@Tregobad seems like these changes are the same as for the VW ID cars.
Will make a update soon
Many thanks for your very fast reply.
It looks like Audi woke up for Christmas. The “Remaining Climate Time” is displayed again.
Strange! I will still look at the data. I think some things can be updated there
Nothing happens when charger is plugged in and I start charging in app
E-tron 55 from 21
I’ll have a look
Can you enable debug in the device settings and after that send diagnostic report?
you can do that via the mobile homey app:
More - apps - MyAudi - settings wheel right top - send diagnostic report
Done
3d7839da-c96c-4b48-9ac3-0b8cf9bdf775
Ah looks like the wrong car is selected
When you add the car you have 2 options
Make sure to select the bottom one:
So removing and re-adding should work
Hi @martijnpoppen
Love youre work!
Had the myskoda app with my old car superb iv
And now with my Enyaq iv80x
But seem to having trouble with the functions.
The app is conncted to the car. I gett updated driven km and if cable is connected and so on but i cant get the buttons to work.
Tried with the start charging especially but it wont work.
Tried with deleting the car and connect again but it wont work.
Tried to find something in the thread but culd not find anything or ive missed it.
Have any ideas?
And a tip
This thread is super long and is about multiple apps. Is it possible to split the threds up in separet to wich app you are using?
Maby this is not nessessary cause all apps ar the same?
Love your work
Your awesome
Regards
Hey @Niklas_Aggemyr
Thanks a lot
Yeah the buttons for the Enyaq are still not working properly unfortunately.
Theres a new Api available but that breaks the updates to the car.
I’ll have to dive in to this soon. Hopefully I can get it working
Im using the same integration as the IObroker one and there it also doesn’t work for the Enyaq
Hmm yeah i was thinking the same when i build the app. But under the hood all the apps are the same. So when i make a update for Skoda i have to update the other brands too. So in the end communication wise its better to have everything in one thread.
What i’ll do for now is expand the FAQ a bit. Then at least its written down for the Enyaq
And thanks again
Greatings, and happy new year.
Just before newyear I got my e-tron. I’ve got the ios app up and running, but it doen’t look like I’m able to control anything at my car thru homey.
I’ve tried to log on with the “after 2021” and I get no control, only reading batt stat, range, driven milage.
I tried to log on with the version for older cars. With this I get a lot more readings, but still no control.
Is there anything I need to activate in the my audi app (ios) or on the my audi website?
I’d also have a request for new version, to have reading if car is home or not (like I can for my e-golf). -I’ve got use for it in some of my flows…
Thanx!
Hi @Kjetil_Kvamme
Happy new year to you too
That’s strange…
Can you do the following?
- add the car to your Homey with the bottom option (new Audi 2021).
- After adding enable debug in the device settings.
- Then try something to control,
- send a diagnotisc report (via the mobile homey app: More - apps - myAudi - settings wheel right top - send diagnostic report)
No should work…
Unofrtunately not possible at the moment for VW ID / Cupra EV / Audi Etron / Skoda Enyaq. Heard last week that for VW ID it might be possible, so I expect it soon to be there too for Audi
Hi Marti. Just sent an diagnosticreport.
@Kjetil_Kvamme not sure whats going wrong , but looks like your Audi decided to be a VW.
Can you delete the car and re-add it and after that send a new report ?
@martijnpoppen deleted the car (unit) and the app. Installed the app again, and the car. Sent new report.
@martijnpoppen thanx for good help and great work so far! Give med a shout if you need more tests and reports from me!
I’ve got to mention; I’ve allready got an VW e-golf up and running in the vw weconnect app allready.
New app update (test: 1.12.0)
Changelog:
- NEW: Lock/Unlock for ID/E-tron/Cupra cars
- NEW: IsHome for ID/E-tron/Cupra Cars - (FYI @koolla )
- NEW: improve device pairing - error messages
- NEW: improve device pairing - S-PIN after car selection
Changelog:
- NEW: Lock/Unlock for ID/E-tron/Cupra cars ( FYI @Rune_Carlsen)
- NEW: IsHome for ID/E-tron/Cupra Cars ( @Kjetil_Kvamme this should work too )
- FIX: Access token issue - ( FYI @Kjetil_Kvamme )
New app update (test: 1.12.1)
Changelog:
- FIX: Access token issue - FYI ( @KentSoderlund )
- FIX: Skoda app crash
Changelog:
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version →
