INNR SP240 smart plug
For everyone stumbling over this thread and wondering about Homey capabilities for OTA firmware updates. Homey Podcast #3 is answering that question.
If manufacturers would provide the firmware files, then
  • Z-Wave - definitely possible
  • Zigbee - possible through the vendor app
  • Matter - to be standardized by the standard itself
Sure.
I’ll repeat what I wrote here:
They say that developers can implement OTA updates (also for Zigbee), but they don’t explain how or provide any example code, nor do they implement firmware updates for any of their own apps. They’re basically putting the blame on the developers for not implementing this feature, which IMO is really bad (but typical).
Until Athom shows us an actual working example, I’m calling BS that it’s even possible.
I cannot judge that, but if the situation is as you are writing it really unfortunate for the end customers. On the other hand or would be pretty easy for the manufacturers to provide firmware updates through a basic smartphone app. I have the Zigbee power switches where Bluetooth is used to push a new firmware to the device.
But let’s stay optimistic that the situation will change in the future. :slight_smile:
But that assumes that all Zigbee devices also have Bluetooth, and most of them don’t.
With protocols that aren’t supported directly by smartphones (Zigbee, Z-Wave) you have to rely on hubs like Homey to provide OTA update functionality.
It’s a question of design, starting with the developments of such devices.
If companies would take information security and customer centricity serious we wouldn’t be in the situation we are. I am well aware that this would be a best case scenario, but that not only one company comes even close to that scenario…
I would suggest that this is exactly why we’re in this situation: most brands are very reluctant to provide information about their devices to make them work with other hubs, because they cannot control those hubs.
Who would a user blame if they perform a firmware update through a third-party hub which bricks the device? My guess is that in 90% of cases that will be either the device manufacturer or the device’s seller (as a warranty claim).
So most manufacturers think that keeping this information (including firmware updates) secret benefits the user, or will at least prevent warranty claims (and yes, you can argue whether this train of thought is correct, and it’s probably not).
Providing an alternative method of firmware updates, like your Zigbee device that also has Bluetooth, costs money and, if you consider that the manufacturer assumes that users will use their hub anyway, unnecessary.
Just chiming in to say that the Innr SP240 plugs are still not reliably reporting power consumption stats as of November 2024. Repairing works for a time until the power is cut for any random reason (or not…).
Apologies for the random tag @Doekse , but it is possible to add a note about this issue in the Best Buy guide until this issue is fully resolved? I tried to find Dino on the forum here, but no luck figuring out what his handle is. :frowning:
Same here. I’m not so happy with INNR these days, I started with some SP120’s which still work perfectly and do measuresment, next came the SP220’s which lacked the reporting completely. I was happy to see they included measurment in the new SP240 untill I received them and realized how bulky they are. It’s so bulky it blocks the second outlet to be used :exploding_head:
Maybe we should all send back these newer models and ask them to go back to the SP120 revision! :wink:
I have been in contact with INNR’s support desk (and to a lesser extent with the INNR Homey app developer) over the last four months on two issues with all of my SP240 plugs:
  • Homey stops reporting power measuring data after unplugging the SP240 plug (on/off function still works). A re-pair is required in Homey to re-enable the power measuring reporting;
  • After every restart of Homey, the current value displayed by Homey is 1000x higher than the actual value reported by de SP240 plug. Either restarting the INNR app on Homey or re-pairing the plug solves this issue, until the next reboot.
Apparently this behavior is caused by bugs in the SP240’s firmware. All my SP240 plugs are on firmware version 1.4.3.
There is a new version of the firmware available though (v1.7.22) that should solve these issues. However:
  • You need INNR’s bridge/hub to update the firmware;
  • This bridge currently does not support the update process. INNR is working on that.
I understand that an alternative is to update those plugs via HA/Zigbee2MQTT (as the new firmware is publicly available). Of course you need such a hardware setup to do that, which I don’t have.
In my case, INNR sent my one of their bridges, while I wait for them to enable the software update functionality.
If INNR would support firmware updates via Homey that would be awesome. I would then hope for other manufacturer to follow this example. This could be a game changer for the support of Zigbee devices on Homey.
If Homey would support Zigbee firmware updates, that would be awesome.
Athom keeps saying that technically it’s possible for apps to implement firmware updates for Zigbee devices, but no one has ever seen an app that supports it, not even Athom apps themselves.
Although I do agree zigbee firmware updating should be supported out-of-the-box, but ā€˜gamechanger’ is not the word I would use myself :man_shrugging:
I did not have to / did not felt the need to update firmware of any my zigbee devices in the last 4 years.
Of course it all depends on the devices used.
SCNR - so you are confirming my statement if INNR would support firmware updates via Homey. :slight_smile:
Nevertheless, semantics. I take now a very end user centric position. I do not care who needs to make it happen. To have IoT devices where the firmware cannot be updated (assuming vendors are providing firmware updates) should not even be a discussion point in 2024.
Well, I am forced by the industry to either have a multitude of hubs from different vendors or allow IoT devices with firmwares that cannot be updated. More hubs connected to the internet is increasing my risk profile in terms of information security. Having unpatchable end devices also. Game changer might be a bit hefty, but it would be big, at least for me. :slight_smile:
What I find really strange is that this isn’t mentioned in the Best Buy guide in Homey.
I bought the Innr plug specifically because I read the Best Buy guide.
Apparently the only way to improve things, is to report your findings to homey.app/support.
It seems that, after a power-outage, the device needs to be repaired in Homey (Press and hold the button 5 seconds). I did this and the network-id changed and Homey receives the metered values.
This is indeed the workaround. For what it’s worth, I’ve had great luck with the newest plugs from Ikea (INSPELNING). They’re also €10/each around here. The Ikea plugs are a bit bigger than the Innr plugs, but if you don’t need them to move ever and they fit, then they seem to work well. I did some electrical work this week and had to cut power and the Ikea plugs kept reporting correctly after the power was restored.
I just got the INNR SP240 plug. When trying to connect it nothing happends. I installed the app, search for the device in the app. It then tells me to hold the power button for 5 seconds and release.
I did that, but nothing happens. It will eventually just time out. I tried restarting my homey and completely pulling out the plug.
Model Homey (Early 2016)
Version 12.2.0
