I have multiple fibaro devices, mainly the double relay and the door sensor 2. In 2017/2018 with homey 1.5 and lower they were working perfectly fine. Due to circumstances I have been away for 2 years and now back to get my home automation to the next level. I have updated Homey to the newest firmware and all devices were still there. However now when a fibaro device is switched, Homey does not respond.
As i did not know this, and because after 2 years the battery of the door sensor was empty, i replaced the battery, removed the device and added it again. After (trying many times) it was added. I could upload the new settings to the door sensor: I switched off the LED in 2017, but now i wanted to know if it works and switched on the LED again. This works from the settings of the door sensor within the Homey app. However now when I move the magnet next to the device, I see the LED switch on, but homey does not respond.
Also for the double relay, which obviously is build in the wall, when i press the light switch, the light switches on, however Homey does not see this. I can switch the light on and off from the homey app and i can use it in the way when using flows, but when i use the hardware switch, homey does not register this.
So in both cases, the device is seen by Homey and it can be controlled, but the signal that the device should send is not registered by Homey.
When i press the button of either my NodOn or my Everspring devices, i see in Homey the status changes.
Furthermore i have the MQTT hub and client installed. For Fibaro i never see any updates, however for my other z-wave devices like the NodOn or Everspring devices i see the /onoff topic change.
Are there others with this problem? Can i solve this? Or is this a Fibaro-app issue?
