Z-Wave unresponsive and unreliable
Hi community! :wave:
I really need your help. :sos:
Background
I’ve a Homey Pro 2023 (with a LAN-adapter) and almost exclusively Fibaro Z-Wave devices.
It has been working very well for a long time. Stable and very reliable. All flows running just fine. Never misses to turn on/off lights, very responsive.
But since some time back, I started having problems. Suddenly some my lights doesn’t turn on/off when my flows run. I’ve a couple of flows which changes all the lights in a room. These flows have always been “snappy”, but now takes quite a while and results in timeouts.
So what have I tried so far?
  • I’ve restarted my Homey
  • I’ve turned off my Homey for more than 10 minutes
  • I’ve run “Heal” countless of times on countless of nodes, I would say ALL nodes by now
What could be the reason to my problem?
  • Is it possible that an existing Z-Wave device suddenly became faulty? (I’ve no newly added devices)
  • Is it possible that Homey has introduced a bug related to Z-Wave? E.g. in the firmware or Fibaro app.
Suspicious behavior
Using the Log-feature of Developer Tools, I’ve noticed suspicious behavior.
If I create a flow which dims a light (and only one light) (in this case node 145) to 50%, then turns it off, I get the following commands to the node:
2024-11-01T10:41:29.715Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:41:35.646Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:41:39.737Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:41:45.649Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,0]},"Sensor Value":{"type":"Buffer","data":[0,0]}}
Looks just fine!
But, if I create a flow which also includes other lights (six other to be exact, all in the same room), I get this following commands to the node:
2024-11-01T10:42:24.768Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:24.827Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:27.709Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:27.838Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:28.103Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.346Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.370Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.382Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.411Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.483Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.661Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.827Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.870Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:30.913Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:31.174Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,1]},"Sensor Value":{"type":"Buffer","data":[0,1]}}
2024-11-01T10:42:34.992Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:35.058Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:35.233Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:36.969Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.060Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.084Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.096Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.172Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.248Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.274Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.323Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.347Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.388Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.448Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.467Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.482Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.496Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.636Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.647Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.659Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.727Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:37.904Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:42:37.979Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:42:38.007Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:42:38.279Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:38.659Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:42:38.758Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[50]},"Value":50}
2024-11-01T10:42:42.446Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:42:42.523Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:42:43.080Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,29]},"Sensor Value":{"type":"Buffer","data":[0,29]}}
2024-11-01T10:42:59.288Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:42:59.349Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:42:59.400Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:42:59.824Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:42:59.908Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:42:59.989Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:00.764Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:00.845Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:00.977Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:02.322Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:02.366Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:02.458Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:03.723Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:03.814Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:03.864Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.264Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.319Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.381Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.404Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.458Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.540Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.551Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.575Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.591Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.641Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.652Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.694Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.715Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.727Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.747Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.781Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.823Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.856Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.908Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:04.938Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:08.552Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:08.592Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:08.687Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:09.204Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:09.276Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:09.371Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:09.451Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:09.474Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:09.864Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:09.991Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.006Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.081Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.144Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.189Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.208Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.254Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.469Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:10.511Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:10.587Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:10.630Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:10.987Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:11.165Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:11.268Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {"Value (Raw)":{"type":"Buffer","data":[0]},"Value":"off/disable"}
2024-11-01T10:43:11.989Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:12.043Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:12.115Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:13.841Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:13.943Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:13.955Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.005Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.081Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.136Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.217Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.266Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.514Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.558Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.578Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.591Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.670Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,0]},"Sensor Value":{"type":"Buffer","data":[0,0]}}
2024-11-01T10:43:14.793Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.846Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.870Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.935Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
2024-11-01T10:43:14.995Z Node[145]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {"Sensor Type (Raw)":{"type":"Buffer","data":[4]},"Sensor Type":"Power (version 2)","Level (Raw)":{"type":"Buffer","data":[34]},"Level":{"Size":2,"Scale":0,"Precision":1},"Sensor Value (Raw)":{"type":"Buffer","data":[0,14]},"Sensor Value":{"type":"Buffer","data":[0,14]}}
Crazy! As you can see the command to dim the light to 50% for node 145 is sent many, many times as well as the command to turn node 145 off. No wonder it’s sluggish and working very unwell.
I’ve recreated the flow several times, the result is the same. Adding more nodes to a flow, creates multiple commands for each node.
Worth mentioning is that this happens with multiple flows in different rooms. So not only the room where node 145 is located.
What the heck is happening here? What could be causing this behavior.
Help is very appreciated! :pray:
… cut the power from the Z-WAVE devices, it might also helps.
More would say screenshot of your ZWAVE devices mesh from Homey Developer Tools - best also to see number of RX/TX packets and all the devices in network including routes
Did your devices start misbehave right after some update like that ? If not, it’s probably not caused by firmware itself.
Share the flow then.
Also last but not least - Sensor Multilevel Reports - The numerous [COMMAND_CLASS_SENSOR_MULTILEVEL] entries suggest that devices are reporting power usage frequently, which can clutter the network. Try adjusting the reporting intervals for power consumption in the device settings to reduce the frequency of reports.
Thank you for helping me out @Sharkys! :slightly_smiling_face:
Will try that! Quite easy to do, but many of the devices fail (as you can see in the screenshot below). So, I would more or less have to cut the power to the whole house. :slightly_smiling_face:
Here you go:
As you can see, there are a lot of “TX Errors” - something I haven’t seen before, or at least very seldom. Something have definitely changed!
My feeling is that the problems started after an update. Either of the Homey or of the Fibaro app. But I can’t be sure. I’m 100% sure that I haven’t changed anything in my physical setup (like new devices). So either this has to do with a software change or a device that has suddenly gone bad. Please note that all devices still works, but there are suddenly errors and everything is sluggish and sometimes commands fails even with multiple retries. This happens to many of my nodes (as you can see in the screenshot).
Here you go:
Nothing advanced at all, just dimming a few lamps. I’ve been running this flow for a long time without problems (e.g. the flow hasn’t changed).
This was actually my first though. So what I tried was to double check the “report values” - all were default. Then I also disabled reporting for the devices included in the flow above. This didn’t help at all. still just as sluggish.
And, even if you explude the power reporting from the log, there are multiple log posts for the dim/off-commands for the same device - why?
At least for me, this behavior is strange. My thoughts about this is that either the flow-engine in the Homey is “translating” the flow to commands incorrectly - causing multiple commands or this is due to a faulty Z-Wave network. If you check the timestamps there’s not many milliseconds between each command. Very strange.
Again - thanks for helping me out! :pray:
Sometimes even this could be a solution
Not so many, eg. if device do not transmit too much, it’s normal that the percentage is higher (Eg. 1 lost or error out of 10, represent 10%).
I would try to cut power from Nodes 144, 145,146, 163 , 171, 172, 173, 192 - they seems to flood your ZWave mesh. Or at least they are very busy (I did not check type of those devices, could be also normal for some busy sensors or regularly reporting multiple values etc.)
That seems to be OKay in general, I would maybe just add some delays in between - eg. split it 50/50 to minimize the load yet, this is still something Homey should be able to handle. If some of the devices belongs to same zone/room, you can either them (and implement delays within the group), or use ZONE control instead (not sure about dimming though, maybe MOOD would be the way?).
Could be because of those Nodes above which keeps your mesh busy.
I would also suggest to share that finding with Athom Support, because it should not happen. Regardless of the reason, they should implement some mechanism that would prevent that. But this is just my humble opinion.
If they are able to prevent us to fully control LED ring just because of some users in the past forget they set it RED and then contacted support (so they implement max 10 sec duration), maybe they could improve even more serious stuff like those ZWAVE storms :wink:
Thank you @Sharkys!
I will try your suggestions as soon as I find the time and get back! :slightly_smiling_face:
@Sharkys So I’ve done some more testing.
I started off by cutting the power to my Homey Pro for 10+ minutes.
I also cut the power to the Fibaro devices with a lot of errors.
Regarding nodes with a lot of traffic:
  • 144, 145, 146, 163 - These are just regular lamps. I believe the amount of traffic is due to my problem, e.g. commands being sent multiple times, which is what I’m trying to solve.
  • 171, 172, 173 - These are Qubino 3-Phase Smart Meters. They measure the power consumption of my house in real time. They are close to my Homey Pro and even though there’s quite a lot being sent, there are very few errors. These has been installed for a long time without any problems.
  • 193 - I used this wall plug to measure my computers power consumption. I don’t really need it, so I removed it.
The removal of node 193 didn’t change anything. Z-Wave is still sluggish and I get a lot of duplicate commands sent. It’s like when I run the flow it sends commands to would represent running the flow over 20 times.
This morning a few of the night lights were still one, e.g. Homey had failed to turned them off. Something that had been working for a long, long time before I started having problems.
Sometimes I get “Network request failed” and “ZWaveSendCommandTimeout after 30000ms” when I run flows.
I’ve posted logs (below) for when I run the flow to turn lights on and off (in my basement recreation room). As you can see COMMAND_CLASS_SWITCH is sent multiple times for each node - why?
How to you find out if a node is faulty? Is there any systematic way to troubleshoot which? If I run the “Test” command for nodes in Developer Tools, nodes returns “pass” instantly.
Log: turn lights on
[2024-11-06T10:01:39.605Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:39.809Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:39.970Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:40.297Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:40.404Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:41.052Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:41.227Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:41.546Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:41.609Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:41.964Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:42.294Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:42.578Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:42.770Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:42.795Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:42.834Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:42.859Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:43.261Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:43.340Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:43.425Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:43.659Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:43.750Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:43.831Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:43.943Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:43.975Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:44.273Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:“on/enable”}
[2024-11-06T10:01:44.341Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:44.675Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:45.002Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:45.181Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:45.389Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:45.663Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:45.742Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:45.949Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:45.996Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:46.488Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:46.547Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:46.674Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:47.030Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:47.072Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:47.119Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:47.155Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:47.536Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:47.626Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:47.675Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:47.791Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:47.942Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.016Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.110Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:48.121Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.245Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.408Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.445Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:48.478Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.489Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.522Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.534Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.546Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.584Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:48.596Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.625Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.641Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:48.658Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.701Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.712Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.795Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.847Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.897Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.910Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.931Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:48.966Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:49.067Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:49.082Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:49.134Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:49.221Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:49.523Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:49.607Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:49.687Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:49.906Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[10]},“Value”:10}
[2024-11-06T10:01:49.943Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:49.975Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:50.028Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:50.082Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:50.109Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.164Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[10]},“Value”:10}
[2024-11-06T10:01:50.457Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.465Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:50.507Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[10]},“Value”:10}
[2024-11-06T10:01:50.533Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:50.549Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.633Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:50.647Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.741Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.830Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.841Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.855Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.890Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.898Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.921Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.934Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.952Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:50.972Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:51.040Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[10]},“Value”:10}
[2024-11-06T10:01:51.051Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:51.078Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[50]},“Value”:50}
[2024-11-06T10:01:51.159Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[10]},“Value”:10}
[2024-11-06T10:01:51.175Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:51.273Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:51.439Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.449Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.458Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.470Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.481Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.567Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.640Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:51.679Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.697Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.782Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:51.801Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[30]},“Value”:30}
[2024-11-06T10:01:56.945Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:56.966Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:56.984Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:56.988Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.036Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.105Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.130Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.141Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.178Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.259Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.271Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.282Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.346Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.363Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.386Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
[2024-11-06T10:01:57.499Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[20]},“Value”:20}
Log: turn lights off
[2024-11-06T10:10:53.597Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:53.908Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:53.945Z] Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:53.989Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.025Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.036Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.294Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.437Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.546Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.639Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.681Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.767Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:54.848Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:55.510Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:55.599Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:55.624Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:55.680Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:55.687Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:55.794Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:56.390Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:56.674Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:56.922Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.061Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.212Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.278Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.441Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.532Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.650Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.661Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.732Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.854Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.883Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.898Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.920Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.962Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:57.973Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.065Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.083Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.109Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.144Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.185Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.197Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.255Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.399Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.632Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.681Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.756Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.905Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.946Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.969Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:58.992Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.020Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.087Z] Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.112Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.184Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.215Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.306Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.339Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.382Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.421Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.433Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.444Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.593Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.620Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.664Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.673Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.692Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.918Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:10:59.962Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.016Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.027Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.189Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.201Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.213Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.303Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.372Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.477Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:00.601Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.174Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.254Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.262Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.273Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.285Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.387Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.399Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.441Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.477Z] Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.550Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.609Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.631Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.642Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.720Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:01.858Z] Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:06.327Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:06.420Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:06.519Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:06.622Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:06.821Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:06.963Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:07.148Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:07.366Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:07.568Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:07.712Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:07.756Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:07.924Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:07.969Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:08.006Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:08.197Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:08.428Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:08.464Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:08.513Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:08.722Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:08.803Z] Node[151]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:12.949Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:13.109Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:13.175Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
[2024-11-06T10:11:13.428Z] Node[149]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
I also found these errors in the log, what does it mean?
Errors in log
[2024-11-06T11:03:49.679Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY - txStatusReport: {“wTransmitTicks”:“0x0”,“bRepeaters”:“0x0”,“rssi_values_incoming_0”:“0x0”,“rssi_values_incoming_1”:“0x0”,“rssi_values_incoming_2”:“0x0”,“rssi_values_incoming_3”:“0x0”,“rssi_values_incoming_4”:“0x0”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x0”,“pLastUsedRoute_0”:“0x0”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x0”,“bRouteTries”:“0x0”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x0”,“bMeasuredNoiseFloor”:“0x0”,“bDestinationAckUsedTxPower”:“0x0”,“bDestinationAckMeasuredRssi”:“0x0”,“bDestinationAckMeasuredNoiseFloor”:“0x0”}
[2024-11-06T11:03:49.697Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY - txStatusReport: {“wTransmitTicks”:“0x0”,“bRepeaters”:“0x0”,“rssi_values_incoming_0”:“0x0”,“rssi_values_incoming_1”:“0x0”,“rssi_values_incoming_2”:“0x0”,“rssi_values_incoming_3”:“0x0”,“rssi_values_incoming_4”:“0x0”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x0”,“pLastUsedRoute_0”:“0x0”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x0”,“bRouteTries”:“0x0”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x0”,“bMeasuredNoiseFloor”:“0x0”,“bDestinationAckUsedTxPower”:“0x0”,“bDestinationAckMeasuredRssi”:“0x0”,“bDestinationAckMeasuredNoiseFloor”:“0x0”}
[2024-11-06T11:03:49.722Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY - txStatusReport: {“wTransmitTicks”:“0x0”,“bRepeaters”:“0x0”,“rssi_values_incoming_0”:“0x0”,“rssi_values_incoming_1”:“0x0”,“rssi_values_incoming_2”:“0x0”,“rssi_values_incoming_3”:“0x0”,“rssi_values_incoming_4”:“0x0”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x0”,“pLastUsedRoute_0”:“0x0”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x0”,“bRouteTries”:“0x0”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x0”,“bMeasuredNoiseFloor”:“0x0”,“bDestinationAckUsedTxPower”:“0x0”,“bDestinationAckMeasuredRssi”:“0x0”,“bDestinationAckMeasuredNoiseFloor”:“0x0”}
[2024-11-06T11:03:49.742Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY - txStatusReport: {“wTransmitTicks”:“0x0”,“bRepeaters”:“0x0”,“rssi_values_incoming_0”:“0x0”,“rssi_values_incoming_1”:“0x0”,“rssi_values_incoming_2”:“0x0”,“rssi_values_incoming_3”:“0x0”,“rssi_values_incoming_4”:“0x0”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x0”,“pLastUsedRoute_0”:“0x0”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x0”,“bRouteTries”:“0x0”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x0”,“bMeasuredNoiseFloor”:“0x0”,“bDestinationAckUsedTxPower”:“0x0”,“bDestinationAckMeasuredRssi”:“0x0”,“bDestinationAckMeasuredNoiseFloor”:“0x0”}
[2024-11-06T11:05:10.764Z] Transmit failed with TRANSMIT_COMPLETE_NO_ACK - txStatusReport: {“wTransmitTicks”:“0x5ef”,“bRepeaters”:“0x0”,“rssi_values_incoming_0”:“0x7f”,“rssi_values_incoming_1”:“0x7f”,“rssi_values_incoming_2”:“0x7f”,“rssi_values_incoming_3”:“0x7f”,“rssi_values_incoming_4”:“0x7f”,“bACKChannelNo”:“0x1”,“bLastTxChannelNo”:“0x1”,“bRouteSchemeState”:“0x7”,“pLastUsedRoute_0”:“0x0”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x2”,“bRouteTries”:“0x1e”,“bLastFailedLinkFrom”:“0xa3”,“bLastFailedLinkTo”:“0x91”,“bUsedTxPower”:“0x0”,“bMeasuredNoiseFloor”:“0x0”,“bDestinationAckUsedTxPower”:“0x0”,“bDestinationAckMeasuredRssi”:“0x0”,“bDestinationAckMeasuredNoiseFloor”:“0x0”}
[2024-11-06T11:05:10.781Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY - txStatusReport: {“wTransmitTicks”:“0x0”,“bRepeaters”:“0x0”,“rssi_values_incoming_0”:“0x0”,“rssi_values_incoming_1”:“0x0”,“rssi_values_incoming_2”:“0x0”,“rssi_values_incoming_3”:“0x0”,“rssi_values_incoming_4”:“0x0”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x0”,“pLastUsedRoute_0”:“0x0”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x0”,“bRouteTries”:“0x0”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x0”,“bMeasuredNoiseFloor”:“0x0”,“bDestinationAckUsedTxPower”:“0x0”,“bDestinationAckMeasuredRssi”:“0x0”,“bDestinationAckMeasuredNoiseFloor”:“0x0”}
[2024-11-06T11:05:16.190Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY_QUEUE - txStatusReport: {“wTransmitTicks”:“0x211”,“bRepeaters”:“0x2”,“rssi_values_incoming_0”:“0x7f”,“rssi_values_incoming_1”:“0x7f”,“rssi_values_incoming_2”:“0x7f”,“rssi_values_incoming_3”:“0x7f”,“rssi_values_incoming_4”:“0x7f”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x1”,“bRouteSchemeState”:“0x5”,“pLastUsedRoute_0”:“0x70”,“pLastUsedRoute_1”:“0xa8”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x2”,“bRouteTries”:“0xa”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x7f”,“bMeasuredNoiseFloor”:“0x7f”,“bDestinationAckUsedTxPower”:“0x7f”,“bDestinationAckMeasuredRssi”:“0x7f”,“bDestinationAckMeasuredNoiseFloor”:“0x7f”}
[2024-11-06T11:05:32.249Z] Transmit failed with TRANSMIT_COMPLETE_NO_ACK - txStatusReport: {“wTransmitTicks”:“0x576”,“bRepeaters”:“0x3”,“rssi_values_incoming_0”:“0x7f”,“rssi_values_incoming_1”:“0x7f”,“rssi_values_incoming_2”:“0x7f”,“rssi_values_incoming_3”:“0x7f”,“rssi_values_incoming_4”:“0x7f”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x4”,“pLastUsedRoute_0”:“0x65”,“pLastUsedRoute_1”:“0xb4”,“pLastUsedRoute_2”:“0x86”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x3”,“bRouteTries”:“0x2”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x7f”,“bMeasuredNoiseFloor”:“0x7f”,“bDestinationAckUsedTxPower”:“0x7f”,“bDestinationAckMeasuredRssi”:“0x7f”,“bDestinationAckMeasuredNoiseFloor”:“0x7f”}
[2024-11-06T11:05:38.398Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY_QUEUE - txStatusReport: {“wTransmitTicks”:“0x248”,“bRepeaters”:“0x1”,“rssi_values_incoming_0”:“0x7f”,“rssi_values_incoming_1”:“0x7f”,“rssi_values_incoming_2”:“0x7f”,“rssi_values_incoming_3”:“0x7f”,“rssi_values_incoming_4”:“0x7f”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x1”,“bRouteSchemeState”:“0x5”,“pLastUsedRoute_0”:“0x72”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x2”,“bRouteTries”:“0xe”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x7f”,“bMeasuredNoiseFloor”:“0x7f”,“bDestinationAckUsedTxPower”:“0x7f”,“bDestinationAckMeasuredRssi”:“0x7f”,“bDestinationAckMeasuredNoiseFloor”:“0x7f”}
[2024-11-06T11:05:52.774Z] Transmit failed with TRANSMIT_COMPLETE_NO_ACK - txStatusReport: {“wTransmitTicks”:“0x1de”,“bRepeaters”:“0x1”,“rssi_values_incoming_0”:“0x7f”,“rssi_values_incoming_1”:“0x7f”,“rssi_values_incoming_2”:“0x7f”,“rssi_values_incoming_3”:“0x7f”,“rssi_values_incoming_4”:“0x7f”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x5”,“pLastUsedRoute_0”:“0x72”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x3”,“bRouteTries”:“0xe”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x7f”,“bMeasuredNoiseFloor”:“0x7f”,“bDestinationAckUsedTxPower”:“0x7f”,“bDestinationAckMeasuredRssi”:“0x7f”,“bDestinationAckMeasuredNoiseFloor”:“0x7f”}
[2024-11-06T11:06:08.266Z] Transmit failed with TRANSMIT_COMPLETE_FAIL_PHY_QUEUE - txStatusReport: {“wTransmitTicks”:“0x14f”,“bRepeaters”:“0x1”,“rssi_values_incoming_0”:“0x7f”,“rssi_values_incoming_1”:“0x7f”,“rssi_values_incoming_2”:“0x7f”,“rssi_values_incoming_3”:“0x7f”,“rssi_values_incoming_4”:“0x7f”,“bACKChannelNo”:“0x0”,“bLastTxChannelNo”:“0x0”,“bRouteSchemeState”:“0x4”,“pLastUsedRoute_0”:“0x72”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x3”,“bRouteTries”:“0x6”,“bLastFailedLinkFrom”:“0x0”,“bLastFailedLinkTo”:“0x0”,“bUsedTxPower”:“0x7f”,“bMeasuredNoiseFloor”:“0x7f”,“bDestinationAckUsedTxPower”:“0x7f”,“bDestinationAckMeasuredRssi”:“0x7f”,“bDestinationAckMeasuredNoiseFloor”:“0x7f”}
[2024-11-06T11:07:51.359Z] Transmit failed with TRANSMIT_COMPLETE_NO_ACK - txStatusReport: {“wTransmitTicks”:“0x32b”,“bRepeaters”:“0x0”,“rssi_values_incoming_0”:“0x7f”,“rssi_values_incoming_1”:“0x7f”,“rssi_values_incoming_2”:“0x7f”,“rssi_values_incoming_3”:“0x7f”,“rssi_values_incoming_4”:“0x7f”,“bACKChannelNo”:“0x1”,“bLastTxChannelNo”:“0x1”,“bRouteSchemeState”:“0x7”,“pLastUsedRoute_0”:“0x0”,“pLastUsedRoute_1”:“0x0”,“pLastUsedRoute_2”:“0x0”,“pLastUsedRoute_3”:“0x0”,“pLastUsedRoute_4”:“0x2”,“bRouteTries”:“0x11”,“bLastFailedLinkFrom”:“0x7a”,“bLastFailedLinkTo”:“0xc0”,“bUsedTxPower”:“0x0”,“bMeasuredNoiseFloor”:“0x0”,“bDestinationAckUsedTxPower”:“0x0”,“bDestinationAckMeasuredRssi”:“0x0”,“bDestinationAckMeasuredNoiseFloor”:“0x0”}
I have the same problem also for a while. I only use z-wave devices and most of them are fibaro wallswitches, RGB controllers and smartplugs. I did’t give it much attentions but its getting annoying now. Only just now looked iin Developer tools and I also have a lot of Tx error on certain devices. I also see some strange unlogical routes. I’ll try to do some troubleshooting this weekend and report back. Keep us posted if you find a solution.
I think it started after some update but not sure it’s been to long to know for sure
Thank you for you input @Stief!
I will get back if I find the reason why this is happening.
I’ve contacted Homey support, but I’m waiting for them to get back.
About a month ago Homey released their firmware 12.1.1 and about the same time the Fibaro app updated to 3.8.0. Maybe it has correlations to our problems, maybe not.
I’m still waiting for an answer from the support.
Meanwhile I’ve talked to a friend who is also a Homey user. He has been noticing a performance decrease when running flows with Zigbee devices as well.
So maybe something is fishy when “flows gets converted to commands”.
I’ve asked him to check his logs to see if he as well has duplicated commands.
This issue has existed for many years, Homey is terrible at executing multiple flow cards in parallel (not just Z-Wave, all radio protocols are affected by this). The symptoms are almost always one or more random devices not responding to the flow actions. The typical solution is adding delays in between the cards.
I don’t know why Athom doesn’t take this issue more seriously, especially since it has existed for many years now (instead, Athom puts the blame on others, for example they recently blamed the Hue hub for being “too slow” to handle multiple commands).
I’m interested in what Athom’s support will say, but my guess is that your devices will be blamed.
Thanks for confirming @robertklep!
The funny thing is that if you try to switch on (or off) a light and it doesn’t respond, you will get a timeout after 10000 ms, e.g. one command is sent, then the Homey will wait 10000 ms. This time might have changed, it’s been a while since I had a device with problems.
While running flows I’ve seen duplicate commands being sent twenty+ times with a delay sometimes no more than 50 ms between each command. What the happened to the wait part in this case? Why would you ever want to send the same command after 50 ms? So strange.
Adding card delays helps as you say, but duplicate commands is still sent, so Athom should really fix this. Flow is such a central function, it’s hard to believe that they wouldn’t want to fix this.
I’ve long had the suspicion that commands aren’t properly queued internally when they are issued from flows, and your logs seems to confirm this. It’s certainly very strange behaviour.
It’s such a common problem that through the course of years a number of workarounds have been found (like the delays), and that’s what users share with each other on this forum. So you could argue that, from Athom’s point of view, the problem has solved itself.
Curious how things work with this recently added ‘master’ switch :
I don’t know if Z-Wave supports broadcast-type messages, where you could target all devices (or possibly all devices of a certain type) with one message?
Interesting. It seams to be using the same logic as flows.
My room has five lights:
  • Node 144 - Fibaro Dimmer 2
  • Node 145 - Fibaro Dimmer 2
  • Node 146 - Fibaro Dimmer 2
  • Node 163 - Fibaro RGBW Controller 2
  • Node 165 - Fibaro Wall Plug 2
If I click the toogle for the all lights in the room, in this case to switch off all lights this is what I get:
Log switch off lights in room
2024-11-13T06:04:09.856Z
[ProcessSendData]: To node: 163 with data: 0x260100ff and txOptions: TRANSMIT_OPTION_ACK,TRANSMIT_OPTION_AUTO_ROUTE,TRANSMIT_OPTION_EXPLORE
2024-11-13T06:04:10.020Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:10.667Z Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:11.015Z Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:11.856Z Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:12.142Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:12.306Z Node[146]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:12.447Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:12.623Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:12.955Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:13.268Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:13.330Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:13.647Z Node[145]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:13.694Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:14.127Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:14.216Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:14.395Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:14.558Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:14.933Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:15.209Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:15.351Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:15.715Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:15.903Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.152Z Node[144]: [COMMAND_CLASS_SWITCH_MULTILEVEL] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.335Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.346Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.632Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.642Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.741Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.763Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.796Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.832Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.879Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:16.937Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:17.035Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:17.138Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:17.413Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:17.519Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:20.937Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.161Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.562Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.619Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.638Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.664Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.676Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.714Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.745Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.757Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.797Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.846Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:21.857Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:22.008Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:22.078Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:22.101Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
2024-11-13T06:04:22.328Z Node[165]: [COMMAND_CLASS_SWITCH_BINARY] {“Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Value”:“off/disable”}
As you can see, the Homey sends many duplicate commands within milliseconds:
  • Node 144 - 9 times
  • Node 145 - 2 times
  • Node 146 - 4 times
  • Node 163 - 1 time
  • Node 165 - 39 times
This time node 165 had most commands, in the log attached previously it was another node. So it’s not like its pointing to a specific node.
If I run the “Test” command in Developer Tools for ZWave, all nodes responds instantly.
Another week has passed and I’m still waiting for Homey support to get back to me. Will update if/once they do.
I have the same (similiar) problem with my new Homey 2023 pro. I think my problem was simultneous connection with Wifi and LAN. In Homey Options You can see that Wifi and Lan are both connected at the same time.
In Homey Developer Tools on very bottom of the site in web api playground I copied Homey.system.disableWifi();
and disabled Wifi with only LAN connection acvite.
I restarted Homey and evyrything started to work excellent. I don’t know is this Your problem but maybe try it. To enable wifi copy - Homey.system.enableWifi();
Best regards
