you wil directed to the Tuya page.
https://community.homey.app/t/app-pro-tuya-zigbee-app/26439
There you will also find info how to add a device to the app.
You have to interview the device.
It’s a _TZ3000_riwp3k79 TS0505A
Do we really just rely on like one guy to be adding all these manufacturing ID’s?
Did you tried the test version of the app?
Your device is on the list with known devices.
It started to work ‘after a while’.
Description said in the Tuya app thread that Lidl may need at least 10min to fully connect…
Using Lidl app though.
Case closed.
Ah! I forgot about this: for a next time, interviewing the device sometimes ‘unlocks’ previously unavailable capabilities.
Yes, but PR’s are accepted.
And if it only were “adding ID’s” it wouldn’t be time consuming/difficult.
It worked for me, I couldn’t change colors and after interviewing it worked again! Thanks for the tip!
Worked for me too ! Same initial issue: only On / Off (no Dim, No color). After the Interview, it started to fully work.
  "ids": {
    "modelId": "TS0505A",
    "manufacturerName": "_TZ3000_riwp3k79"
  "endpoints": {
    "ieeeAddress": "cc:86:ec:ff:fe:56:b6:b4",
    "networkAddress": 32654,
    "manufacturerName": "_TZ3000_riwp3k79",
    "endpointDescriptors": [
        "status": "SUCCESS",
        "nwkAddrOfInterest": 32654,
        "_reserved": 28,
        "endpointId": 1,
        "applicationProfileId": 260,
        "applicationDeviceId": 269,
        "_reserved1": 1,
        "inputClusters": [
          0,
          3,
          4,
          5,
          6,
          8,
          768,
          4096
        "outputClusters": [
          25,
          10
        "_reserved": 10,
        "endpointId": 242,
        "applicationProfileId": 41440,
        "applicationDeviceId": 97,
        "_reserved1": 0,
        "inputClusters": [],
        "outputClusters": [
          33
    "deviceType": "router",
    "receiveWhenIdle": true,
    "capabilities": {
      "alternatePANCoordinator": false,
      "deviceType": true,
      "powerSourceMains": true,
      "security": false,
      "allocateAddress": true
    "extendedEndpointDescriptors": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "zclVersion",
                "value": 3,
                "reportingConfiguration": {
                  "status": "NOT_FOUND",
                  "direction": "reported"
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "name": "appVersion",
                "value": 80,
                  "direction": "reported",
                  "attributeDataType": 32,
                  "minInterval": 1,
                  "maxInterval": 150,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "name": "stackVersion",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "hwVersion",
                "value": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "name": "manufacturerName",
                "value": "_TZ3000_riwp3k79",
                "acl": [
                  "readable",
                  "reportable"
                "id": 5,
                "name": "modelId",
                "value": "TS0505A",
                "acl": [
                  "readable",
                  "reportable"
                "id": 6,
                "name": "dateCode",
                "value": "",
                "acl": [
                  "readable",
                  "reportable"
                "id": 7,
                "name": "powerSource",
                "value": "mains",
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 65502,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "name": "clusterRevision",
                "value": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65534,
                "name": "attributeReportingStatus",
                "value": "PENDING",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65504,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65505,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65506,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65507,
            "commandsGenerated": "UNSUP_GENERAL_COMMAND",
            "commandsReceived": "UNSUP_GENERAL_COMMAND"
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "name": "identifyTime",
                "value": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
          "groups": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "nameSupport",
                "value": {
                  "type": "Buffer",
                  "data": [
                    0
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "scenes": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "acl": [
                  "readable",
                  "reportable"
                "id": 1,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "acl": [
                  "readable",
                  "reportable"
                "id": 4,
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "onOff": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "onOff",
                "value": false,
                  "attributeDataType": 16,
                  "minInterval": 1,
                  "maxInterval": 65534,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
          "levelControl": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "currentLevel",
                "value": 255,
                  "minInterval": 1,
                  "minChange": 0,
                  "status": "SUCCESS"
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 1,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 15,
          "colorControl": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 0,
                "name": "currentHue",
                "value": 0,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 1,
                "name": "currentSaturation",
                "value": 254,
                "acl": [
                  "readable",
                  "reportable"
                "id": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 3,
                "name": "currentX",
                "value": 45874,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 4,
                "name": "currentY",
                "value": 19660,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 7,
                "name": "colorTemperatureMireds",
                "value": 216,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 8,
                "name": "colorMode",
                "value": "colorTemperatureMireds",
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
                "acl": [
                  "readable",
                  "writable",
                  "reportable"
                "id": 15,
                "acl": [
                  "readable",
                  "reportable"
                "id": 61440,
                "acl": [
                  "readable",
                  "reportable"
                "id": 61441,
                "acl": [
                  "readable",
                  "reportable"
                "id": 61442,
                "acl": [
                  "readable",
                  "reportable"
                "id": 61443,
                "acl": [
                  "readable",
                  "reportable"
                "id": 61444,
          "touchlink": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 65533,
                "value": 2,
        "bindings": {
          "ota": {},
          "time": {
            "attributes": [],
      "242": {
        "clusters": {},
        "bindings": {}
