[APP][Pro] Homewizard 🧙‍♂️
You see: I already told you you’re the best!
But serious: thanks @Jeroen_Tebbens, very much appreciated.
Will install it as soon as it is visible in the (test) app store.
It’s not pushed yet only available locally atm, have a sick kid at home so pretty much bound.
Ah, no problem.
Hope your kid feels better soon!
its in test now
Like a charm!
Thx @Jeroen_Tebbens!
Of course. :sweat_smile:
Version v3.0.2 (SDKv3 compatible) pushed to production awaiting approval.
I can’t connect my water meter. He is on battery can you help or is this a fault?
In battery mode the API is closed/locked. It must be USB powered.
In battery mode it will only connect 4 times a day and not a continuously wifi connection that would allow data retrieval from the watermeter.
Hi, first of all, Jeroen thanks for this app. Works like a charm.
One feature is not cooperating though:
Watermeter offset value cannot be set (anymore?).
When entering anything via advanced options - compensation m3, Homey will report:
“Callback is not a function.”
Has Homewizard limited their API functionality perhaps? (just a thought)
Or am I overseeing something.
Anyhow, setting the offset just within the Homey universe would be great.
SDKv3 bug will check
Fixed in v3.0.3 (now in test)
Just installed v3.0.3. Compensation value for watermeter can be set and stored correctly. Thanks for the quick fix, Jeroen.
No problem, thx for testing and confirmation. Also thx for your donation!
Hi Jeroen,
Great that you are so committed to this app!
Got a little problem,
The power export is not visible in the homey.
I’ve already tried to reconnect everything but it doesn’t show up.
The solar panels have been working for a week now and everything is visible in the Energy app.
Hereby the API data of the p1 meter:
{“smr_version”:50,“meter_model”:“Landis + Gyr LGBBLA4415560672”,“wifi_ssid”:“Foarwei 67D Deco”,“wifi_strength”:100,“total_power_import_t1_kwh”:5308.256,“total_power_import_t2_kwh”:6099.571,“total_power_export_t1_kwh”:0,“total_power_export_t2_kwh”:5.659,“active_power_w”:346,“active_power_l1_w”:346,“active_power_l2_w”:null,“active_power_l3_w”:null,“total_gas_m3”:5266.496,“gas_timestamp”:221108184001}
Maybe it has to do with the fact that we don’t have a T1 export yet, but we do have T2 export?
Everything runs on the latest versions of the apps.
The 1 phase kWh meter works well!
Yes T1 export needs to be 1kwh or more then it will show accordingly.
After a thorough search I found out that our smart meter uses T1 for the ‘‘dal tarief’’ and T2 for the normal rate.
Thats why the T1 export does not increase at this moment when de solarpanels are delivering power.
You probably used all the solar power directly during last weekend hence not delivering energy back to grid. Hence T1 dal stays 0.
Yes thats right.
We will wait this weekend en see what happens.
Thank for de info!
Yeah next weekend will have some sun power if forecasts are right. I will try to improve the code so it will check T2 but doubt it will hit the store before the weekend.
