I have the exact same situation
Yes, tried it, but no difference.
Hello !
Is anybody know if it’s possible to add the SRTS-A01 Aqara Smart Radiator Thermostat E1 ?
Thanks !
Hi!
I have an Aqara Vibration Sensor mounted on the inside of the lid of my mailbox to get a notification when I get new mail.
For this I want to use the Tilt alarm (since the vibration sensor is to sensitive and triggers when it isn’t supposed to). The problem is that the sensor is to slow to react. When I open the lid and holds it open for a couple of seconds the alarm goes off, but when I open and close it quicker (like when delivering mail) it doesn’t react.
Is anyone using this sensor for a similar purpose and have managed to find a solution?
Thanks!
Hello , when will be allowed within aqara app the new aqara presence sensor FP2?
Thanks!!
Still no news about the SRTS-A01 Aqara Smart Radiator Thermostat E1 ?
And my Aqara Motion Sensor isn’t detected by homey (I can’t pairing it), it work with the aqara hub but not with homey. Any idea ?
hello, the new sensors are not working yet. When will these be activated.
→ AQ_DW-S03D
I use the Roller Shade Driver and am very satisfied with it.
However, when I use the buttons themselves once, they can no longer be operated via Homey for about one or two weeks. The status (open or closed) is displayed correctly.
After a while it suddenly works again, until it is manually operated. This keeps repeating.
The device has already been added to Homey several times, then it will also work well for a while.
Anyone who can help me or experience the same?
Same here. Not working…
Can you please add this?
Dankjewel / thanks!
It’s available … but you would need to perform CLI install from GitHUB source but you will get version 1.6.0.
Hello, thanks for the great app ! I got e1 Curtain drivers - with devicemodelID ZNCLBL01LM but with a different product ID lumi.curtain.acn003 instead of lumi.curtain.agl001. Device is added as “unknown zigbee device”. EAN 6970504215119. Would it be possible to add this as E1 Curtain driver ? Happy to test ! ![]()
Models:
- ZNCLBL01LM (
lumi.curtain.acn003) - chinese version - CM-M01 (
lumi.curtain.agl001) - global version
"ids": {
"modelId": "lumi.curtain.acn003",
"manufacturerName": "LUMI"
"endpoints": {
"ieeeAddress": "54:ef:42:10:00:7b:a9:30",
"networkAddress": 34565,
"manufacturerName": "LUMI",
"swBuildId": "0.0.0_0027",
"capabilities": {
"type": "Buffer",
"data": [
132
"endpointDescriptors": [
"status": "SUCCESS",
"nwkAddrOfInterest": 34565,
"_reserved": 28,
"endpointId": 1,
"applicationProfileId": 260,
"applicationDeviceId": 263,
"_reserved1": 1,
"inputClusters": [
0,
1,
3,
64704,
258,
10
"outputClusters": [
3,
25,
64704,
10
"touchlinkGroupIds": [],
"extendedEndpointDescriptors": {
"1": {
"clusters": {
"basic": {
"attributes": "UNSUP_GENERAL_COMMAND",
"commandsGenerated": "UNSUP_GENERAL_COMMAND",
"commandsReceived": "UNSUP_GENERAL_COMMAND"
"powerConfiguration": {
"identify": {
"windowCovering": {
"time": {}
"bindings": {
"identify": {
"time": {},
"ota": {}
@HomeAut Did you read the first post about interviewing a device?
This is necessary if this is an unknown device.
tnx, see post above.
Some bad news from Aqara support when I asked if we could expect an updated Aqara app.
Hi Farid,
Thank you for contacting us.
Unfortunately, there is no plan to do this for the time being. Please check our Facebook page for updates at Aqara | New York NY.
Sincerely,
Cecilia
Aqara Technical Support
Technical support probably don’t even know what Homey is, so take that response with a grain of salt.
Does anyone know how to contact Lumi Technology to make feature/device addition requests? (Since they have taken responsibility over this app) Or do we still direct those requests to Ted?
It depends.
Thanks for your effort, but that out of my league unfortunately
Could you help with making the Aqara curtain Motor A1 compatible?
I bought it thinking it was the same as the curtain motor that is already listed in Homey devices but apparently not, so my Homey Pro isn’t able to detect it…
The product model number is: ZNCLDJ21LM
