🤓 What's up, Nerds? — Introducing Homey Self-Hosted Server
Is there a limit of 50 zigbee devices using the Bridge with Homey Self Hosted Server?
Are there any plans for you to use your own zigbee coordinator?
I’ve a usb sonoff adapter which I’d like to use without the need of the bridge. That would be perfect setup - Homey OS hosted with your own zigbee/zwave coordinator.
Can we run both?
Set up Homey SHS on my NAS for most. Use my HP2023 (which is bursting at memory limits) for some things, join them with Homey Link app and use the bridge as intended so its all bridged around the house?
I was just about to buy a new HP2026 but i think i can pass now.
I take it app control and updates etc will be as is through the app
I was curious too, if i offload most/all to the NAS and use the link what effect will that have on routines/memory use?
Can we run all of it in one?
If i have bridge, will that “only” server the SHS or will it bridge the shs and the Pro 2023?
It’s most probably hardware related, not to the role it has (cloud extension / Pro sat / SHS sat).
It’s no hard limit, but just like the Pro 2016-2019 series, it’s recommended to not exceed 40 devices to avoid performance issues, but some have reported to use 70 zigbee devices perfectly on a Pro 2019.
It all depends on the used devices, how many different brands and interference.
Don’t build too big
Using Zigbee routers, you can create a stable Zigbee network of around 30-40 devices with Homey Bridge.
We do not recommend creating bigger Zigbee networks with your Homey. Adding more devices will put more stress on the network and might therefore negatively impact communication, reliability, and speed.
The limits of what is workable depend a lot on your specific situation.
If you notice Zigbee performance dropping after extending your network to a larger-than-recommended number of devices, you are probably pushing the limits of the Zigbee network in your home.
source > https://support.homey.app/hc/en-us/articles/4414431713682-Creating-a-stable-Zigbee-network-with-Homey-Bridge
Nice update. How can I pull a update from homey 2023 to homey self hosted?
Oh, that particular reply was about
as in ‘Home Assistant’, Sven.
No issues with Homeyscript @ linux + Docker
Every platform has it’s dedicated topic now, Olivier. I think you’d best report here:
Yeah, sounds like it might be a Nuki quirk (“Works with Home Assistant” :roll_eyes:). I was planning a trip to the local IKEA somewhere in the upcoming days (Zigbee devices are getting cleared out) and pick up some of their new Thread devices.
EDIT: meh, just read that the new Thread devices will become available from Jan 1st.
Does the connection between the Homey Self-Hosted Server and the Homey Bridge occur locally, given that the Homey Bridge was originally a cloud-based solution?
No everyone called Homey Cloud “Homey Bridge”, don’task me why. So the Homey Cloud is the only cloud-based solution.
The actual bridge is just a device, connectable per local wifi to Homey Cloud, to Homey Pro or to Homey SHS.
One thing worth thinking about before deciding to use Homey SHS with Homey Bridge for Z Wave, Zigbee etc. devices is that if your Internet goes down, you’re fine as long as your Homey Bridge stays powered. If your Internet goes down and your Homey Bridge loses power even briefly then you’re stuck without access to any of your RF devices until the Internet is restored.
Wi-Fi with internet access is required
While Homey Bridge connects to Homey Pro directly on LAN, Homey Bridge needs Wi-Fi with internet access to connect to Homey Pro every time it powers on. Homey Bridge might pulsate red if your internet is offline until it can reconnect to Homey Pro.
Source: https://support.homey.app/hc/en-us/articles/7263667137052-Setting-up-Satellite-Mode-for-Homey-Pro
This kills the idea of Homey SHS as my primary solution at least for now.
So I’m thinking Homey SHS might be a better option as a ‘backup Homey’ in the event something goes wrong with my Homey Pro that I cannot quickly fix. Obviously this use case won’t be viable until Homey SHS supports restore from backup (ideally cloud so that I have an automated nightly backup). And even then, it’s not clear that there would be a quick route to migrate RF devices from a Homey Pro to a Homey SHS’s Satellite Bridge.
So this leaves the only remaining use cases for Homey SHS right now:
  • Users who don’t care about truly local (not sure how much overlap there is between these people and those contemplating Homey SHS)
  • Users who don’t have (m)any RF devices. Similar caveat to the above.
  • Tinkering / dev system but not primary system (not sure how many people for whom this use case is worth the subscription fee)
In the cold light of day, Homey SHS is more limited than I first thought. And the addition of a restore from backup feature is even more critical IMHO. While you’re thinking about restore from backup, Athom, perhaps worth considering how RF devices could be migrated from Homey Pro to Homey Bridge operating as a Satellite for Homey SHS.
:man_facepalming:t3:
I just bought some yesterday in Groningen.. only the new air quality thing is not available
don’t buy the scrol wheel button.. it’s bad
I think that’s because Homey uses the homeylocal.com domain to reach your Homey via HTTPS (for me it’s 192-168-107-193.homey.homeylocal.com) and it needs DNS for that
Yeah I read your review, I will be skipping that (too bad because it sounded quite nice!).
“TLS Everywhere” on a local network is just asking for problems. Not just because of this, but also having to turn off DNS rebinding protection in your router to make it work. I think it’s one of the main reasons why there are so many issues with “Homey Offline” errors.
But AFAIK the Homey app falls back to a cloud/relay connection when local access fails, right? When I block the “/ping” URL in DevTools, the web app automatically uses the cloud/relay connection. So then you shouldn’t have those Offline errors
They are already in stock in multiple Dutch stores. Picked up a TIMMERFLOTE temperature sensor in Haarlem last week.
That’s how it should work in theory, but in practice something causes the Homey apps to think Homey is offline when it’s not. My guess is that for some reason Homey either loses its connection to the cloud servers, or its local IP address (stored in the cloud so the apps can connect to it via A-B-C-D.homey.homeylocal.com) becomes outdated or lost.
