[APP][Pro] Home Assistant - Community App
large
Happy with this app? Thank you for supporting community app development with a small donation via PayPal (send to friends).
btn_donate_LG1
This Homey app adds support for many devices, scripts & scenes of your Home Assistant installation.
Currently the following device types are supported:
  • Switches
  • Buttons
  • Lights
  • Sensors and Binary Sensors
  • Media Players
  • Climate
  • Presence
  • Scenes
  • Scripts
  • Compound (combined & customizable device)
  • Services (start via flowss)
Installing / using the app
To use this app, just install it from the Homey app store Home Assistant Community | Homey
There’s no need for configuring things up front, you can start right away by adding your first device, only now you will have to enter your Home Assistant instance’s local IP address, along with the “Longlived token”
→ when you don’t have one, create it by scrolling down at ‘http://your.homeassistant.IPaddress:8123/profile’;
When successfully saved, you can install devices without interruption.
After adding a new device on your HA instance, the entity list in Homey is refreshed instantly and you can directly add your new entity as Homey device.
Device types explained
  • Switches
    Any switch can be paired
  • Buttons
    You can press the button in Homey or react on a HA button press with a flow trigger
  • Lights
    Lights will be paired with their matching capabilities (as available on HA);
    this includes: brightness, colour and temperature
  • Media Players
    Media players can be paired, that includes TV sets, satellite / cable settop-boxes, home cinema receivers and more.
  • Presence
    This device represents a device_tracker or person (with assigned device_tracker) entity. You get the current state an an presence alarm, which can be inverted in device settings.
  • Climate
    Contol thermostats, heaters or air conditioner. Change the temperature and mode.
    Device dependent modes (fan, preset, swing) can be set using flows cards.
  • Scenes
    Scenes you’ve created in HA are paired as buttons, just press it to start a linked scene
  • Scripts
    Scripts you’ve created in HA are paired as buttons, just press it to start a linked script
  • Sensors
    Sensors are devices which return numeric values, like measuring and metering devices, weather data like rain, wind and such.
    Binary Sensors are devices which return an on/off or true/false state, like motion or contact sensors
And a special device:
  • Compound
    Compound is a custom device; in your HA instance, you can create a device which combines any sensors or entities present, which you then can pair with Homey as one device.
    There will be examples in this app’s forum topic. See link below.
  • There’s a little extra you’ll need to do:
    If you are using HACS, you can just add this integration to HACS searchig for “homey”.
    If not, you can download the files from
    https://github.com/RonnyWinkler/homeassistant.homey
    and copy/paste them into ‘/config/custom_components/homey/’
    You’ll find example files and a how-to in that folder.
Further documentations can be found on my Homepage:
grafik
There you can register for a newsletter to get updated when a new blog post is published.
And you can ask for further blog posts about examples, HowTo’s and technical insights
Contributions:
The thanks go to
  • Rob Groenendijk and his work on the HA community app this app is based on.
  • Jeroen Nijssen and
  • Peter Dwarswaard for their suport, ideas and app tests.
Help getting this app even better!
btn_donate_LG1
paypal-logo-png-transparent
Please use “send to friends” to avoid fees. Thanks.
Homey t.o.v. Home Assistant
Aqara FP2, mmWave presence detection on WiFi
MQTT Hub/Gateway
Home Assistant App - Unendliche Möglichkeiten 😀
Mobilephone as device
Home Assistant -> Homey Pro
[TUTORIAL][PRO] How to integrate Home Assistant with Homey Pro and v.v
Homematic IP thermostat heads Evo connected to Home Assistant/Raspberry Pi
Aqara Water Leak Sensor not working
Externer Temperatursensor am Danfoss Ally
Apple Music to Google devices
What's the current status of heltun devices support by homey?
How can I display Tasmota data?
New here, Smartthings, to HA to now HA with Homey SH. What would be the best way to go forward
Homey Zigbee VS Zigbee2MQTT
MQTT Hub/Gateway
Jung/Gira eNet Server koppelen aan de Homey Pro
Created a MMWave/PIR presence sensor with temp and humidity and luminance
Aqara Roller Shade Driver blinds stop command
Zigbee remote toevoegen
SONOFF Zigbee Human Presence Sensor | SNZB-06P
Homey integration for Home Assistant - Now Available! 🎉
Umzug Pro2019 auf Pro2023
Weheat warmtepomp via Homey Pro
[TUTORIAL][PRO] Home Assistant integreren met Homey Pro en v.v
No Energy calculation - Home Assistant devices
AEG wasmachine
'Route' column missing from zigbee device overview
Kan Home Assistant apparaten niet selecteren in flow
App creation for HomeWhiz support (Beko / Grundig)
Value of Home Assistant with Homey
Integration of a wolf heating system
Aqara temperature and humidity sensors report time
Home Assistant Devices Show Offline
Homey Self-Hosted Server on Home Assistant OS | Megathread
Zigbee/Z-Wave via Homey Bridge or USB Sticks?
Home Assistant zu Homey
Homey Pro (early 2023) and NHC - Niko Home Control
How to connect meross smart plug?
Oral b tandenborstel toevoegen aan homey?
Homey + Max.Storage von solarmax
Can't integrate home assistant
Kan ik matter devices gekoppeld aan homey koppelen aan andere apps?
Homey, a single hub for all?
Kidde Smoke Detectors with Air Quality monitoring
Honeywell T6 Pro Zwave Help!
Homey Pro's Flows (Aqara + Hue) work... until they don't. How can I fix it?
MQTT Setup Instructions - For a Beginner, Start to Finish Example / Instructions
Tuya lampen en sensors
Generic Physical Thermostat
Homey pro mit home assistant verbinden
Best location for Homey Bridge
Homey-HA zonder MQTT?
Support Z-Wave / Zigbee Coordinators / Homey Bridge
Unwanted crosstalk Aqara Smart Plug (EU) and IKEA Tradfri devices
Add Home Assistant entities as device capabilities in Homey
Steckdose Zigbee Energieanzeige
[APP][PRO] Home Assistant - Community App (deutsch)
Fritz Box Call Monitor
Homeassistant
Zigbee2mqtt versus deCONZ
Homey node red dash board maken
[APP] Tuya - Connect any Tuya device with Homey (by Tuya Inc. / Athom)
[Request] Connect Fordpass to Homey
[APP][Pro] Zigbee2MQTT - Use Zigbee devices via MQTT
Einfache Zeitschaltung mit Denkfehler?
[APP][Pro] Advanced Virtual Device (Device Capabilities App) with Unique Text Status Indicator
Homey Energy | Megathread
WHich Home Assistant Intergration to use?
The app crashes becasue of “memory limit”
Most common problem is a high frequent amount of HomeAssistant entity updates.
Check the following details:
  • Are devices imported with this app synced back to HomeAssistant with MqttClient & MqttHub. Exclude these devices in MqttHub
  • Is there a HA integrationsending a lot of events/entity updates? Check in HA developer tools, check frequest state changes and events. Check if it’s possible to reduce the interval in HA.
Can I only add single entities?
The app is designed to represent HA domains as a Homey device. State, attributes and services are bound to a domain, so you can add a single entity to Homey as device.
But additionally you can add HA device entities (entities grouped to a HA device) in device settings. And you can add entities manually in rrepair view.
For further detail, please check the Blog:
Add device entities
Add entities manually
reserved
Detailed descriptions and examples
HA custom_component
  • Installation (HACS)
    Open HACS in Home Assistant, select “Search and download repositories”. Search for “homey” and install the integration.
    grafik
  • Installation (manually)
    → Download the files from Github: custom_component/homey and copy them to a new folder “homey” in your HA configuration: /config/custom_components/homey
    → Then restart HA to load this component.
  • YAML configuration
    → If you want to include the YAML definition into your configuration.yaml, then take example.yaml as example for the structure. Copy the content into your configuration.yaml and edit the compound definition
    → If you would like to use an include file (the preferred variant), the insert this line into your configuration.yaml:
    homey: !include homey.yaml
    This way, you can add all compounds to a file names homey.yaml
    Use example_include.yaml as example for the structure.
Compound definition
The compoud groups a set of entities into a Homey device. As target you have to use an existing Homey capability. The capability defines, how the value is shown (as alarm, measurement or switch).
The Structure is:
compound_name:
  name: The name that is used as device name
  capabilities:
    capability1: entity1
    capability2: entity2
  capabilitiesTitles: (this is optional if you would like to set another capability description)
    capability1: title of capability 1
    capability2: title of capability 2
If you need more than one capability of the same type, you can use subcapabilities (add .subname)
Example:
temperature:
  capabilities:
    measure_temperature.south: sensor.south_temperature
    measure_temperature.nord: sensor.nord_temperature
  capabilitiesTitles:
    measure_temperature.south: "Temp. South"
    measure_temperature.nord: "Temp. Nord"
This way you can combine a switch and its measurement capabilities to a measurement plug
Example: This are the needed entities of a SP120 plug used for a fan:
Combined as compound it could look like:
fan:
  capabilities:
    onoff: switch.ventilator_eingeschaltet
    meter_power: sensor.ventilator_energie
    measure_power: sensor.ventilator_leistung
Add this code to your YAML (using your entities :-)).
Then restart HA to take effect.
In Homey, add a compound device:
Select the “Fan”:
grafik
Now you have a device showing the two power values and a switch to toggle the plug.
grafik
As you can see, the capability description were taken from the HA entities. If you like to get other titles, you can add them to the YAML. And don’t forget to restart HA after YAML changes. If there are syntax error, HA will prevent you to restart.
fan:
  capabilities:
  capabilitiesTitles:
    onoff: Fan switch
    meter_power: Power meter
    measure_power: Power current
Removed from Homey and added again it looks like this:
grafik
A further example for air quality data (air purifier) you can find in post #130:
Wishlist
This is a Wiki post for your wishes to the app.
Please add a wish for the Homey app itself or a HA device/entity you want to see in this app.
Please make a short! comment/keyword including the affected HA domain. Please don’t comment or discuss here.
I would love to see
  • Add your wish here
  • Support for wireless switches (Aqara). Not a button, but a switch that can support multiple actions (single_left, double_left, triple_left, hold_left, single_right, double_right, triple_right, hold_right)
:gift: Fulfilled wishes :gift:
  • add buttons “input_button”
    => RonnyW: added with version 0.1.6
  • Call custom service: make “services” list auto generated, replace domain with entity
    => RonnyW: new app flow action card with autocomplete lists
  • support for device trackers entity: device_tracker.xxxxxx
    HA has great options to track network devices, perfect to check is someone is home or not
    => RonnyW: added with version 0.2.3
  • direct Support for light entities with measurement
    => RonnyW: added with 0.3.0
    A sensor entity sensor.mylight_power is uses as measure_power capability for light entities light.mylight
  • direct Support for Cover entities
    => RonnyW: added with 0.5.0
  • direct Support for Locks
  • direct Support for vacuum cleaner
    => RonnyW: added with 0.5.15
  • possibility to select multiple devices at once
    => RonnyW: added new pairing dialog with 1.0.0
  • “Always on”, “Power usage when on”, “Power usage when off”. /k4mrat
    => RonnyW: added general Homey settings based on selectable device class.
  • “What’s plugged in?” (“other”, “light”, “fan” etc) /k4mrat
    => RonnyW: Added device settings for socket/switch device. It’s using Homey core functionality like other socket devices.
  • direct Support for airpurifier
    => RonnyW: Add a fan. Then add HA device entities in Homey device settings or manually in repair view.
  • media image for http sources
    => RonnyW: Added support for http URLs
  • condition cards for generic capabilities
  • Alarm Control Panel device support
Nice! I use the other HA app on a daily basis but I have missed some features that you introduce.
I have some issues to login in but I think I just need to have another go.
Am Inforced to use the local IP-adress? I use DuckDNS on my HA installation (https enabled).
That souldn’t matter I think.
Thanks, I will try more later. Just had a quick try with my duckdns server address https://xxxxx.duckdns.org:8123 with my newly created long lived token but I get “wrong credentials”. Probably something that I did wrong
that means it connects! you just entered a wrong key :slight_smile:
Or the app could not connect to the server. Both will raise the error because it’s just the default login view.
Hard to do it in a different way, I just copy the token from the app and paste it in Homey interface
I also got “could not find that Pairsession”
This happens if the pairing dialog is opened for a too long time or the dialog lost connection to the app process in another way. Just close the popup and start again.
Is this instance running https on this port?
I tried https://mydomain.de with default port 443 and a reverse proxy between forwarding to HA as http on port 8123 and this works fine.
Okay, I don’t use reverse proxy, just plain simple DNS. I use the same adress that I normally would use to access my HA installation, same port. Just tried and it works to connect to in the browser.
But why accessing HA via DynDNS in the LAN? You can try via IP first if it’s working in general.
I just have the dns-address in my muscle memory, I always use it. But I also tried the local IP which gave me the same result.
And HA is running https? With a self generated certificate? Perhaps that’s rejected.
That’s why I’m using HA internal with http and external with https via reverse proxy to avoid such certificate based issues. I can try to figure out if the connection will allow bad certificates or not.
Ok, tried a “bad” certificat access (exchanged certificated to get a wrong domain error) and got the connect error, too. So you need a correct certificate if you are using https. I’ll check if I can tweak the connection settings to ignore cert errors.
Thanks mate. Didn’t want to cause you more work, just to provide some feedback. :wink:
Every feedback helps us to get better :wink:
So I can check the SSL settings.
