to complete information for troubleshoot, below the log associated to Node214 (one which has problem) :
[2021-05-30T13:41:15.959Z] Node[214]: Received application command for COMMAND_CLASS_METER, data: 0x020134000000000000
[2021-05-30T13:41:15.960Z] Node[214]: [COMMAND_CLASS_METER] {“Meter Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Meter Type”:“Electric meter”,“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[52]},“Properties1”:{“Size”:4,“Scale”:2,“Precision”:1},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,0,0]}}
[2021-05-30T13:41:16.958Z] Node[214]: Received application command for COMMAND_CLASS_METER, data: 0x020134000000000000
[2021-05-30T13:41:16.960Z] Node[214]: [COMMAND_CLASS_METER] {“Meter Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Meter Type”:“Electric meter”,“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[52]},“Properties1”:{“Size”:4,“Scale”:2,“Precision”:1},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,0,0]}}
[2021-05-30T13:41:17.964Z] Node[214]: Received application command for COMMAND_CLASS_METER, data: 0x020134000000000000
[2021-05-30T13:41:17.965Z] Node[214]: [COMMAND_CLASS_METER] {“Meter Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Meter Type”:“Electric meter”,“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[52]},“Properties1”:{“Size”:4,“Scale”:2,“Precision”:1},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,0,0]}}
[2021-05-30T13:41:18.957Z] Node[214]: Received application command for COMMAND_CLASS_METER, data: 0x020134000000000000
[2021-05-30T13:41:18.958Z] Node[214]: [COMMAND_CLASS_METER] {“Meter Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Meter Type”:“Electric meter”,“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[52]},“Properties1”:{“Size”:4,“Scale”:2,“Precision”:1},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,0,0]}}
[2021-05-30T13:41:20.003Z] Node[214]: Received application command for COMMAND_CLASS_METER, data: 0x020134000000000000
[2021-05-30T13:41:20.005Z] Node[214]: [COMMAND_CLASS_METER] {“Meter Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Meter Type”:“Electric meter”,“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[52]},“Properties1”:{“Size”:4,“Scale”:2,“Precision”:1},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,0,0]}}
[2021-05-30T13:41:20.956Z] Node[214]: Received application command for COMMAND_CLASS_METER, data: 0x020134000000000000
[2021-05-30T13:41:20.957Z] Node[214]: [COMMAND_CLASS_METER] {“Meter Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Meter Type”:“Electric meter”,“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[52]},“Properties1”:{“Size”:4,“Scale”:2,“Precision”:1},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,0,0]}}
[2021-05-30T13:41:21.955Z] Node[214]: Received application command for COMMAND_CLASS_METER, data: 0x020134000000000000
[2021-05-30T13:41:21.956Z] Node[214]: [COMMAND_CLASS_METER] {“Meter Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Meter Type”:“Electric meter”,“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[52]},“Properties1”:{“Size”:4,“Scale”:2,“Precision”:1},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,0,0]}}
Below the technical specs of 2 modules in error (Qubino & Fibaro) :
