There has been one occurrence of this before, this was when the password contained a ‘special’ character, are you by any chance using a password that contains any character that isn’t regularly used (letters, numbers, simple characters)
That will not be possible unfortunately, it’s not supported by the Api as mentioned before and also stated in the error message returned by the Api:
2023-07-12T17:29:52.571Z [log] [Api] _setLocationMode (Ring Alarm) error Error: Failed to set alarm mode to “some”. Sensors may require bypass, which can only be done in the Ring app.
Hi, I have noted that my ring doorbell pro does not communicate with Homey (early 2016 model) anymore. This happens every couple of months and normally deleting the doorbell and than including it does the trick. Now nothing seems to help anymore.
I removed the app and installed it again (in the hope that works) and I saw that the Ring app isn’t available anymore for Homey, only for Homey pro. Does that mean @DaneedeKruyff that I can’t use the app anymore?
I also tried the things you advised in post 97 (repair etc.), no luck.
After installing front doorbell these are the only items I get in the timeline. No other updates are received when someone walks by or rings the doorbell.
Thnx for your reply!
Not exactly sure which option you mean, within the ring app I can restart the app or in app settings revoke authentication. Do not know where remove all devices is located.
I removed all devices (just 1, doorbell pro) and removed the app to re-install it afterwards and added the doorbell again.
When the Ring API returns an error on changing the location mode using a flow, the returned error is now available to the user.
Here’s how to use this function:
Thanks for reporting there was no indication what was wrong when the location couldn’t be changed @Jaype
The next fix is in the flow card Turn the siren of for supported camera’s, this function wasn’t implemented correctly so the siren was not actually turned of by using this card, this is fixed now.
(Reported on GitHub)
Hi @DaneedeKruyff thanks! I tried that, however it doesnt solve the issue. The device in Homey registers the movement (see picture).
Its only that the flow doesnt work. I also tried making a fresh flow.
