Hi, Iam thinking of buying something like this smart knob to easily dimm lights by rotating and in second mode (pushing and rotating) change color temperature.
On the Tuya app page this button is not specifically mentioned. So I guess it will not work? Or am I wrong here?
That’s a nice gadget!
It’s true it has to be supported by the Tuya zigbee app.
With Tuya (related) devices the firmware can be different for the same type, or similar looking device.
The needed info can only be discovered by buying it, pair and interviewing it, and then request support → here’s the how-to.
Or, the quickest, but not the most easy way (and, it depends on the cloud):
- buy a cheap (~ E19,-) Tuya zigbee hub
- control Homey via raw commands (Tuya MQTT-ish version) with the Tuya Cloud app.
Oh when you’re interested, I found a much cheaper one here, around E 14,60
Thanks, I think I will try it and then follow the how to to request support. I think there will be other people that would like integrate this.
Agreed, I did not see such versatile knob before.
It has an unknown ETA, while the dev is working on it in is spare hours, and maybe a bunch of donations speeds up things ![]()
I have this smart knob too, did you manage to request support to add it?
because I cannot pair it directly to my Homey yet…
Thanks!
Hey, I have gotten my homey pro two weeks ago and looked into this. I followed the the steps that were explained in the previous post.
However apparently someone already made the request for this knob and it hasn’t been integrated yet.
Since this is all done on a voluntary basis it might take some time.
I have looked at the code at github but haven’t had the time to actually do stuff.
I sent the dev manufacturer code via github, to get this device registered.
Great Job! I didnt know they switched the process to directly add request in Github now.
Yeah it’s changed lately, it’s explained in the Tuya Zigbee app topic:
I just received the Smart Knob, and I still don’t see it in the Tuya Zigbee app. Do you have any updated information?
Use Tuya zigbee test version
“Which device have you linked it to? I don’t see the ‘smart knob’ anywhere.”
It doesn’t really matter how you pair it, Homey will automatically pick the correct device driver once it’s paired (provided it’s actually supported).
Ok thanks. I´ll check it later
I was able to get the Moes Smart Knob working.
1 install the Tuya Zigbee App, at the time of this writing make sure to install the Test version not the current version. The test version has far more devices.
2 battery is not included. Remove the battery lid by removing the very small screw. The magnet with in will either hinder or help. Replace the battery lid.
3 find the reset pin taped to the box. If lost any will do. Ideally not a sharp point.
4 set homey in inclusion mode. Look for “smart knob”. If not there make sure you have the test version of the app.
5 while honey is in pair mode- reset the knob by inserting the pin in the hole to press the button. This is tiny and there are two holes, one with the light and the other has the button. I used my iPhone camera to see which hole has the button. Hold the button a few seconds, it will blink.
Button offers, press, rotate clockwise, rotate Counter clockwise, press while rotate either way.
All plastic, magnetic base and a metal screw plate mount. No additional hardware needed.
Prices vary wildly from $50 to $7 so watch the price!
Hey Peter,
I installed the button, the cheap one you posted. It is included, but it doesn’t do anything in my zone (with 10 lights). Any thoughts on how I can get the whole zone to respond.
Thanks
Jeroen
Not sure what you mean, Jeroen.
But to control lights in a zone, you’d create a flow like:
When..
smart button scene X is activated
Then..
Turn on all lights in Zone Y
Thanks. I thought it would automatically control all lights in a zone.
But this makes sense.
Not sure how to program a scene or a color but I guess this will show itself.
pretty good with advanced flows.
Thanks
