Time is one hour off
I just did a test. I made a flow with the when card at time 12:52 and the then card with a push to my phone and it worked. Maybe I should rework the flows that are time triggered?
That might be a workaround, but Athom should still know about it.
Ofcoures Robert. I will send them an email. See what they come up with.
Did you ever get a response. Im also in sweden having the same problem. All flows are one hour late. My time is same though, time zone is right!
First, update your firmware to the stable v5 to see if that fixes the problem. When it doesn’t, you can also try changing your location to another timezone (like London) and back again to your actual location.
No, they did not give me a solution. They only confirmed that with my workaround the problem was solved. So getting in touch was a waste of time.
The restart worked for me too.
