[APP][Pro] HomeKit Controller voor Homey (NL)
Hello! I having trouble with homekit controler, my FP2 is falling out several times a day and have to restart homekit about every 20 min.
Not so good. PM me the log, code on the unavailable device etc ..
50a703f5-56ec-4ee4-a030-e9e7560cffbc
Can you test with version 1.4.0?
Ok downloaded the version 1.4.0 now, i make it a try.
I’m also testing it as well.
1.4.0 is live. Small bugfix in 1.4.1 (also fix typo in device class airconditioning, that causes fail)
Apologies, 1.4.2 fix for airco value in device store that still causes issues. Hope it is fixed now.
Is there any issues with the lastet version. V1.4.5?
My Aqara FP2’s is not available any more thru homey but they are connected to my network and in works in their own app..
Should not be. Have them running for a long time.
Try an app restart
I tried restarting both the app and homey. They disconnected after the app was updated automatically, earlier today. I also tried to disconnect the power of the sensor :-/
Also no problem with mine v1.4.5 test. I had it one time. And even that it worked on the network, there was a problem with the homekit implementation on the fp2 and so also with homey. I needed to do a power on/ powe off of the fp2 to get it to work
Does the device show a message in Homey or is it doing nothing. In both cases submit a diagnostic report, it might reveal something.
I submitted a ticket: 40273e0b-54e8-498b-a9ca-7eaf7270519c
The sensors hold last known status & values. Connection Alarm is active, and the app tells me to try an switch the power off and on to fix it.. Doesnt help
Made it work again, by deleting the sensors from homey, power them off and on again and then added them again to homey. Dont know if there is a better solution but at least they work again.
I think there is an issue in the repair function of the device. It did remove the pairing with Homekit, so what you did was the only thing you could do. Apologies for the problem, will do some fixing off the repair function.
Since the update to 1.4.5, my Aqara FP2 devices are no longer available in Homey. Unfortunately, the repair process didn’t work either. Since they still work perfectly fine in the Aqara app itself, I thought I’d remove them from Homey and add them again. But when I try to add a new device via the HomeKit Controller, the FP2 doesn’t show up. Does it need to be put into pairing mode again?
Hi ik probeer mijn Homepod mini toe tevoegen aan homey maar ik zie hem maar niet verschijnen.
I told myself: now I’ll take it upon myself, remove the FP2 from Homey, add it again, and recreate all the flows. But now I can’t even get it into Homey anymore. When I add a device, I can select the FP2. But when I enter the PIN, I get the following error message:
OnPair device no longer availabele, power cycle Device and try again
What can I do to be able to use the FP2 again?
Will be pushing an update soon. There seems to be an issue with devices that have timeouts or are unreachable for a short period.
