Hey @tumtum100 thanks.
Thats the same issue as described above.
This answer also applies to you
Thank you for your fast answer. I added debug in the device and made a new report.
Changelog:
- FIX: range + distance_driven (ID / CUPRA / ETRON)
Changelog:
Changelog:
Changelog:
Thank you very much it is fixed now
Nice!
Indeed, iobreaker changed the tree from odometerMeasurement to odometerStatus. Same goes for rangeMeasurement changed to rangeStatus.
1.11.4 installed and now updating again, thanks!
Hi Martijn
You have made an app for the majority of the VAG groups cars.
Any chance a myPorsche app is on the way
Regards
Casper
Hi Martijn,
Do you know if there are more options or status of the car available if you get the update me3.0 of the car? I mean in the homey app.
Hey @Maikel_Van_de_Wouw
Currently not. Me3.0 requires a new Api which doesn’t work properly yet in the Homey app
@martijnpoppen I know now for sure that my login is correct. I also reset my S Pïn but I keep getting the same problem. Any other ideas what might cause this?
Hi, thanks for great app. I just updated my VW ID.4 to 3.0. Should I change anything in the Homey app? The native VW Connect app now “knows” where the car is parked for example. Is that anything that I can use in the Homey app?
Hey @koolla
This app is not updated yet. I’ll have a look soon if I can get that data out of there.!
Hi Martijn,
First of all, thank you for the great app and the work you put into it.
For a few days I have no longer been able to see the parameter: “Remaining Climate Time”.
Has Audi screwed on the API again?
Hey @Tregobad
I’ll have a look
Can you enable debug in the device settings and after that send diagnostic report?
you can do that via the mobile homey app:
More - apps - MyAudi - settings wheel right top - send diagnostic report
Hi Martijn,
that was fast.
I just activated debugging and started the heating, or then stopped it again immediately.
How do I send you the debug report, where is the report?
I just sent
do you need the code?
No I get an email
If you need more, let me know.
Many thanks
