[APP][Pro] Homewizard 🧙‍♂️
Ooooh energylink hasn’t been updated for that.
I think you will update it, s.a.p. And If you have time for it to do that. Or is this a HWZ issue or a Homey issue?
try test/beta v3.6.1 I added meter_gas as extra capability to support the Homey Energy dashboard.
Oke. I report back sap.
It look like to working. But i do not get incoming triggers for sunpannels. Is this not supported bij energie link.
Please be more specific as I have no clue what triggers you refer to.
In energielink the S1 value are the sun panels thats be giving by the pulser between the main energie and my sun pannels.
Water is seen bij homey, but the s1 value is not show in the dashboard.
Hope you know wat i meen.
Sorry that can’t be done. This is a short coming from Homey where the whole unit gets a Class type. As this Energylink is tracking your overall energy usage it is just like a P1 and it can’t be set both energy tracking AND solar panel hence it will not show up. Same as for P1, you both need a P1 and another device/unit to capture solar usage only then it will start to track what goes in/out and what is solar portion of it.
Oke. Thanks for now and to make the gas value visual
What you can do is create a Virtual Device, make it a solar panel class, copy the values to that device and that will be your solar panel source.
I will try it. Thks
Homey lost connection with 3 plugs. HW works and they have good wifi. (Local api is ON and IP is correct)
Should I remove them and re-connect them or what is the best option to try.
Dont remove…never. As stated in first post, start with reboot/restarting your AP and if that doesnt help your router.
This can mean two things, socket isn’t connected to WiFi or the ip address of the socket has changed and the mDNS update wasn’t received by your Homey.
Thanks, Restart Homey was the solution.
test/beta
v3.6.2
  • Homey Energy dashhboard: Energylink meter_gas capability added
  • Text fix in Plugin Battery driver
  • APIv2 timer timeout problem
Question, I have an SMR 5.0 metre. Yet Homey gives an update every 10 seconds. Is this a limitation in Homey or the Home Wizard API?
Limitation is not the correct word. Initially it was set for 10s.
With latest development on Homey Energy and people more eager on details looking at dropping to 5s. I am checking if 1s is ok with the P1 or not.
5 seconds sounds fine. 1 second perfection
