Yes still on the todo list → [APP][Pro] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra - #3 by martijnpoppen
I don’t know, I don’t have an Audi
But some brands have limits. But not that I’m aware off. The creator of the Library I use set it on 6 hours with this reason
Thanks @Mari_VW
I’ll have a look at the possibilities
VW ID 4 It worked on previous version. It logged in without error but no data it shown
VW We-Connect app 1.11.1 in use.
Homey version 8.0.8
Car ID3
My car doesn’t update the data either. Stopped updating the data 5.12.2022 12.40. The app was updated to 1.11.1 in 2.12.2022 23.34.
The IObroker adapter is not updating the data either.
The Volkswagen We Connect ID app android app is updating the values.
Restarted the Homey VW We-Connect app a couple of times but no help. Haven’t restarted the Homey yet. Will try that next.
Any ideas are appreciated.
@peltsi51 I think that says it all.
This app uses the iobroker integration.
So if that doens’t work so won’t this app.
I’ll keep an eye on that integration if any updates are available
FYI @Patrik_Strandberg
That’s what I thought also. Let’s see what happens.
I see There’s an update available for the IOBroker integration.
if you update the iobroker integration to 0.0.56 it should work again.
I’ll make a update to this app soon
Good to know, thanks again!
New app update (live: 1.11.2 )
Changelog:
FIX: update WeConnect API
FIX: update Elli Api
Changelog:
Changelog:
Changelog:
-FIX: update WeConnect API
New app update (live: 1.11.3 )
If you find any issues , send a report via the mobile homey app
More - apps - Appname - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@peltsi51 @Patrik_Strandberg Updated the API can you check if it’s working again?
You can force install it by clicking the link above and press the green install button
That was blistering fast. Everything is working
Now it’s working . Thanks for the quick fix
OH2TH
December 7, 2022, 6:44am
1278
Seems that VW ID.3 is not updating anymore. Connects, but doesn’t retrieve current values. Not even with 1.11.2
WE Connect ID and in car the readings are:
Range 145 km
Odometer 1994 km
While this app remains at, which is the state since Saturday morning last driven.
Range 158 km
Odometer 1970 km
Changelog:
FIX: crashes in app due to Weconnect update
Changelog:
Changelog:
Changelog:
-FIX: crashes in app due to Weconnect update
New app update (live: 1.11.4 )
@OH2TH just made an update, hopefully that will fix it.
also it might be that you have to start your car before you get updates.
Due to the updates in the app last days it might be that the force refresh was called too many times and therefore your car won’t update right now. But that’s just an theory
OH2TH
December 7, 2022, 3:32pm
1281
Car has been started. And now what I see from dev tools is that some capabilities have been updated when I came home and plugged the car for charging. However odo and range is not updated
Odo makes sense right if you didn’t drive it. Then the value is still the same. And the value of the range is different than in Homey?
OH2TH
December 7, 2022, 6:24pm
1283
Driven today and odo should be 2023 and range 111. While battery level is updated correctly.
Hello Martijn, first thanks for the app
I made an report for not getting new data for the range for my I’d.3 car
cd7a8f8e-5cad-42a5-a75d-a306f5ac4064
Thanks
@OH2TH if the API doesn’t return a updated value Homey cant update it
If theres a new value then Homey will show it. It think it has to do with the update to the API which was changed recently.
I lookout for a update to the library.
If you want you can sent me a diagnostic report with debug enabled in the device settings. Maybe it gives some more insights
