I’m having some trouble using tis app, or maybe just understanding use cases. I’ve tried adding two Airversa air filters. They are the model AP2, which are Apple HomeKit native devices communicating via Thread to my Apple Home hubs.
I’ve tried to add the via the HomeKit over thread, but, it doesn’t see them. My suspicion is that Homey uses it’s own Thread network and never looks at others. The Thread network created by my Apple Home hubs is never seen by this app.
If I’ve gone off the rails somehow, kindly let me know. If there’s a way to make this app, or Homey Pro itself use my preferred Thread mesh network, that would be nice too.
i have just added a FP2 sensor and set it up in the Aqara app with zones and all,and i can see it in apple home kit
as i now understand it i should be able to add it to homey with the home kit controller app and hom IP but absolutely nothing shows up ??
i just cannot figure out what im doing wrong
i think i hav removed it from home because i cannot see it anymore in home
but still nothing shows up in homekit controller
unless there is another setting i needd to remove in home
Hmmm. That should not be needed. Can you restart the app and after a few minutes try again. If still nothing showed pm me the log, you can access that via the app settings, configure, log, copy to clipboard
hello again Martin
now i have been setting up zones and stuff today but made a mistake and had to redo the zones and now when i add the sensor again it shows in the aqara app as a induvidual sensor pr zone but when it adds to homey there is no zones following the device ??
have tryed to reset and add again buit it doesnt help
i removed device everywhere and did a factory reset and i do find the device again in homey but when i search there is 2 devices available but nomatter which one i select none of them have the 4 zones i have created ??
damn i should just have edited the zones and left it to sync instead
I did not read all 570 comments here, but couldn’t find this anywhere with a quick browsing through this topic… What’s going wrong here?? Trying to add the Aqara FP2. Added it to the Aqara app on Android, found it through the Homekit Controller app, entered the pin, keep getting this error message
Hello @Martin_Verbeek i would like to my Legrand Gateway into honey using your app instead of the one that depends on Cloud connection. This gateway does support HomeKit and it will bring light switches as well blinds controls on my case. Is this something the app can handle with ease? I’m asking this because if I want to move this away from my HomeKit/Apple TV I will need to full reset the device and reconfigure all my switches and blinds. Are you able to support me if we need to debug it?
There are also individual Smarter Thermostats from Netatmo.
@Martin_Verbeek Thank you so far for the help in getting the Legrand Gateway connected to homey via your app. After this weekend outage of Netatmo/Legrand services on they’re 3rd Party API services and also they’re own app “Control” it all made even more sense to move forward with this approach for local control instead of Cloud
HI, Read through the forum. I just got a HomeyPro 2026, I’m trying to Add Aqara FP2 Presence sensor to the same. I have tried all the suggestions in the Forum So far, but Unable to add the same to HomeyPro. I have installed Homekit Controller (v2.1.18). But unable to add it, dont see any options to add it, the device doesn’t show up (if it is supposed to). So could you help, Give me instructions as to process (if possible with screen shots).
Hi @Martin_Verbeek, I successfully added an Atag One Zone thermostat. Could it be that the device class isn’t set as climate or thermostat? Is there a way to change this manually in Homey? Thnx !
Hi @Martin_Verbeek, I’m a long-time user of your excellent app. Recently I ran into frequent crashes on my Homey Pro 2023 and when looking at the logs I see CPU warnings causing app unloads. The only devices managed by your app are 4 FP2. The app version is 2.1.18. Best, Peter
First of all, thanks for the great HomeKit Controller app, I really like it and appreciate the work behind it.
I’m trying to add my latest generation Eve Aqua (Thread, non-Matter version) to Homey Pro 2023 using the HomeKit Controller app, which supposedly supports non-Matter Thread devices as well.
My setup:
Homey Pro 2023
Existing Thread network already working fine with several Matter-over-Thread devices
Eve Aqua was previously added to Apple HomeKit and worked there perfectly
I read the first post saying:
“WHEN adding EVE Thread devices reset the device and do not put it into pairing mode, the device will not be found if you do. For Thread devices, remove devices does not work, so if you want to remove it from Homey, delete it and after that reset the device network settings.”
The problem is that Eve Aqua seems to have only one type of reset:
holding the power button for ~10 seconds.
I did exactly that several times:
reset the device
kept it very close to the Homey
tried adding it immediately after reset
did NOT manually put it into any pairing mode
Still, Homey never discovers it.
What’s confusing is:
after the failed Homey attempts, without any additional reset or button presses, I can immediately add the Eve Aqua back to Apple HomeKit again successfully. So it doesn’t seem to enter a special pairing mode at all.
Has anyone successfully added a non-Matter Eve Aqua Thread device to Homey Pro 2023 through HomeKit Controller?
Am I missing some extra Thread reset step or does the device need to be removed from the Apple Thread network differently first?
I recently just purchased a Homey Pro and loving it so far. I’ve got most everything moved over that I want to, but I am running into some issues with HomeKit native devices.
I’ve got a handful of devices that are HomeKit only that either don’t have Homey Apps, or aren’t supported devices within their respective Homey Apps (some Meross switches, a Yardian sprinkler controller, chamberlain garage door bridge, abode security, and a hunter fan).
I’ve downloaded the HomeKit controller app and I know that HomeKit devices can only be tied to one account at a time… HOWEVER, I am still having trouble. I’ve only messed with the Meross switches, and the Yardian, but every time I remove them from Apple home, and reset them to repair, they do not show up in the “connect over IP” or “connect over thread” options in the HomeKit controller. It constantly says no new devices found.
From my understanding of reading previous threads/articles on this, this is the only way to expose HomeKit only devices (that don’t have apps) to Homey without using something like HA…
Am I doing something wrong for these devices to not appear in the Homey HomeKit controller app? Should I remove these devices from the WiFi completely too? Any help is appreciated!
