What do you see on Homey Developer Tools ? Share the part with nodes WITHOUT the part System information.
You can try factory reset with backup restore, in case you have paid cloud backup option.
I see the light sensors (mainly using them with the Aqara app), nothing special on the node list. What am I looking for? Thank you
I really want to avoid a system restore. Nobody else experiencing the same problem with the app on 10.0.0?
By not working, the flows for those devices dont work?
Had a similar problem with Nimly. I just re-made my flow for that device, then all went back to normal… worth a try
The flows are fine. The device itself doesn’t work. So for example a light sensor didn’t updated since 10.0.0. I can’t add another device threw the aqara app.
Homey 2019 myself, and except for the Nimly hickup, my Aqara devices (motion and door/window sensors) works just fine…
Thanks for the confirmation. And you use the Aqara app right (without the gateway in between)?
I use those devices with Homeys Aqara app only
Unfortunately I told you what to do and you said it’s looking fine without sharing :wink: - so I’m out of options, but you can blindly go to suggested options :
Good luck.
Thank you for your guidance.
What is exactly what you want to see from the node list. Because im on the phone and can’t get a right picture. If it is for the routers, i really have enough throughout the whole house. But i will try the reset option and let you guys know if it worked.
Thank you :pray:
Did a full restore with a backup from a couple of days before where the light sensors worked ok. But still no movement of the light sensors…. So that didn’t work either. Very weird how could this be possible?
Anyone with another suggestion?
All my magnet sensors are constantly showing with 100% battery until battery is flat, and the device stop working. Does anyone know if there is a solution for this?
You have 3 options:
  1. Accept it and live with it.
  2. Do a search on this forum. This has been discussed several times.
  3. Replace every battery once a year. 99% guaranteed you will never have a problem again.
I noticed that my Single switch modules T1 with neutral didn’t report the power values anymore in my new homey pro 2023.
I tried to repair them without success.
Then I’ve tried to remove and readd one, but adding the device failed: “something went wrong trying to add the device, try again later.”
Tried to restart the app and tried adding it: failed. Than restarted homey and tried adding it: failed.
What can I do to add the device successfully?
And how can I get back my power values?
Hope somebody can help me.
Thanks in advance!
Does anyone have a aqara G4 doorbell?
I am thinking of getting it but i dont see any support for it with Homey.
the date of release of v1.8.0 at the end of August is still valid?
I have a Homey Pro 2023 and can not pair it with my Aqara Door and Window sensor. I try to add the device through the aqara app and i get an instruction to push the button on the sensor for three seconds, but then nothing happens. I did a search and found another person with the same problem Problem to pair Aqara with new Homey pro 2023
I also have my homey app set to swedish as in the post above.
Any thoughts or ideas?
The LED inside the device doesn’t blink?
Sorry for being unclear. The LED blinks just as the guide says. So the device looks fine, it just never shows up in the Homey Aqara app.
Have you tried a PtP?
Any info on compatibility for new Aqara led strip T1?
